[petsc-users] PETSC matrix assembling super slow
Smith, Barry F. bsmith at mcs.anl.gov
Mon Feb 4 16:21:30 CST 2019
> On Feb 4, 2019, at 3:17 PM, Yaxiong Chen via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hi Mark,
>      Will the parameter MatMPIAIJSetPreallocation in influence the following part
>       do i=mystart,nelem,nproc
>             call ptSystem%getElementalMAT(i, Ae, auxRHSe, idx)
>             ne=size(idx)
>             idx=idx-1           !-1 since PETSC index starts from zero
>             if (allocated(auxRHSe))  call VecSetValues(bvec,ne,idx,auxRHSe,ADD_VALUES,ierr)
>             call MatSetValues(Amat,ne,idx,ne,idx,Ae,ADD_VALUES,ierr)
>       end do
> I found this part will impede my assembling process. In my case ,the total DOF is 20800. I estimated the upper bound  of number of nonzero entries in each row as 594. So I set f9 to be 20206 and f6 to be 10103 in the following command:
>  call MatMPIAIJSetPreallocation(Amat,f9,PETSC_NULL_INTEGER,f6,PETSC_NULL_INTEGER, ierr)
> Running the code in sequential mode with -info I got the following information.And I can get the result even thought the assembling process is kind of slow(several times slower than using Mumps).
> [0] MatAssemblyBegin_MPIBAIJ(): Stash has 0 entries,uses 0 mallocs.
> [0] MatAssemblyBegin_MPIBAIJ(): Block-Stash has 0 entries, uses 0 mallocs.
> [0] MatAssemblyEnd_SeqBAIJ(): Matrix size: 20800 X 20800, block size 1; storage space: 13847 unneeded, 1030038 used
> [0] MatAssemblyEnd_SeqBAIJ(): Number of mallocs during MatSetValues is 62659
   Something is very wrong. The number of mallocs should be zero if you have the correct preallocation. Are you calling MatZeroEntries() or some other Mat routine before you call MatSetValues() ?
> [0] MatAssemblyEnd_SeqBAIJ(): Most nonzeros blocks in any row is 70
> [0] MatCheckCompressedRow(): Found the ratio (num_zerorows 0)/(num_localrows 20800) < 0.6. Do not use CompressedRow routines.
> [0] PetscCommDuplicate(): Using internal PETSc communicator 4462889472 140509341618528
> [0] VecScatterCreate_Seq(): Special case: sequential copy
> [0] MatAssemblyEnd_SeqBAIJ(): Matrix size: 20800 X 0, block size 1; storage space: 104000 unneeded, 0 used
> [0] MatAssemblyEnd_SeqBAIJ(): Number of mallocs during MatSetValues is 0
> [0] MatAssemblyEnd_SeqBAIJ(): Most nonzeros blocks in any row is 0
> [0] MatCheckCompressedRow(): Found the ratio (num_zerorows 20800)/(num_localrows 20800) > 0.6. Use CompressedRow routines.
>  aseembel time   282.54871800000001
> [0] PetscCommDuplicate(): Using internal PETSc communicator 4462888960 140509341442256
> [0] PCSetUp(): Setting up PC for first time
> [0] PCSetUp(): Leaving PC with identical preconditioner since operator is unchanged
> However, when I use the parallel mode,I got the following information:
> [0] MatAssemblyBegin_MPIBAIJ(): Stash has 707965 entries,uses 6 mallocs.
   You have a lot of off-process MatSetValues(). That is one process is generating a lot of matrix entries that belong on another process. This is not desirable. Ideally each process will generate the matrix entries that belong to that process so only a few matrix entries need to be transported to another process. How are you partitioning the mesh and how are you deciding which process computes which which entries in the matrix? All of this may be need to be revisited.
  Barry
> it seems it never went to  call MatAssemblyEnd(Amat,MAT_FINAL_ASSEMBLY,ierr)
> Is there anything I am doing wrong?
