[petsc-users] PetscInitialize take various time to run on different node
Matthew Knepley
knepley at gmail.com
Mon Aug 19 17:41:59 CDT 2019
On Mon, Aug 19, 2019 at 4:49 PM Kun Jiao via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi,
> I am running into a problem, different node/process take different time to
> run petscinitialize. The difference could be 5~10mins.
This sounds like an MPI installation error. I would consult your sysadmin.
Matt
> I put some check before petscinitialize, and after petscinitialize.
> MPI_Init(argc, args);
> int rank;
> MPI_Comm_rank(MPI_COMM_WORLD, &rank );
> std::cout << "I am here :"<< rank << "!!!!" << std::endl;
> PetscErrorCode ierr = PetscInitialize(&argc, &args, (char*)0, *help*);
> std::cout << "You am here 2:"<< rank << "!!!!" << std::endl;
> “I am here” message was printout for every process, but not “You are here
> 2” message.
> Very strange.
> Any suggestion is appreciated.
> Regards,
> Kun
> Schlumberger-Private
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190819/4fbc6637/attachment.html>
