[petsc-users] Problem Using EPSGetEigenpair
Jose E. Roman
jroman at dsic.upv.es
Fri Feb 8 08:05:14 CST 2019
You are printing the variable as an integer, and it is not an integer, it's a PetscScalar. Use %g
Jose
> El 8 feb 2019, a las 15:02, Eda Oktay via petsc-users <petsc-users at mcs.anl.gov> escribió:
> Hello,
> I am trying to test EPSGetEigenpair function on ex11 in EPS.
> First, I executed ex11 and get 0.097887 as eigenvalue (k).
> Then under the code
> ierr = PetscPrintf(PETSC_COMM_WORLD," Number of requested eigenvalues: %D\n",nev);CHKERRQ(ierr);
> I added the following code:
> ierr = EPSGetEigenpair(eps,0,&kr,NULL,NULL,NULL);
> ierr = PetscPrintf(PETSC_COMM_WORLD," Requested eigenvalue: %D\n",kr);CHKERRQ(ierr);
> After execution, I expected to find 0.097887 but the requested eigenvalue was found as -876957631.
> Why EPSGetEigenpair couldn't give 0.097887, isn't 0.097887 the eigenvalue that EPSSetWhichEigenpairs(eps,EPS_SMALLEST_REAL) calculated?
> Best regards,
> Eda
