[petsc-users] errors when using elemental with petsc3.10.5
Smith, Barry F.
bsmith at mcs.anl.gov
Thu Aug 22 19:03:58 CDT 2019
> On Aug 22, 2019, at 6:48 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
> Compilers are supposed to prefer libraries in specified -L path before system stuff.
Suppose to.
> balay at es^~ $ ls /usr/lib/lib*metis*
> /usr/lib/libmetis.a /usr/lib/libmetis.so.3.1 /usr/lib/libparmetis.so@ /usr/lib/libscotchmetis-5.1.so /usr/lib/libscotchmetis.so@
> /usr/lib/libmetis.so@ /usr/lib/libparmetis.a /usr/lib/libparmetis.so.3.1 /usr/lib/libscotchmetis.a
> balay at es^~ $
This is really bad system management, there is no reason for them to be there nor should they be there.
bsmith at es:~$ ldd /usr/lib/libparmetis.so.3.1
linux-vdso.so.1 => (0x00007fff9115e000)
libmpi.so.1 => /usr/lib/libmpi.so.1 (0x00007faf95f87000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007faf95c81000)
libmetis.so.3.1 => /usr/lib/libmetis.so.3.1 (0x00007faf95a34000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007faf9566b000)
libutil.so.1 => /lib/x86_64-linux-gnu/libutil.so.1 (0x00007faf95468000)
libhwloc.so.5 => /usr/lib/x86_64-linux-gnu/libhwloc.so.5 (0x00007faf95228000)
libltdl.so.7 => /usr/lib/x86_64-linux-gnu/libltdl.so.7 (0x00007faf9501e000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007faf94e00000)
/lib64/ld-linux-x86-64.so.2 (0x00007faf9654e000)
libnuma.so.1 => /soft/com/packages/pgi/19.3/linux86-64/19.3/lib/libnuma.so.1 (0x00007faf94bf5000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007faf949f1000)
You have something in /usr/lib referring to something in /soft/com/packages/pgi/ ??
and of course that refers back to
bsmith at es:~$ ls -l /soft/com/packages/pgi/19.3/linux86-64/19.3/lib/libnuma.so.1
lrwxrwxrwx 1 fritz voice 38 Mar 29 15:59 /soft/com/packages/pgi/19.3/linux86-64/19.3/lib/libnuma.so.1 -> /usr/lib/x86_64-linux-gnu/libnuma.so.1
I stand by my statement, it is bad policy to put any stuff like this in system directories.
> And we have these files installed and they don't cause problems. And its not always practical to uninstall system stuff
> [esp on multi-user machines]
I agree it is not always practical or possible to remove them.
barry
> Satish
> On Thu, 22 Aug 2019, Smith, Barry F. wrote:
>> You have a copy of parmetis installed in /usr/lib this is a systems directory and many compilers and linkers automatically find libraries in that location and it is often difficult to avoid have the compilers/linkers use these. In general you never want to install external software such as parmetis, PETSc, MPI, etc in systems directories (/usr/ and /usr/local)
>> You should delete this library (and the includes in /usr/include)
>> Barry
>>> On Aug 22, 2019, at 5:17 PM, Balay, Satish via petsc-users <petsc-users at mcs.anl.gov> wrote:
>>>> ./ex19: symbol lookup error: /usr/lib/libparmetis.so: undefined symbol: ompi_mpi_comm_world
>>> For some reason the wrong parmetis library is getting picked up. I don't know why.
>>> Can you copy/paste the log from the following?
>>> cd src/snes/examples/tutorials
>>> make PETSC_DIR=/home/lailai/nonroot/petsc/petsc3.11.3_intel19_mpich3.3 ex19
>>> ldd ex19
>>> cd /home/lailai/nonroot/petsc/petsc3.11.3_intel19_mpich3.3/pet3.11.3-intel19-mpich3.3/lib
>>> ldd *.so
>>> Satish
>>> On Thu, 22 Aug 2019, Lailai Zhu via petsc-users wrote:
>>>> hi, Satish,
>>>> as you have suggested, i compiled a new version using 3.11.3,
>>>> it compiles well, the errors occur in checking. i also attach
>>>> the errors of check. thanks very much,
>>>> lailai
>>>> On 8/22/19 4:16 PM, Balay, Satish wrote:
>>>>> Any reason for using petsc-3.10.5 and not latest petsc-3.11?
>>>>> I suggest starting from scatch and rebuilding.
>>>>> And if you still have issues - send corresponding configure.log and make.log
>>>>> Satish
>>>>>> sorry, Satish,
>>>>>> but it does not seem to solve the problem.
>>>>>> best,
>>>>>> lailai
>>>>>> On 8/22/19 12:41 AM, Balay, Satish wrote:
>>>>>>> Can you run 'make' again and see if this error goes away?