> Thanks
> Yaxiong Chen,
> Ph.D. Student
> School of Mechanical Engineering, 3171
> 585 Purdue Mall
> West Lafayette, IN 47907
> From: Mark Adams <mfadams at lbl.gov>
> Sent: Tuesday, January 29, 2019 10:02 PM
> To: Yaxiong Chen; PETSc users list
> Subject: Re: [petsc-users] PETSC matrix assembling super slow
> Optimized is a configuration flag not a versions.
> You need to figure out your number of non-zeros per row of you global matrix, or a bound on it, and supply that in MatMPIAIJSetPreallocation. Otherwise it has to allocate and copy memory often.
> You could increase your f9 on a serial run and see what runs best and then  move to parallel with a value in f6 of about 1/2 of f9.
> On Tue, Jan 29, 2019 at 9:13 PM Yaxiong Chen <chen2018 at purdue.edu> wrote:
> Thanks Mark,
>     I use PETSC 3.9.4, is this the optimized version you called?
>     Actually f9 and f6 are from the PETSC example. I don't know how to set the value correctly so I commend them. The size of my elemental matrix may vary. For 2D problem, the size of elemental matrix can be 24*24 or 32*32 or some other sizes. And the index is not continuous. In this case, the elemental matrix may interlace with each other in the global matrix, and I may have thousands of elemental matrix to be assembled. Does the preallocating suitable for this?
> Yaxiong Chen,
> Ph.D. Student
> 585 Purdue Mall
> Sent: Tuesday, January 29, 2019 8:25 PM
> To: Yaxiong Chen
> Cc: Song Gao; petsc-users at mcs.anl.gov
> Slow assembly is often from not preallocating correctly. I am guessing that you are using Q1 element and f9==9, and thus the preallocation should be OK if this is a scalar problem on a regular grid and f6-==6 should be OK for the off processor allocation, if my assumptions are correct.
> You can run with -info, which will tell you how many allocation were done in assembly. Make sure that it is small (eg, 0).
> I see you use f90 array stuff 'idx-1'. Compilers can sometimes do crazy things with seeming simple code. You could just do this manually if you can find anything else.
> And I trust you are running an optimized version of PETSc.
> On Tue, Jan 29, 2019 at 6:22 PM Yaxiong Chen via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hi Song,
> I don't quite understand how I can use this command. I don't partition the gloabl matrix. If I add my elemental matrix to the global system it will be like this. And in my parallel part, I use each core to generate the elemental matrix in turn. In this case, I guess each core will be assigned the space for global matrix and finally be assembled.But according to the manual, it seems each core will store a part of the global matrix. Is the local submatrix in the MatMPIAIJSetPreallocation(Mat B,PetscInt d_nz,const PetscInt d_nnz[],PetscInt o_nz,const PetscInto_nnz[])the same as my elemental matrix?
> <pastedImage.png>
> Thanks
> Yaxiong Chen,
> Ph.D. Student
> 585 Purdue Mall
> From: Song Gao <song.gao2 at mail.mcgill.ca>
> Sent: Tuesday, January 29, 2019 1:22 PM
> To: Yaxiong Chen
> Cc: Matthew Knepley; petsc-users at mcs.anl.gov
> I think you would prefer to preallocate the matrix
> uncomment this line
> ! call MatMPIAIJSetPreallocation(Amat,f9,PETSC_NULL_INTEGER,f6,PETSC_NULL_INTEGER, ierr)
> Le mar. 29 janv. 2019, à 12 h 40, Yaxiong Chen via petsc-users <petsc-users at mcs.anl.gov> a écrit :
> Hello,
> I have a 2D system which is assembled by each elemental matrix.  Ae is my elemental matrix, auxRHSe(:) and RHSe(:) and corresponding right hand side, idx is the global index. My code is as follow, however ,the assembling rate is super slow(Marked red in the code). I am not sure whether the assembling type is right or not. Since for each element, idx are not continuous numbers. Do you have any idea what is the better way to assemble the matrix?
