[petsc-users] Queries related to snes options
Aman Saxena
amansaxena.iitg at gmail.com
Mon Feb 4 05:03:54 CST 2019
I am trying to use PETSc's TS to implement implicit time-stepping, for
1d-Euler Equation discretized using 5th order WENO schemes. I have
following queries related to using some of the snes options::
-- What does -ts_max_snes_failure means and what does the non-linear solver
do once it diverges to ensure convergence?
-- If I do not specify “-snes_fd” or “-snes_mf”, does by default it uses
the jacobian I have coded instead of building it using Finite-differences?
-- As “-snes_fd ” replaces my routine to calculate the jacobian with
petsc’s fd routine, does it stores the jacobian in the same Matrix that I
pass to my hand-coded routine. It might lead to some inconsistency as my
actual scheme involves stencils width equals 3 while I am approximating the
Jacobian using first order scheme which requires stencils width equals 1.
So I have used another “dmda” with sw = 1, to initialize the matrix using
“DMCreateMatrix()” while fd needs sw = 3.
-- I am not able to use “-snes_type test” it gives me the following error
“[0]PETSC ERROR: Unknown type. Check for miss-spelling or missing package:
http://www.mcs.anl.gov/petsc/documentation/installation.html#external
[0]PETSC ERROR: Unable to find requested SNES type test”
-- What exactly "PCMAT" do? Do I have to supply matrix other than in
RHSJacobian for PCMAT?
Thanks
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190204/634bd2b5/attachment.html>
