[petsc-users] reading petsc binary files.
Wed Feb 6 05:32:40 CST 2019
On Tue, Feb 5, 2019 at 6:36 PM Smith, Barry F. via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> > On Feb 5, 2019, at 5:06 PM, Sanjay Kharche via petsc-users <
> > Hi
> > I use two mpi clusters (cluster 1 and 2). Whereas the petsc binary files
> I generate can be read on cluster 1, I get errors doing so on cluster 2. I
> also output vts files corresponding to each binary file output, and it
> appears that both clusters do produce meaningful results. I use ver 3.7.4
> on cluster 1, and 3.7.5 on 2. Also, the same simulation produces binary
> files of slightly different sizes on the two clusters.
>    This is truly strange. PETSc has always used the exact same format for
> its binary files and automatically handles any byte-swapping that may be
> need to always have a consistent representation on the disk. Also a
> difference in the file size is strange. In over 20 years we've never had an
> issue with unreadable binary files.
>   Can cluster 1 read the binary files from cluster 1 and cluster 2 read
> the binary files from cluster 2. Is it just cluster 2 cannot read the files
> from cluster 1?
>   Could the file be changed somehow as it is copied between the clusters?
>   Is this difference in size reproducible if you delete the files and
> create them again?
>   Is one of the clusters by any chance a Microsoft Windows cluster?
Is one configured with 64-bit integers and the other not?
     Matt
>    Barry
> > Can you comment on what I need to do to be able to read binary files on
> cluster 2.
> > thanks
> > Sanjay
> > Code snippet from parallel petsc code that does output:
> > if(time_int % (int)(1.0/DELTAT) == 0){ // a smaller time step and more
> files outputted makes the CV estimate better.
> > sprintf(str,"my_2d%d.vts", file_Counter); // this confirms that
> simulation does something meaningful.
> > PetscViewer viewer;  PetscViewerCreate(PETSC_COMM_WORLD, &viewer);
> PetscViewerSetType(viewer, PETSCVIEWERVTK);
> > PetscViewerFileSetName(viewer, str); VecView(u, viewer);
> PetscViewerDestroy(&viewer);
> >                 sprintf(str,"my_3d%d.bin",(int)file_Counter);
> > PetscViewer viewer2;
> > PetscViewerBinaryOpen(PETSC_COMM_WORLD,str,FILE_MODE_WRITE,&viewer2);
> > VecView(u,viewer2);
> > PetscViewerDestroy(&viewer2);
> > file_Counter++;
> > How I am trying to read it (typically serial code with binary called
> ecg):
> >   // inputs are Petsc binary files, create and destroy viewer at each
> file for simplicity.
> > PetscViewer viewer_in;
> > sprintf(str,"my_3d%d.bin",file_Counter);
> > PetscViewerBinaryOpen(PETSC_COMM_WORLD,str,FILE_MODE_READ,&viewer_in);
> > VecLoad(u,viewer_in);
> > PetscViewerDestroy(&viewer_in);
> > Errors I got when I ran ecg:
> > login3 endo]$ ./ecg
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Invalid argument
> > [0]PETSC ERROR: Not a vector next in file
> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> > [0]PETSC ERROR: Petsc Release Version 3.7.5, Jan, 01, 2017
> > [0]PETSC ERROR: ./ecg on a arch-linux2-c-opt named gra-login3 by
> kharches Tue Feb  5 17:43:36 2019
> > [0]PETSC ERROR: Configure options --prefix=/cvmfs/
> soft.computecanada.ca/easybuild/software/2017/avx2/MPI/intel2016.4/openmpi2.1/petsc/3.7.5