> Thanks
> block
>     PetscErrorCode ierr
>      PetscMPIInt rank,nproc, mystart
>      PetscInt  nelem
>      integer,allocatable  ::info(:)
>      real(wp), allocatable :: Ae(:,:), auxRHSe(:),RHSe(:)
>      integer, allocatable      :: idx(:)
>      PetscScalar, pointer :: xx_v(:)
>      PC               prec
>      PetscScalar ::   val
>      Vec              xvec,bvec,uvec
>      Mat              Amat
>      KSP              ksp
>      PetscViewer viewer
>      PetscInt  geq,j,k,ne,M,Istart,Iend
>      PetscBool  flg
>      KSPConvergedReason reason
>      Vec         dummyVec, dummyVecs(1)
>      MatNullSpace nullspace
>      call PetscInitialize( PETSC_NULL_CHARACTER, ierr )
>      if (ierr .ne. 0) then
>      print*,'Unable to initialize PETSc'
>      stop
>      endif
>      call MPI_Comm_size(PETSC_COMM_WORLD,nproc,ierr)
>      call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)
>      mystart=rank+1
>  !   Parameter set
>      info=ptsystem%getInitInfo()
>      nelem = info(Info_EleMatNum)+info(Info_FixedDOFNum)+info(Info_NumConstrain)
>      print*,'nelem',nelem
>  !  Create Matrix
>      call MatCreate(PETSC_COMM_WORLD,Amat,ierr)
>      call MatSetSizes( Amat,PETSC_DECIDE, PETSC_DECIDE, info(1), info(1), ierr )
>      call MatSetType( Amat, MATMPIBAIJ, ierr )
>      call MatSetFromOptions( Amat, ierr )
>      call MatSetUp( Amat, ierr )
>      call MatGetOwnershipRange( Amat, Istart, Iend, ierr )
>       xvec = tVec(0)
>       call MatCreateVecs( Amat, PETSC_NULL_VEC, xvec, ierr )
>       call VecSetFromOptions( xvec, ierr )
>       call VecDuplicate( xvec, bvec, ierr )
>       call VecDuplicate( xvec, uvec, ierr )
>    t1 = MPI_WTime();
>             ne=size(idx)
>             if (allocated(auxRHSe))  call VecSetValues(bvec,ne,idx-1,auxRHSe,ADD_VALUES,ierr)
>              call MatSetValues(Amat,ne,idx-1,ne,idx-1,Ae,ADD_VALUES,ierr)
>       end do
>       nelem   = info(Info_EleRHSNum)
>       mystart = rank+1
>       do i = mystart, nelem, nproc
>         call ptSystem%getElementalRHS(i, RHSe, idx)
>         print*,'idx',idx
>         ne=size(idx)
>         if (allocated(RHSe))  call VecSetValues(bvec,ne,idx-1,RHSe,ADD_VALUES,ierr)
>       end do
>       call MatAssemblyBegin(Amat,MAT_FINAL_ASSEMBLY,ierr)
>       call MatAssemblyEnd(Amat,MAT_FINAL_ASSEMBLY,ierr)                          !  this part is slow, the for loop above is done but here it may get stuck
>       call VecAssemblyBegin(bvec,ierr)        ! For a 2500 DOF system, assembling only takes over 2 seconds
>       call VecAssemblyEnd(bvec,ierr)        ! But for a 10000 DOF system , it gets stuck
>      t2 = MPI_WTime();
>       print*,'assembeling time',t2-t1
>       ! Solve
>       call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
> !  Set operators. Here the matrix that defines the linear system
> !  also serves as the preconditioning matrix.
>       call KSPSetOperators(ksp,Amat,Amat,ierr)
>       call KSPSetFromOptions(ksp,ierr)
> !                      Solve the linear system
>     call KSPSetType(ksp,KSPCG,ierr)
>     call KSPGetPC(ksp,prec,ierr)
>    ! call KSPSetPCSide(ksp,PC_SYMMETRIC,ierr)
>     call PCSetType(prec,PCJACOBI,ierr)
>      call KSPSolve(ksp,bvec,xvec,ierr)
>      call PetscFinalize(ierr)
> end block
> Yaxiong Chen,
> Ph.D. Student
> 585 Purdue Mall
