[petsc-users] Memory optimization
Perceval Desforges perceval.desforges at polytechnique.edu
Tue Dec 10 11:36:04 CST 2019
Hello again,
I have tried following your advice to use preconditioned iterative
solvers for my 3D systems, and have been encountering some difficulties.
I have been following the recommendations of section 3.4.1 of the slepc
user's manual, setting the following options:  -st_ksp_type gmres
-ksp_gmres_modifiedgramschmidt -st_pc_type asm -st_sub_pc_type lu
-st_ksp_rtol 1e-9 -st_ksp_converged_reason
-st_ksp_monitor_true_residual.
The problem is that the code converges quite rapidly for the first
eigenvalues (at around 0.4 in my case, and in about 20 iterations for
each). The last eigenvalue obtained is a bit higher than 0,5. However,
when I set the shift to 0.5, it does not converge even after 10000
iterations, and the residual norm is still at around 0,01.
This only seems to be happening when my matrix is large enough (10^6 by
10^6).
Is there something obvious I am doing wrong?
Thanks for your time,
Perceval,
> In 3D problems it is recommended to use preconditioned iterative solvers. Unfortunately the spectrum slicing technique requires the full factorization (because it uses matrix inertia).
> El 25 nov 2019, a las 18:44, Perceval Desforges <perceval.desforges at polytechnique.edu> escribió:
> I am basically trying to solve a finite element problem, which is why in 3D I have 7 non-zero diagonals that are quite farm apart from one another. In 2D I only have 5 non-zero diagonals that are less far apart. So is it normal that the set up time is around 400 times greater in the 3D case? Is there nothing to be done?
> I will try setting up only one partition.
> Thanks,
> Perceval,
> Probably it is not a preallocation issue, as it shows "total number of mallocs used during MatSetValues calls =0".
> Adding new diagonals may increase fill-in a lot, if the new diagonals are displaced with respect to the other ones.
> The partitions option is intended for running several nodes. If you are using just one node probably it is better to set one partition only.
> Jose
> El 25 nov 2019, a las 18:25, Matthew Knepley <knepley at gmail.com> escribió:
> On Mon, Nov 25, 2019 at 11:20 AM Perceval Desforges <perceval.desforges at polytechnique.edu> wrote:
> Hi,
> So I'm loading two matrices from files, both 1000000 by 10000000. I ran the program with -mat_view::ascii_info and I got:
> Mat Object: 1 MPI processes
> type: seqaij
> rows=1000000, cols=1000000
> total: nonzeros=7000000, allocated nonzeros=7000000
> not using I-node routines
> 20 times, and then
> type: seqaij
> total: nonzeros=1000000, allocated nonzeros=1000000
> 20 times as well, and then
> type: seqaij
> 20 times as well before crashing.
> I realized it might be because I am setting up 20 krylov schur partitions which may be too much. I tried running the code again with only 2 partitions and now the code runs but I have speed issues.
> I have one version of the code where my first matrix has 5 non-zero diagonals (so 5000000 non-zero entries), and the set up time is quite fast (8 seconds)  and solving is also quite fast. The second version is the same but I have two extra non-zero diagonals (7000000 non-zero entries)  and the set up time is a lot slower (2900 seconds ~ 50 minutes) and solving is also a lot slower. Is it normal that adding two extra diagonals increases solve and set up time so much?
> I can't see the rest of your code, but I am guessing your preallocation statement has "5", so it does no mallocs when you create
> your first matrix, but mallocs for every row when you create your second matrix. When you load them from disk, we do all the
> preallocation correctly.
> Thanks,
> Matt
> Thanks again,
> Best regards,
> Perceval,
> Then I guess it is the factorization that is failing. How many nonzero entries do you have? Run with
> -mat_view ::ascii_info
> Jose
> El 22 nov 2019, a las 19:56, Perceval Desforges <perceval.desforges at polytechnique.edu> escribió:
> Hi,
> Thanks for your answer. I tried looking at the inertias before solving, but the problem is that the program crashes when I call EPSSetUp with this error:
> slurmstepd: error: Step 2140.0 exceeded virtual memory limit (313526508 > 107317760), being killed
> I get this error even when there are no eigenvalues in the interval.
> I've started using BVMAT instead of BVVECS by the way.
> Thanks,
> Perceval,
> Don't use -mat_mumps_icntl_14 to reduce the memory used by MUMPS.
> Most likely the problem is that the interval you gave is too large and contains too many eigenvalues (SLEPc needs to allocate at least one vector per each eigenvalue). You can count the eigenvalues in the interval with the inertias, which are available at EPSSetUp (no need to call EPSSolve). See this example:
> http://slepc.upv.es/documentation/current/src/eps/examples/tutorials/ex25.c.html
> You can comment out the call to EPSSolve() and run with the option -show_inertias
> For example, the output
> Shift 0.1  Inertia 3
> Shift 0.35  Inertia 11
> means that the interval [0.1,0.35] contains 8 eigenvalues (=11-3).
> By the way, I would suggest using BVMAT instead of BVVECS (the latter is slower).
> Jose
> El 21 nov 2019, a las 18:13, Perceval Desforges via petsc-users <petsc-users at mcs.anl.gov> escribió:
> Hello all,
> I am trying to obtain all the eigenvalues in a certain interval for a fairly large matrix (1000000 * 1000000). I therefore use the spectrum slicing method detailed in section 3.4.5 of the manual. The calculations are run on a processor with 20 cores and 96 Go of RAM.
> The options I use are :
> -bv_type vecs  -eps_krylovschur_detect_zeros 1 -mat_mumps_icntl_13 1 -mat_mumps_icntl_24 1 -mat_mumps_cntl_3 1e-12
> However the program quickly crashes with this error:
> slurmstepd: error: Step 2115.0 exceeded virtual memory limit (312121084 > 107317760), being killed
> I've tried reducing the amount of memory used by slepc with the -mat_mumps_icntl_14 option by setting it at -70 for example but then I get this error:
> [1]PETSC ERROR: Error in external library
> [1]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: INFOG(1)=-9, INFO(2)=82733614
> which is an error due to setting the mumps icntl option so low from what I've gathered.
> Is there any other way I can reduce memory usage?
> Thanks,
> Regards,
> Perceval,
> P.S. I sent the same email a few minutes ago but I think I made a mistake in the address, I'm sorry if I've sent it twice.
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191210/8f9e8c2a/attachment.html>
