[petsc-users] [TimeStepping] Eventhandler
Huck, Moritz Moritz.Huck at rwth-aachen.de
Tue Feb 5 11:30:15 CST 2019
I am using the fenics library for my PDE discretization.
I can not compile fenics with PETSc 3.10.3.
I will locate the exact error tomorrow.
Von: Jed Brown <jed at jedbrown.org>
Gesendet: Dienstag, 5. Februar 2019 15:30:38
An: Huck, Moritz; Smith, Barry F.; Abhyankar, Shrirang G
Cc: PETSc users list
Betreff: Re: [petsc-users] [TimeStepping] Eventhandler
"Huck, Moritz via petsc-users" <petsc-users at mcs.anl.gov> writes:
> @Shri
> The system is very stiff, but the stiffness is handled well by ARKIMEX.
> I'am using PETSc 3.10. (I cannot use 3.10.3 at the moment due to
> compatibilty with a third library),
What compatibility problem is this?  3.10.3 should be (binary and
source) backward compatible with other 3.10 releases, so if there is a
case where it is not, we need to understand it.
Regarding the event, it seems there are scenarios where something
important changes in the model and a conservative time step is
desirable, and other scenarios where the dynamics after the event are on
the same scale as before so it makes sense to continue with the same
step sizes.
