[petsc-users] CMake error in PETSc
Jed Brown jed at jedbrown.org
Thu Dec 5 08:23:23 CST 2019
Yingjie Wu <yjwu16 at gmail.com> writes:
> I'm so sorry that I've ignored your previous advices.
> I added a global variable that seems works:
> export
> LD_LIBRARY_PATH=/home/lerui/petcs-3.12.2/arch-linux2-c-debug/lib:$LD_LIBRARY_PATH
> How should I make petsc in a standard position?This eliminates the need to
> set global variables.
You can configure PETSc with --prefix=/your/standard/path, then make install.
> It seems that some of the options before running fit become unavailable:
> mpiexec -n 1 ./example01cmke -snes_view
> Options-snes _ view are not used and how should I solve this problem?
I don't have your ex1.cpp, but presumably you didn't SNESSetFromOptions?
