[petsc-users] (no subject)
    Li Luo
    li.luo at kaust.edu.sa
    Wed Dec  4 01:56:38 CST 2019
Thank you, I'll try that.
Best,
Li
On Wed, Dec 4, 2019 at 5:34 AM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   From the code:
>   if (snes->lagjacobian == -2) {
>     snes->lagjacobian = -1;
>     ierr = PetscInfo(snes,"Recomputing Jacobian/preconditioner because lag
> is -2 (means compute Jacobian, but then never again) \n");CHKERRQ(ierr);
>   } else if (snes->lagjacobian == -1) {
>     ierr = PetscInfo(snes,"Reusing Jacobian/preconditioner because lag is
> -1\n");CHKERRQ(ierr);
>     ierr =
> PetscObjectTypeCompare((PetscObject)A,MATMFFD,&flag);CHKERRQ(ierr);
>     if (flag) {
>       ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>       ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>     PetscFunctionReturn(0);
>  So it does what the manual page says. If you use -2 it will compute the
> Jacobian the next time it is needed but then will never compute it again,.
> This means it reuses the one computed for all time-steps. It can make sense
> depending on how much the Jacobian changes to use with -snes_mf_operator.
>  To compute just once at the beginning of each new linear solver you can
> use for example 100 (this assumes that one nonlinear solver never needs
> more than 100 linear solvers.) This can also be used with -snes_mf_operator
> (or without).
>   Barry
> > On Dec 3, 2019, at 6:33 AM, Li Luo <li.luo at kaust.edu.sa> wrote:
> > If use -snes_mf,  the linear solver just never converges. And at the
> second time step, it reports an error as:
> > [0]PETSC ERROR: No support for this operation for this object type!
> > [0]PETSC ERROR: Mat type mffd!
> > I still don't understand "-snes_lag_jacobian -2", from the manual, it
> seems Jacobian is computed only once by setting -1, but it is recomputed
> once by -2.
> > For a time-stepping scheme where each step calls SNESSolve, if using
> -snes_lag_jacobian -2, will the following time steps reuse the Jacobian
> built at the first time step?
> > Best,
> > Li
> > On Tue, Dec 3, 2019 at 12:10 AM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> > > On Dec 2, 2019, at 2:30 PM, Li Luo <li.luo at kaust.edu.sa> wrote:
> > >  -snes_mf  fails to converge in my case, but  -ds_snes_mf_operator
> works, when the original analytic matrix is still used as the
> preconditioner.
> > > The timing is several times greater than using the analytic matrix for
> both Jacobian and preconditioner.
> >    ok, how does -snes_mf fail to converge? -ksp_monitor  ? does the
> linear solver just never converge?
> >    Using -snes_mf_operator will also build the Jacobian so in your case
> doesn't make much sense by itself since it is very expensive
> > > For an implicit time-stepping scheme, if using -snes_lag_jacobian -2,
> is the Jacobian built only twice at the first time step then it is used for
> all later time steps? Or it is built twice at every time step?
> >    Check the manual page for SNESSolve it should just compute the
> Jacobian once and reuse it forever.
> >    You can also try -snes_mf  -snes_lag_jacobian -2 which should compute
> the Jacobian once, use that original one to build the preconditioner once
> and reuse the same preconditioner but use the matrix free to define the
> operator.
> >    Barry
> > > Regards,
> > > Li
> > > On Mon, Dec 2, 2019 at 6:02 PM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> > > Ok it is spending 99+ percent of the time computing the Jacobians.
> > > MatFDColorApply      106 1.0 8.7622e+03 1.0 1.31e+08 1.1 6.9e+07
> 2.6e+03 1.1e+06 99  0 97 81 99  99  0 97 81 99     1
> > > MatFDColorFunc     60950 1.0 8.7560e+03 1.0 0.00e+00 0.0 6.9e+07
> 2.6e+03 1.1e+06 99  0 97 81 99  99  0 97 81 99     0
> > > It is requiring on average 12 KSP iterations per linear solve so the
> resulting linear system appears well conditioned, this means even if you
> compute the Jacobian analytically likely most of the time in the run will
> still be computing Jacobians.
> > > Try using -snes_mf with the logging and see what happens.   You can
> also try -snes_lag_jacobian_persists -snes_lag_jacobian -2
> > > Note there may be other ways of avoiding the costly computation of the
> Jacobian at each Newton step.
> > > Barry
> > > > On Dec 2, 2019, at 6:38 AM, Li Luo <li.luo at kaust.edu.sa> wrote:
> > > > Dear Barry,
> > > > Here is my log.
> > > > Because I am using libMesh built on PETSc, there is more information
> from libMesh in the log file.
> > > > I ran 13 time steps for the simulation so there are repeated
> snes_view info.
> > > > The algorithm is simply NKS.
> > > > Cheers,
> > > > Li
> > > > On Mon, Dec 2, 2019 at 4:55 PM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> > > >   Please send a run with optimization turned on (--with-debugging=0
> in ./configure) and -log_view  without the actual timing information we are
> just guessing where the time is spent.
