[petsc-users] Reading a complex vector from HDF5
Sajid Ali sajidsyed2021 at u.northwestern.edu
Fri Feb 1 14:38:34 CST 2019
Column 1 contains the real value and column 2 contains the imaginary value,
correct?
I did that last time as well (and opened it using h5py just to be sure that
the shape is indeed dim x 2 and the datatype is f8),  yet I get the error.
The error comes from these lines in PETSc :
#if defined(PETSC_USE_COMPLEX)
if (!h->complexVal) {
H5T_class_t clazz = H5Tget_class(datatype);
if (clazz == H5T_FLOAT) SETERRQ(PetscObjectComm((PetscObject)viewer),
PETSC_ERR_SUP,"File contains real numbers but PETSc is configured for
complex. The conversion is not yet implemented. Configure with
--with-scalar-type=real.");
Am I setting the dtype incorrectly?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190201/a0c37fba/attachment.html>
