[petsc-users] different dof in DMDA creating
Danyang Su danyang.su at gmail.com
Thu Feb 7 15:53:06 CST 2019
Thanks, Barry. DMPlex also works for my code.
Danyang
On 2019-02-07 1:14 p.m., Smith, Barry F. wrote:
>    No, you would need to use the more flexible DMPlex
>> On Feb 7, 2019, at 3:04 PM, Danyang Su via petsc-users <petsc-users at mcs.anl.gov> wrote:
>> Dear PETSc Users,
>> Does DMDA support different number of degrees of freedom for different node? For example I have a 2D subsurface flow problem with the default dof = 1 throughout the domain. Now I want to add some sparse fractures in the domain. For the nodes connected to the sparse fractures, I want to set dof to 2. Is it possible to set dof to 2 for those nodes only?
>> Thanks,
>> Danyang
