[petsc-users] killed 9 signal after upgrade from petsc 3.9.4 to 3.12.2
Santiago Andres Triana
repepo at gmail.com
Mon Dec 23 14:13:08 CST 2019
Dear all,
After upgrading to petsc 3.12.2 my solver program crashes consistently.
Before the upgrade I was using petsc 3.9.4 with no problems.
My application deals with a complex-valued, generalized eigenvalue problem.
The matrices involved are relatively large, typically 2 to 10 Gb in size,
which is no problem for petsc 3.9.4.
However, after the upgrade I can only obtain solutions when the matrices
are small, the solver crashes when the matrices' size exceed about 1.5 Gb:
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
batch system) has told this process to end
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
to find memory corruption errors
[0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
run
[0]PETSC ERROR: to get more information on the crash.
and so on for each cpu.
I tried using valgrind and this is the typical output:
==2874== Conditional jump or move depends on uninitialised value(s)
==2874== at 0x4018178: index (in /lib64/ld-2.22.so)
==2874== by 0x400752D: expand_dynamic_string_token (in /lib64/ld-2.22.so)
==2874== by 0x4008009: _dl_map_object (in /lib64/ld-2.22.so)
==2874== by 0x40013E4: map_doit (in /lib64/ld-2.22.so)
==2874== by 0x400EA53: _dl_catch_error (in /lib64/ld-2.22.so)
==2874== by 0x4000ABE: do_preload (in /lib64/ld-2.22.so)
==2874== by 0x4000EC0: handle_ld_preload (in /lib64/ld-2.22.so)
==2874== by 0x40034F0: dl_main (in /lib64/ld-2.22.so)
==2874== by 0x4016274: _dl_sysdep_start (in /lib64/ld-2.22.so)
==2874== by 0x4004A99: _dl_start (in /lib64/ld-2.22.so)
==2874== by 0x40011F7: ??? (in /lib64/ld-2.22.so)
==2874== by 0x12: ???
==2874==
These are my configuration options. Identical for both petsc 3.9.4 and
3.12.2:
./configure --with-scalar-type=complex --download-mumps --download-parmetis
--download-metis --download-scalapack=1 --download-fblaslapack=1
--with-debugging=0 --download-superlu_dist=1 --download-ptscotch=1
CXXOPTFLAGS='-O3 -march=native' FOPTFLAGS='-O3 -march=native'
COPTFLAGS='-O3 -march=native'
Thanks in advance for any comments or ideas!
Cheers,
Santiago
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191223/9dbef242/attachment.html>
