[petsc-users] Installing PETSc
Jed Brown
jed at jedbrown.org
Tue Feb 5 08:36:32 CST 2019
Fazlul Huq via petsc-users <petsc-users at mcs.anl.gov> writes:
> Hello PETSc Developers,
> may be this is a trivial question!
> I usually run PETSc code from Home/petsc-3.10.2 directory. Last day I tried
> to run the code from Documents/petsc directory but I can't. As far as I can
> recall, I have installed PETSc in the Home directory. Is it the reason why
> I can't run PETSc code from other directory? Shall I install PETSc in the
> root directory?
What do you mean by "run PETSc"? How did you link your executable?
> Again, if I run command "which petsc" I don't get any echo on the terminal.
That is searching for an executable named "petsc" in your PATH.
echo $PATH
to see the value of that variable.
