[petsc-users] petsc under cygwin
Balay, Satish balay at mcs.anl.gov
Fri Dec 6 08:04:14 CST 2019
Its likely my cygwin is slightly old [as its not updated in the past few months].
balay at ps5 ~/petsc
$ cygcheck.exe -f /usr/bin/mpicxx
openmpi-3.1.3-1
Satish
On Fri, 6 Dec 2019, Balay, Satish wrote:
> Are you sure this is cygwin from OpenMPI? I don't see it refer to -lmpi_cxx
> $ which mpicxx
> /usr/bin/mpicxx
> $ mpicxx -show
> g++ -L/usr/lib -lmpi -lopen-rte -lopen-pal -lm -lgdi32 -lz
> Here is what I get with cygwin/openmpi,lapack,blas
> Satish
> $ ./configure --with-scalar-type=real --with-x=0 --with-hdf5 --download-hdf5=1 --with-single-library=1 --with-shared-libraries=0 --with-log=0 --with-clanguage=C++ --with-cxx-d
> ialect=C++11 --CXXFLAGS="-fopenmp -fPIC" --CFLAGS="-fopenmp -fPIC" --with-fortran=0 --FFLAGS="-fopenmp -fPIC" --with-64-bit-indices=0 --with-debugging=0 --with-cc=mpicc --with
> -fc=mpif77 --with-cxx=mpicxx COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 --with-fortran-kernels=0
>              Configuring PETSc to compile on your system
> ===============================================================================        WARNING -with-clanguage=C++ is a developer feature and is *not* required for regular usage of PETSc either from C or C++                                                  ===============================================================================        ===============================================================================        Trying to download git://https://bitbucket.org/petsc/pkg-sowing.git for SOWING        ===============================================================================        ===============================================================================        Running configure on SOWING; this may take several minutes        ===============================================================================        ===============================================================================        Running make on SOWING; this may take several minutes        ===============================================================================        ===============================================================================        Running make install on SOWING; this may take several minutes        ===============================================================================        ===============================================================================        Trying to download https://support.hdfgroup.org/ftp/HDF5/releases/hdf5-1.10/hdf5-1.10.5/src/hdf5-1.10.5.tar.gz for HDF5                                                   ===============================================================================        ===============================================================================        Running configure on HDF5; this may take several minutes        ===============================================================================        ===============================================================================        Running make on HDF5; this may take several minutes        ===============================================================================        ===============================================================================        Running make install on HDF5; this may take several minutes        ===============================================================================        Compilers:
>   C Compiler:         mpicc -fopenmp -fPIC -O3
>     Version: gcc (GCC) 7.4.0
>   C++ Compiler:       mpicxx -fopenmp -fPIC -O3
>     Version: g++ (GCC) 7.4.0
>   Fortran Compiler:   mpif77 -fopenmp -fPIC -O3
>     Version: GNU Fortran (GCC) 7.4.0
> Linkers:
>   Static linker:   /usr/bin/ar cr
>   Dynamic linker:   /usr/bin/ar
>   Libraries linked against:   -lgdi32 -luser32 -ladvapi32 -lkernel32 -lquadmath -lstdc++ -ldl
> make:
>   Version:  4.2
>   /usr/bin/make
> BlasLapack:
>   Library:  -llapack -lblas
>   uses 4 byte integers
> MPI:
>   Version:  3
>   Mpiexec: mpiexec --oversubscribe
>   OMPI_VERSION: 3.1.3
> pthread:
> hdf5:
>   Version:  1.10.5
>   Includes: -I/home/balay/petsc/arch-mswin-cxx-opt/include
>   Library:  -Wl,-rpath,/home/balay/petsc/arch-mswin-cxx-opt/lib -L/home/balay/petsc/arch-mswin-cxx-opt/lib -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5
> cmake:
>   Version:  3.14.5
>   /usr/bin/cmake
> sowing:
>   Version:  1.1.25
>   /home/balay/petsc/arch-mswin-cxx-opt/bin/bfort
>   Language used to compile PETSc: Cxx
> PETSc:
>   PETSC_ARCH: arch-mswin-cxx-opt
>   PETSC_DIR: /home/balay/petsc
>   Scalar type: real
>   Precision: double
>   Support for __float128
>   Integer size: 4 bytes
>   shared libraries: disabled
>   Memory alignment from malloc(): 16 bytes
> xxx=========================================================================xxx
>  Configure stage complete. Now build PETSc libraries with:
>    make PETSC_DIR=/home/balay/petsc PETSC_ARCH=arch-mswin-cxx-opt all
> On Fri, 6 Dec 2019, Povolotskyi, Mykhailo wrote:
> > I checked:
> > I cannot build C++ programs with MPI, but I can build and run C programs
> > with MPI.
> > I have -with-log=0 because there is an overhead if many small objects
> > are created, which is my case.
> > As for the fortran, I will remove  --with-fortran=0
> > On 12/5/2019 11:53 PM, Smith, Barry F. wrote:
> > >    Can you actually build and run C++ programs with the MPI?
> > > Executing: mpicxx  -o /tmp/petsc-Llvze6/config.setCompilers/conftest.exe   -fopenmp -fPIC /tmp/petsc-Llvze6/config.setCompilers/conftest.o
> > > Possible ERROR while running linker: exit code 1
> > > stderr:
> > > /usr/lib/gcc/x86_64-pc-cygwin/7.4.0/../../../../x86_64-pc-cygwin/bin/ld: cannot find -lmpi_cxx
> > > collect2: error: ld returned 1 exit status
> > >            Error testing C++ compiler: Cannot compile/link Cxx with mpicxx.
> > >              MPI installation mpicxx is likely incorrect.
> > >    Use --with-mpi-dir to indicate an alternate MPI.
> > > Also you have  --with-fortran=0
> > > but --download-fblaslapack  and FOPTFLAGS=-O3
> > > and why do you have --with-log=0   it costs no overhead if you do not use it and is always useful for tracking performance.
> > >    Barry
> > >> On Dec 5, 2019, at 9:19 PM, Povolotskyi, Mykhailo <mpovolot at purdue.edu> wrote:
> > >> Dear Petsc support team,
> > >> for some reasons I have to build petsc under Windows.
> > >> I have installed Cygwin with GNU compilers and OpenMPI.
> > >> Unfortunately, the configuration fails with the following message:
> > >> TESTING: checkCxxCompiler from
> > >> config.setCompilers(config/BuildSystem/config/setCompilers.py:814)
> > >>           UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
> > >> for details):
> > >> C++ compiler you provided with -with-cxx=mpicxx does not work.
> > >> I'm attaching the *.log file.
> > >> Please advise,
> > >> Michael.
> > >> <configure.log>
