[petsc-users] question about CISS
Povolotskyi, Mykhailo mpovolot at purdue.edu
Thu Aug 29 13:56:12 CDT 2019
Hello everyone,
this is a question about  SLEPc.
The problem that I need to solve is as follows.
I have a matrix and I need a full spectrum of it (both eigenvalues and
eigenvectors).
The regular way is to use Lapack, but it is slow. I decided to try the
following:
a) compute the bounds of the spectrum using Krylov Schur approach.
b) divide the complex eigenvalue plane into rectangular areas, then
apply CISS to each area in parallel.
However, I found that the solver is missing some eigenvalues, even if my
rectangles cover the whole spectral area.
My question: can this approach work in principle? If yes, how one can
set-up CISS solver to not loose the eigenvalues?
Thank you,
Michael.
