[petsc-users] CMake error in PETSc
Yingjie Wu
yjwu16 at gmail.com
Wed Dec 4 09:14:17 CST 2019
Dear Petsc developers
Because I use some external library files, I want to compile the PETSc
program with CMake. I follow the library search program
https://github.com/CoolProp/CoolProp/blob/b493de51a44078e4f5bbb8712e89305fd91f8b85/CMakeLists.txt
recommended
on GitHub. And wrote a cmakelist.txt:
cmake_minimum_required(VERSION 2.8.11)
project(example01cmke)
add_executable(example01cmke ex1.cpp)
set(CMAKE_MODULE_PATH ${PROJECT_SOURCE_DIR}/cmake/modules)
find_package(PETSc)
include_directories(${PETSC_INCLUDE_DIR})
target_link_libraries(example01cmke ${PETSC_LIBRARIES})
My document relationships are:
yjwu at yjwu-XPS-8910:~/PETSctest/Testcmake$ tree
├── build
├── cmake
│ └── modules
│ ├── CorrectWindowsPaths.cmake
│ ├── FindFFTW.cmake
│ ├── FindGit.cmake
│ ├── FindGSL.cmake
│ ├── FindITAPS.cmake
│ ├── FindNetCDF.cmake
│ ├── FindPackageMultipass.cmake
│ ├── FindPETSc.cmake
│ ├── LICENSE
│ ├── README
│ └── ResolveCompilerPaths.cmake
├── CMakeLists.txt
└── ex1.cpp
After compiling with cmake.. and make, there is an error message:
yjwu at yjwu-XPS-8910:~/PETSctest/Testcmake/build$ cmake ..
-- The C compiler identification is GNU 5.4.0
-- The CXX compiler identification is GNU 5.4.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- petsc_lib_dir /home/yjwu/petsc-3.10.1/arch-linux2-c-debug/lib
-- Recognized PETSc install with single library for all packages
-- Performing Test MULTIPASS_TEST_1_petsc_works_minimal
-- Performing Test MULTIPASS_TEST_1_petsc_works_minimal - Success
-- Minimal PETSc includes and libraries work. This probably means we are
building with shared libs.
-- Found PETSc:
/home/yjwu/petsc-3.10.1/arch-linux2-c-debug/include;/home/yjwu/petsc-3.10.1/include
(found version "3.10.1")
-- Configuring done
-- Generating done
-- Build files have been written to: /home/yjwu/PETSctest/Testcmake/build
yjwu at yjwu-XPS-8910:~/PETSctest/Testcmake/build$ make
Scanning dependencies of target example01cmke
[ 50%] Building CXX object CMakeFiles/example01cmke.dir/ex1.cpp.o
In file included from /home/yjwu/petsc-3.10.1/include/petscis.h:7:0,
from /home/yjwu/petsc-3.10.1/include/petscvec.h:9,
from /home/yjwu/petsc-3.10.1/include/petscmat.h:6,
from /home/yjwu/petsc-3.10.1/include/petscpc.h:6,
from /home/yjwu/petsc-3.10.1/include/petscksp.h:6,
from /home/yjwu/petsc-3.10.1/include/petscsnes.h:6,
from /home/yjwu/PETSctest/Testcmake/ex1.cpp:29:
/home/yjwu/petsc-3.10.1/include/petscsys.h:14:23: fatal error: petscconf.h:
No such file or directory
compilation terminated.
CMakeFiles/example01cmke.dir/build.make:62: recipe for target
'CMakeFiles/example01cmke.dir/ex1.cpp.o' failed
make[2]: *** [CMakeFiles/example01cmke.dir/ex1.cpp.o] Error 1
CMakeFiles/Makefile2:67: recipe for target
'CMakeFiles/example01cmke.dir/all' failed
make[1]: *** [CMakeFiles/example01cmke.dir/all] Error 2
Makefile:83: recipe for target 'all' failed
make: *** [all] Error 2
I don't know how to solve this problem,ex1.cpp is the first example in SNES
tutorial, please give me some advice.
Best regards,
Yingjie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191204/87715466/attachment.html>