>>>>>>> Satish
>>>>>>> On Wed, 21 Aug 2019, Lailai Zhu via petsc-users wrote:
>>>>>>>> hi, Satish,
>>>>>>>> i tried to do it following your suggestion, i get the following errors
>>>>>>>> when
>>>>>>>> installing.
>>>>>>>> here is my configuration,
>>>>>>>> any ideas?
>>>>>>>> best,
>>>>>>>> lailai
>>>>>>>> ./config/configure.py --with-c++-support --known-mpi-shared-libraries=1
>>>>>>>> --with-batch=0 --with-mpi=1 --with-debugging=0 CXXOPTFLAGS="-g -O3"
>>>>>>>> COPTFLAGS="-O3 -ip -axCORE-AVX2 -xSSE4.2" FOPTFLAGS="-O3 -ip -axCORE-AVX2
>>>>>>>> -xSSE4.2" --with-blas-lapack-dir=/opt/intel/mkl --download-elemental=1
>>>>>>>> --download-blacs=1 --download-scalapack=1 --download-hypre=1
>>>>>>>> --download-plapack=1 --with-cc=mpicc --with-cxx=mpic++ --with-fc=mpifort
>>>>>>>> --download-amd=1 --download-anamod=1 --download-blopex=1
>>>>>>>> --download-dscpack=1 --download-sprng=1 --download-superlu=1
>>>>>>>> --with-cxx-dialect=C++11 --download-metis --download-parmetis
>>>>>>>> pet3.10.5-intel19-mpich3.3/obj/mat/impls/sbaij/seq/sbaij.o: In function
>>>>>>>> `MatCreate_SeqSBAIJ':
>>>>>>>> sbaij.c:(.text+0x1bc45): undefined reference to
>>>>>>>> `MatConvert_SeqSBAIJ_Elemental'
>>>>>>>> ld: pet3.10.5-intel19-mpich3.3/obj/mat/impls/sbaij/seq/sbaij.o:
>>>>>>>> relocation
>>>>>>>> R_X86_64_PC32 against undefined hidden symbol
>>>>>>>> can not be used when making a shared object
>>>>>>>> ld: final link failed: Bad value
>>>>>>>> gmakefile:86: recipe for target
>>>>>>>> 'pet3.10.5-intel19-mpich3.3/lib/libpetsc.so.3.10.5' failed
>>>>>>>> make[2]: *** [pet3.10.5-intel19-mpich3.3/lib/libpetsc.so.3.10.5] Error 1
>>>>>>>> make[2]: Leaving directory
>>>>>>>> '/usr/nonroot/petsc/petsc3.10.5_intel19_mpich3.3'
>>>>>>>> ........................../petsc3.10.5_intel19_mpich3.3/lib/petsc/conf/rules:81:
>>>>>>>> recipe for target 'gnumake' failed
>>>>>>>> make[1]: *** [gnumake] Error 2
>>>>>>>> make[1]: Leaving directory
>>>>>>>> **************************ERROR*************************************
>>>>>>>> Error during compile, check
>>>>>>>> pet3.10.5-intel19-mpich3.3/lib/petsc/conf/make.log
>>>>>>>> Send it and pet3.10.5-intel19-mpich3.3/lib/petsc/conf/configure.log to
>>>>>>>> petsc-maint at mcs.anl.gov
>>>>>>>> On 8/21/19 10:58 PM, Balay, Satish wrote:
>>>>>>>>> To install elemental - you use: --download-elemental=1 [not
>>>>>>>>> --download-elemental-commit=v0.87.7]
>>>>>>>>> Satish
>>>>>>>>>> hi, dear petsc developers,
>>>>>>>>>> I am having a problem when using the external solver elemental.
>>>>>>>>>> I installed petsc3.10.5 version with the flag
>>>>>>>>>> the installation seems to be ok. However, it seems that i may not be
>>>>>>>>>> able
>>>>>>>>>> to use the elemental solver though.
>>>>>>>>>> I followed this page
>>>>>>>>>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MATELEMENTAL.html
>>>>>>>>>> to interface the elemental solver, namely,
>>>>>>>>>> MatSetType(A,MATELEMENTAL);
>>>>>>>>>> or set it via the command line '*-mat_type elemental*',
>>>>>>>>>> in either case, i will get the following error,
>>>>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>>>>>> [0]PETSC ERROR: Unknown type. Check for miss-spelling or missing
>>>>>>>>>> package:
>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/installation.html#external
>>>>>>>>>> [0]PETSC ERROR: Unknown Mat type given: elemental
>>>>>>>>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>>>>>>>> for
>>>>>>>>>> trouble shooting.
>>>>>>>>>> [0]PETSC ERROR: Petsc Release Version 3.10.5, Mar, 28, 2019
>>>>>>>>>> May i ask whether there will be a way or some specific petsc versions
>>>>>>>>>> that
>>>>>>>>>> are
>>>>>>>>>> able to use the elemental solver?
>>>>>>>>>> Thanks in advance,
>>>>>>>>>> best,
>>>>>>>>>> lailai
