[petsc-users] Ksp Initial residual norm
Smith, Barry F.
bsmith at mcs.anl.gov
Sun Feb 3 13:03:24 CST 2019
If you use the default KSP convergence tests (which almost everyone does) the initial residual norm is stored in ksp->rnorm0. Thus to access it you need to include the private header file that defines the KSP object kspimpl.h so something like
#include <petsc/private/kspimpl.h>
PetscErrorCode KSPGetInitialResidualNorm(KSP ksp,PetscReal *norm0)
*norm0 = ksp->rnorm0;
return 0;
should work.
Barry
> On Feb 3, 2019, at 8:27 AM, Edoardo alinovi via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Dear all,
> I have a very simple question for you. How can I get the initial residual from a ksp solver? I can easily extract the final (preconditioned) residual norm but when I try to use to do the same with the initial residual using:
> kspInitialResidual()
> PETSc tells me that this feature is not supported. I am actually doing it applying the definition of residual "by hand", but I am wondering if somenthing already built-in is available or not.
> Thank you very much!
> Edoardo Alinovi, Ph.D.
> DICCA, Scuola Politecnica,
> Universita' degli Studi di Genova,
> 1, via Montallegro,
> 16145 Genova, Italy
> Email: edoardo.alinovi at dicca.unige.it
> Tel: +39 010 353 2540
