[petsc-users] different dof in DMDA creating
Danyang Su
danyang.su at gmail.com
Thu Aug 15 11:33:25 CDT 2019
Hi Matt,
Thanks for the quick reply. Will let you know when I am confused in
using it.
Danyang
On 2019-08-15 9:22 a.m., Matthew Knepley wrote:
> On Thu, Aug 15, 2019 at 12:18 PM Danyang Su <danyang.su at gmail.com
> <mailto:danyang.su at gmail.com>> wrote:
> Hi Barry and Matt,
> Would you please give me some advice on the functions I need to
> use to
> set different dof to the specified nodes. For now, I use
> DMPlexCreateSection that dof is uniform throughout the domain. I am a
> bit lost in choosing the right DMPlex functions, unfortunately.
> Chapter 10 of the PETSc User Manual discusses low-level data layout
> using Section. How about we start
> there and then clarify anything that is confusing.
> Thanks,
> Matt
> Thanks and regards,
> Danyang
> On 2019-02-07 1:53 p.m., Danyang Su wrote:
> > Thanks, Barry. DMPlex also works for my code.
> > Danyang
> > On 2019-02-07 1:14 p.m., Smith, Barry F. wrote:
> >> No, you would need to use the more flexible DMPlex
> >>> On Feb 7, 2019, at 3:04 PM, Danyang Su via petsc-users
> >>> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> >>> Dear PETSc Users,
> >>> Does DMDA support different number of degrees of freedom for
> >>> different node? For example I have a 2D subsurface flow
> problem with
> >>> the default dof = 1 throughout the domain. Now I want to add some
> >>> sparse fractures in the domain. For the nodes connected to the
> >>> sparse fractures, I want to set dof to 2. Is it possible to
> set dof
> >>> to 2 for those nodes only?
> >>> Thanks,
> >>> Danyang
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190815/ac9bab6e/attachment-0001.html>