> > > >   If your problem has a natural block size then using baij should be
> a bit faster than aij, but not dramatically better
> > > >    Barry
> > > > > On Dec 2, 2019, at 4:30 AM, Li Luo <li.luo at kaust.edu.sa> wrote:
> > > > > Thank you very much! It looks forming an analytic Jacobian is the
> only choice.
> > > > > Best,
> > > > > Li
> > > > > On Mon, Dec 2, 2019 at 3:21 PM Matthew Knepley <knepley at gmail.com>
> wrote:
> > > > > On Mon, Dec 2, 2019 at 4:04 AM Li Luo <li.luo at kaust.edu.sa> wrote:
> > > > > Thank you for your reply.
> > > > > The matrix is small with only 67500 rows, but is relatively dense
> since a second-order discontinuous Galerkin FEM is used,
> nonzeros=23,036,400.
> > > > > This is very dense, 0.5% fill or 340 nonzeros per row.
> > > > > The number of colors is 539 as shown by using
> -mat_fd_coloring_view:
> > > > > Coloring is not appropriate for this matrix since you have
> enormous dense blocks (I am guessing). It could work if you statically
> > > > > condense them out or had a fast analytic Jacobian. With 540
> colors, it takes 540 matvecs to generate the action of the Jacobian.
> > > > >   Thanks,
> > > > >      Matt
> > > > > MatFDColoring Object: 64 MPI processes
> > > > >   type not yet set
> > > > >   Error tolerance=1.49012e-08
> > > > >   Umin=1.49012e-06
> > > > >   Number of colors=539
> > > > >   Information for color 0
> > > > >     Number of columns 1
> > > > >       378
> > > > >     Number of rows 756
> > > > >       0 1188
> > > > >       1 1188
> > > > >       2 1188
> > > > >       3 1188
> > > > >       4 1188
> > > > >       5 1188
> > > > > Is this normal?
> > > > > When using MCFD, is there any difference using mpiaij and mpibaij?
> > > > > Best,
> > > > > Li
> > > > > On Mon, Dec 2, 2019 at 10:03 AM Smith, Barry F. <
> > > > >   How many colors is it requiring?   And how long is the
> MatGetColoring() taking? Are you running in parallel?  The MatGetColoring()
> MATCOLORINGSL uses a sequential coloring algorithm so if your matrix is
> large and parallel the coloring will take a long time. The parallel
> colorings are MATCOLORINGGREEDY and MATCOLORINGJP
> > > > >   Barry
> > > > > > On Dec 1, 2019, at 12:56 AM, Li Luo <li.luo at kaust.edu.sa> wrote:
> > > > > > Dear Developers,
> > > > > > I tried to use the multi-color finite-difference (MC-FD) method
> for constructing the Jacobians. However, I find it is very slow compared to
> the exact Jacobian.
> > > > > > My implementation of MC-FD Jacobian is posted below, would you
> please check whether I am correct? Anything missed? Thank you!
> > > > > > ////////// Setup phase:
> > > > > >           MatStructure flag;
> > > > > >           ISColoring   iscoloring;
> > > > > >           ierr = MatGetColoring(Jac,MATCOLORINGSL,&iscoloring);
> > > > > >           ierr =
> MatFDColoringCreate(Jac,iscoloring,&this->matfdcoloring);
> > > > > >           ierr =
> MatFDColoringSetFunction(this->matfdcoloring,(PetscErrorCode
> (*)(void))__libmesh_petsc_snes_residual,(void *)this);
> > > > > >           ierr =
> MatFDColoringSetFromOptions(this->matfdcoloring);
> > > > > >           ierr = ISColoringDestroy(&iscoloring);
> > > > > > //////////// Apply:
> > > > > >           ierr = MatZeroEntries(*jac);CHKERRQ(ierr);
> > > > > >           ierr =
> MatFDColoringApply(*jac,solver->matfdcoloring,x,msflag,snes);
> > > > > > Best regards,
> > > > > > Li Luo
> > > > > > This message and its contents, including attachments are
> intended solely for the original recipient. If you are not the intended
> recipient or have received this message in error, please notify me
> immediately and delete this message from your computer system. Any
> unauthorized use or distribution is prohibited. Please consider the
> environment before printing this email.
> > > > > Postdoctoral Fellow
> > > > > Extreme Computing Research Center
> > > > > King Abdullah University of Science & Technology
> > > > > https://sites.google.com/site/rolyliluo/
> > > > > This message and its contents, including attachments are intended
> solely for the original recipient. If you are not the intended recipient or
> have received this message in error, please notify me immediately and
> delete this message from your computer system. Any unauthorized use or
> distribution is prohibited. Please consider the environment before printing
> this email.
> > > > > What most experimenters take for granted before they begin their
> experiments lead.
> > > > > -- Norbert Wiener
> > > > > https://www.cse.buffalo.edu/~knepley/
> > > > > Postdoctoral Fellow
> this email.
> > > > Postdoctoral Fellow
> this email.<slurm-13575838.out>
> > > Postdoctoral Fellow
> this email.
> > Postdoctoral Fellow
> > This message and its contents, including attachments are intended solely
> for the original recipient. If you are not the intended recipient or have
> received this message in error, please notify me immediately and delete
> this email.
Postdoctoral Fellow
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191204/97b77c2f/attachment-0001.html>