> --with-mkl_pardiso=1 --with-mkl_pardiso-dir=/cvmfs/
> soft.computecanada.ca/easybuild/software/2017/Core/imkl/11.3.4.258/mkl
> --with-hdf5=1 --with-hdf5-dir=/cvmfs/
> soft.computecanada.ca/easybuild/software/2017/avx2/MPI/intel2016.4/openmpi2.1/hdf5-mpi/1.8.18
> --download-hypre=1 --download-metis=1 --download-triangle=1
> --download-ptscotch=1 --download-superlu_dist=1 --download-ml=1
> --download-superlu=1 --download-prometheus=1 --download-mumps=1
> --download-parmetis=1 --download-suitesparse=1 --download-mumps-shared=0
> --download-ptscotch-shared=0 --download-superlu-shared=0
> --download-superlu_dist-shared=0 --download-parmetis-shared=0
> --download-metis-shared=0 --download-ml-shared=0
> --download-suitesparse-shared=0 --download-hypre-shared=0
> --download-prometheus-shared=0 --with-cc=mpicc --with-cxx=mpicxx
> --with-c++-support --with-fc=mpifort --CFLAGS="-O2 -xCore-AVX2 -ftz
> -fp-speculation=safe -fp-model source -fPIC" --CXXFLAGS="-O2 -xCore-AVX2
> -ftz -fp-speculation=safe -fp-model source -fPIC" --FFLAGS="-O2 -xCore-AVX2
> -ftz -fp-speculation=safe -fp-model source -fPIC" --with-gnu-compilers=0
> --with-mpi=1 --with-build-step-np=8 --with-shared-libraries=1
> --with-debugging=0 --with-pic=1 --with-x=0 --with-windows-graphics=0
> --with-scalapack=1 --with-scalapack-include=/cvmfs/
> soft.computecanada.ca/easybuild/software/2017/Core/imkl/11.3.4.258/mkl/include
> --with-scalapack-lib="[/cvmfs/
> soft.computecanada.ca/easybuild/software/2017/Core/imkl/11.3.4.258/mkl/lib/intel64/libmkl_scalapack_lp64.a,libmkl_blacs_openmpi_lp64.a,libmkl_intel_lp64.a,libmkl_sequential.a,libmkl_core.a]"
> --with-blas-lapack-lib="[/cvmfs/
> soft.computecanada.ca/easybuild/software/2017/Core/imkl/11.3.4.258/mkl/lib/intel64/libmkl_intel_lp64.a,libmkl_sequential.a,libmkl_core.a]"
> --with-fftw=1 --with-fftw-dir=/cvmfs/
> soft.computecanada.ca/easybuild/software/2017/avx2/MPI/intel2016.4/openmpi2.1/fftw-mpi/3.3.6
> > [0]PETSC ERROR: #1 PetscViewerBinaryReadVecHeader_Private() line 28 in
> /dev/shm/ebuser/PETSc/3.7.5/iomkl-2016.4.11/petsc-3.7.5/src/vec/vec/utils/vecio.c
> > [0]PETSC ERROR: #2 VecLoad_Binary() line 90 in
> > [0]PETSC ERROR: #3 VecLoad_Default() line 413 in
> > [0]PETSC ERROR: #4 VecLoad() line 975 in
> /dev/shm/ebuser/PETSc/3.7.5/iomkl-2016.4.11/petsc-3.7.5/src/vec/vec/interface/vector.c
> > [0]PETSC ERROR: #5 VecLoad_Binary_DA() line 931 in
> /dev/shm/ebuser/PETSc/3.7.5/iomkl-2016.4.11/petsc-3.7.5/src/dm/impls/da/gr2.c
> > [0]PETSC ERROR: #6 VecLoad_Default_DA() line 964 in
> > [0]PETSC ERROR: #7 VecLoad() line 975 in
> > This email is directed in confidence solely to the person named above
> and may contain confidential, privileged or personal health information.
> Please be aware that this email may also be released to members of the
> public under Ontario's Freedom of Information and Protection of Privacy Act
> if required. Review, distribution, or disclosure of this email by anyone
> other than the person(s) for whom it was originally intended is strictly
> prohibited. If you are not an intended recipient, please notify the sender
> immediately via a return email and destroy all copies of the original
> message. Thank you for your cooperation.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190206/eba62ef5/attachment-0001.html>
