[petsc-users] Getting the connectivity from DMPlex
Matthew Knepley
knepley at gmail.com
Wed Aug 21 07:03:19 CDT 2019
On Wed, Aug 21, 2019 at 7:48 AM Jian Zhang - 3ME via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi Jed,
> Thank you very much. I tried to use DMPlexGetCone, but the output is the
> edge ids, not the vertice ids. For the function DMPlexGetClosureIndices,
> I can not find it in petsc4py. Do you know any alternative ways to solve
> this?
DMPlexGetClosure() should be in petsc4py. It also returns orientations,
which you can just filter out.
Matt
> Best,
> Jian
> *From:* Jed Brown <jed at jedbrown.org>
> *Sent:* 21 August 2019 13:42:41
> *To:* Jian Zhang - 3ME; petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] Getting the connectivity from DMPlex
> Jian Zhang - 3ME via petsc-users <petsc-users at mcs.anl.gov> writes:
> > Hi guys,
> > I am trying to get the element connectivity from DMPlex. The input is
> the element id, and the output should be the vertice ids. Which function
> should I use to achieve this? Thanks in advance.
> See DMPlexGetCone or DMPlexGetClosureIndices.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190821/c12e0562/attachment.html>
