[petsc-users] Corrrect usage of MatMumpsGetInverse()
Jan Grießer
griesser.jan at googlemail.com
Mon Dec 16 10:08:10 CST 2019
Hello, everybody,
I am using PETSc version 3.12 together with MUMPS to calculate a part of an
inverse from a matrix A. For this I used the example
mat/examples/tests/ex214.c as suggested here in the forum. For test
purposes I read a matrix with the dimension 10x10, which only has entries
on the main diagonal, because I know the inverse of it.
But now I have a problem using the MatMumpsGetInverse() function. I get the
error message:
Error reported by MUMPS in solve phase: INFOG(1)=-47 INFO(2)=1 ACcording to
the MUMPS Docu this message tells me that I would ignored the constraint
NRHS= N. I checked the shape of spRHST but they appear to be correct. Does
anyone see the error?
My code is appended below.
static char help[] ="Compute a part of the inverse of a sparse matrix. This
code requires that PETSc was configured with MUMPS since we are dealing
with large matrices \
and therefore use a parallel LU factorization. We compute the inverse
by solving the equation A*X=RHS. Where A is our Matrix, X is the inverse
and RHS is the identity matrix.\
Note that the number of columns nrhs of X can be chosen smaller than
the number of columns N in A. Therefore only a part of the inverse is
computed in X. \n \
In this code we use a sparse representation of the RHS matrix in MUMPS
in csr format. Computation of selected entries in inv(A) is done using
MatMumpsGetInverse. \n \
Input parameters: \n\
-fin <input_file> : file to load \n \
-fout <input_file> : file to load \n \
-nrhs <numberofcolumns> : Number of columns to compute \n \
-displ <Bool>: Print matrices to terminal \n\
Example usage: \n \
mpiexec -np 2 ./compute_inverse_sparse_rhs -fin
../../convert_to_binary_petsc_matrix/identity_matrix_prefactor3_ncols10
-nrhs 5 -displ";
#include <stdio.h>
#include <petscmat.h>
#include <petscviewer.h>
int main(int argc, char **args){
PetscErrorCode ierr; // Datatype used for return error code
PetscMPIInt size,rank; // Datatype used to represent 'int' parameters
to MPI functions.
#if defined(PETSC_HAVE_MUMPS)
Mat A,F,spRHST; // Abstract PETSc matrix object used to manage all
linear operators in PETSc
PetscViewer fd; // Abstract PETSc object that helps view (in ASCII,
binary, graphically etc) other PETSc objects
PetscBool flg1,flg2; // Logical variable. Actually an int in C.
PetscBool displ=PETSC_FALSE; // Display matrices
PetscInt M,N,m,n,rstart,rend,nrhs,i; // PETSc type that represents an
integer, used primarily to represent size of arrays and indexing into
arrays.
PetscScalar v; // PETSc type that
represents either a double precision real number,...
char inputfile[1][PETSC_MAX_PATH_LEN]; // Input file name
// char outputfile[1][PETSC_MAX_PATH_LEN]; // Outputfile file name
#endif
// Initializes PETSc and MPI. Get size and rank of MPI.
ierr = PetscInitialize(&argc, &args, (char*)0, help);if (ierr){return
ierr;}
ierr = MPI_Comm_size(PETSC_COMM_WORLD, &size);CHKERRQ(ierr);
ierr = MPI_Comm_rank(PETSC_COMM_WORLD,&rank);CHKERRQ(ierr);
//Check if PETSc was configured with MUMPS. If not print error message
and exit
#if !defined(PETSC_HAVE_MUMPS)
if (!=rank){ierr = PetscPrintf(PETSC_COMM_SELF, "This code requires
MUMPS, exit...\n");CHKERRQ(ierr);
ierr = PetscFinalize();
return ierr;
#else
// Check if displ is set. If True the matrices are printed to the
terminal
ierr = PetscOptionsGetBool(NULL, NULL, "-displ", &displ,
NULL);CHKERRQ(ierr);
// Load matrix A from file
ierr = PetscOptionsGetString(NULL, NULL, "-fin" ,inputfile[0],
PETSC_MAX_PATH_LEN, &flg1);CHKERRQ(ierr);
ierr = PetscPrintf(PETSC_COMM_WORLD, "Load matrix in: %s \n",
inputfile[0]);CHKERRQ(ierr);
ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD, inputfile[0],
FILE_MODE_READ, &fd);CHKERRQ(ierr);
ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
ierr = MatSetType(A, MATAIJ);CHKERRQ(ierr);
ierr = MatLoad(A, fd);CHKERRQ(ierr);
// Print matrix A
if (displ){
"\n---------------\n");CHKERRQ(ierr);
ierr = PetscPrintf(PETSC_COMM_WORLD,"Matrix A from file:\n", nrhs);
ierr = MatView(A, PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
ierr = PetscPrintf(PETSC_COMM_WORLD, "\n");CHKERRQ(ierr);
// Check if matrix is quadratic
ierr = MatGetSize(A, &M, &N);CHKERRQ(ierr);
ierr = MatGetLocalSize(A, &m, &n);CHKERRQ(ierr);
if (M != N){
//Macro that is called when an error has been detected.
