[petsc-users] Installing PETSc
Fazlul Huq
huq2090 at gmail.com
Tue Feb 5 08:05:08 CST 2019
Hello PETSc Developers,
may be this is a trivial question!
I usually run PETSc code from Home/petsc-3.10.2 directory. Last day I tried
to run the code from Documents/petsc directory but I can't. As far as I can
recall, I have installed PETSc in the Home directory. Is it the reason why
I can't run PETSc code from other directory? Shall I install PETSc in the
root directory?
Again, if I run command "which petsc" I don't get any echo on the terminal.
Thanks.
Sincerely,
Huq
Fazlul Huq
Graduate Research Assistant
Department of Nuclear, Plasma & Radiological Engineering (NPRE)
University of Illinois at Urbana-Champaign (UIUC)
E-mail: huq2090 at gmail.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190205/8cfff6fe/attachment.html>