SETERRQ2(PETSC_COMM_SELF, PETSC_ERR_ARG_SIZ, "Detected a
rectangular matrix: (%d, %d)", M, N);
ierr = MatGetOwnershipRange(A,&rstart,&rend);CHKERRQ(ierr);
ierr = PetscPrintf(PETSC_COMM_WORLD, "---------------\n");CHKERRQ(ierr);
ierr = PetscSynchronizedPrintf(PETSC_COMM_WORLD, "Ownership ranges for
Matrix A, rank: %i, size: %i, rstart: %i, rend: %i \n", rank, size,
rstart, rend);CHKERRQ(ierr);
ierr = PetscSynchronizedFlush(PETSC_COMM_WORLD,
PETSC_STDOUT);CHKERRQ(ierr);
// Set the number of columns of the inverse to be computed.
nrhs = N;
ierr = PetscOptionsGetInt(NULL, NULL, "-nrhs", &nrhs,
&flg2);CHKERRQ(ierr);
// Create SpRHST for inv(A) with sparse RHS stored in the host.
// PETSc does not support compressed column format which is required by
MUMPS for sparse RHS matrix,
// thus user must create spRHST=spRHS^T and call MatMatTransposeSolve()
// User must create B^T in sparse compressed row format on the host
processor and call MatMatTransposeSolve() to implement MUMPS' MatMatSolve().
// MUMPS requires nrhs = N
ierr = MatCreate(PETSC_COMM_WORLD, &spRHST);CHKERRQ(ierr);
if (!rank){
ierr =
MatSetSizes(spRHST,N,M,PETSC_DECIDE,PETSC_DECIDE);CHKERRQ(ierr);
else{
ierr =
MatSetSizes(spRHST,0,0,PETSC_DECIDE,PETSC_DECIDE);CHKERRQ(ierr);
ierr = MatSetType(spRHST,MATAIJ);CHKERRQ(ierr);
ierr = MatSetFromOptions(spRHST);CHKERRQ(ierr);
ierr = MatSetUp(spRHST);CHKERRQ(ierr);
if (!rank){
v = 1.0;
for(i=0;i<nrhs;i++){
ierr =
MatSetValues(spRHST,1,&i,1,&i,&v,INSERT_VALUES);CHKERRQ(ierr);
ierr = MatAssemblyBegin(spRHST,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
ierr = MatAssemblyEnd(spRHST, MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
// Print matrix spRHST
if (displ){
ierr = PetscPrintf(PETSC_COMM_WORLD,"Matrix spRHST:\n", nrhs);
ierr = MatView(spRHST, PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
// Print information
ierr = PetscPrintf(PETSC_COMM_WORLD, "\nCompute %i columns of the
inverse using LU-factorization in MUMPS!\n", nrhs);
// Factorize the Matrix using a parallel LU factorization in MUMPS
ierr = MatGetFactor(A, MATSOLVERMUMPS, MAT_FACTOR_LU, &F);CHKERRQ(ierr);
ierr = MatLUFactorSymbolic(F, A, NULL, NULL, NULL);CHKERRQ(ierr);
ierr = MatLUFactorNumeric(F, A, NULL);CHKERRQ(ierr);
// Create spRHS
Mat spRHS = NULL;
// Create spRHS = spRHS^T. Two matrices that share internal matrix data
structure.
// Creates a new matrix object that behaves like A'.
ierr = MatCreateTranspose(spRHST,&spRHS);CHKERRQ(ierr);
// Get user-specified set of entries in inverse of A
ierr = MatMumpsGetInverse(F,spRHS);CHKERRQ(ierr);
if (displ){
ierr = PetscPrintf(PETSC_COMM_WORLD,"First %D columns of inv(A)
with sparse RHS:\n", nrhs);
ierr = MatView(spRHS,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
// Free data structures
ierr = MatDestroy(&A);CHKERRQ(ierr);
ierr = MatDestroy(&spRHS);CHKERRQ(ierr);
ierr = MatDestroy(&spRHST);CHKERRQ(ierr);
return ierr;
#endif
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191216/375646c5/attachment.html>
