[petsc-users] Creating a 3D dmplex mesh with cell list and distributing it
Matthew Knepley
knepley at gmail.com
Thu Aug 15 07:48:36 CDT 2019
On Thu, Aug 15, 2019 at 12:50 AM Swarnava Ghosh <swarnava89 at gmail.com>
wrote:
> Hi Matthew,
> Thank you for your response. It works right now.
Great!
Matt
> dmplex before distribution
> DM Object: 3 MPI processes
> type: plex
> DM_0x84000004_0 in 3 dimensions:
> 0-cells: 7 0 0
> 1-cells: 17 0 0
> 2-cells: 17 0 0
> 3-cells: 6 0 0
> Labels:
> depth: 4 strata with value/size (0 (7), 1 (17), 2 (17), 3 (6))
> dmplex after distribution
> DM Object: Parallel Mesh 3 MPI processes
> type: plex
> Parallel Mesh in 3 dimensions:
> 0-cells: 5 5 5
> 1-cells: 9 9 9
> 2-cells: 7 7 7
> 3-cells: 2 2 2
> Labels:
> depth: 4 strata with value/size (0 (5), 1 (9), 2 (7), 3 (2))
> Thanks,
> Swarnava
> On Wed, Aug 14, 2019 at 8:47 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, Aug 14, 2019 at 10:48 PM Swarnava Ghosh <swarnava89 at gmail.com>
>> wrote:
>>> Hi Matthew,
>>> "It looks like you are running things with the wrong 'mpirun' ", Could
>>> you please elaborate on this? I have another DMDA in my code, which is
>>> correctly being parallelized.
>> Ah, I see it now. You are feeding in the initial mesh on every process.
>> Normally one process generates the mesh
>> and the other ones just give 0 for num cells and vertices.
>> Thanks,
>> Matt
>>> Thanks,
>>> SG
>>> On Wed, Aug 14, 2019 at 7:35 PM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Wed, Aug 14, 2019 at 10:23 PM Swarnava Ghosh <swarnava89 at gmail.com>
>>>> wrote:
>>>>> Hi Matthew,
>>>>> I added DMView(pCgdft->dmplex,PETSC_VIEWER_STDOUT_WORLD); before and
>>>>> after distribution, and I get the following:
>>>> Thanks,
>>>> Matt
>>>>> type: plex
>>>>> 0-cells: 7 7 7
>>>>> 1-cells: 17 17 17
>>>>> 2-cells: 17 17 17
>>>>> 3-cells: 6 6 6
>>>>> Labels:
>>>>> type: plex
>>>>> 0-cells: 7 7 7
>>>>> 1-cells: 17 17 17
>>>>> 2-cells: 17 17 17
>>>>> 3-cells: 6 6 6
>>>>> Labels:
>>>>> Thanks,
>>>>> SG
>>>>> On Wed, Aug 14, 2019 at 6:48 PM Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> DMView() the mesh before and after distribution, so we can see what
>>>>>> we have.
>>>>>> Thanks,
>>>>>> Matt
>>>>>> On Wed, Aug 14, 2019 at 5:30 PM Swarnava Ghosh via petsc-users <
>>>>>> petsc-users at mcs.anl.gov> wrote:
>>>>>>> Hi PETSc team and users,
>>>>>>> I am trying to create a 3D dmplex mesh
>>>>>>> using DMPlexCreateFromCellList, then distribute it, and find out the
>>>>>>> coordinates of the vertices owned by each process.
>>>>>>> My cell list is as follows:
>>>>>>> numCells: 6
>>>>>>> numVertices: 7
>>>>>>> numCorners: 4
>>>>>>> cells:
>>>>>>> 0
>>>>>>> 3
>>>>>>> 2
>>>>>>> 1
>>>>>>> 4
>>>>>>> 0
>>>>>>> 2
>>>>>>> 1
>>>>>>> 6
>>>>>>> 4
>>>>>>> 2
>>>>>>> 1
>>>>>>> 3
>>>>>>> 6
>>>>>>> 2
>>>>>>> 1
>>>>>>> 5
>>>>>>> 4
>>>>>>> 6
>>>>>>> 1
>>>>>>> 3
>>>>>>> 5
>>>>>>> 6
>>>>>>> 1
>>>>>>> vertexCoords:
>>>>>>> -6.043000
>>>>>>> -5.233392
>>>>>>> -4.924000
>>>>>>> -3.021500
>>>>>>> 0.000000
>>>>>>> -4.924000
>>>>>>> -3.021500
>>>>>>> -3.488928
>>>>>>> 0.000000
>>>>>>> -6.043000
>>>>>>> 1.744464
>>>>>>> 0.000000
>>>>>>> 0.000000
>>>>>>> -5.233392
>>>>>>> -4.924000
>>>>>>> 3.021500
>>>>>>> 0.000000
>>>>>>> -4.924000
>>>>>>> 3.021500
>>>>>>> -3.488928
>>>>>>> 0.000000
>>>>>>> After reading this information, I do
>>>>>>> ierr=
>>>>>>> DMPlexCreateFromCellList(PETSC_COMM_WORLD,3,pCgdft->numCellsESP,pCgdft->NESP,pCgdft->numCornersESP,interpolate,pCgdft->cellsESP,3,pCgdft->vertexCoordsESP,&pCgdft->dmplex);
>>>>>>> ierr = DMPlexDistribute(pCgdft->dmplex,0,&pCgdft->dmplexSF,
>>>>>>> &distributedMesh);CHKERRQ(ierr);
>>>>>>> if (distributedMesh) {
>>>>>>> printf("mesh is distributed \n");
>>>>>>> ierr = DMDestroy(&pCgdft->dmplex);CHKERRQ(ierr);
>>>>>>> pCgdft->dmplex = distributedMesh;
>>>>>>> DMGetCoordinates(pCgdft->dmplex,&VC);
>>>>>>> VecView(VC,PETSC_VIEWER_STDOUT_WORLD);
>>>>>>> On running this with 3 mpi processes, From VecView, I see that all
>>>>>>> the processes own all the vertices. Why is the dmplex not being
>>>>>>> distributed?
>>>>>>> The VecView is :
>>>>>>> Process [0]
>>>>>>> -6.043
>>>>>>> -5.23339
>>>>>>> -4.924
>>>>>>> -3.0215
>>>>>>> 0.
>>>>>>> -4.924
>>>>>>> -3.0215
>>>>>>> -3.48893
>>>>>>> 0.
>>>>>>> -6.043
>>>>>>> 1.74446
>>>>>>> 0.
>>>>>>> 0.
>>>>>>> -5.23339
>>>>>>> -4.924
>>>>>>> 3.0215
>>>>>>> 0.
>>>>>>> -4.924
>>>>>>> 3.0215
>>>>>>> -3.48893
>>>>>>> 0.
>>>>>>> Process [1]
>>>>>>> -6.043
>>>>>>> -5.23339
>>>>>>> -4.924
>>>>>>> -3.0215
>>>>>>> 0.
>>>>>>> -4.924
>>>>>>> -3.0215
>>>>>>> -3.48893
>>>>>>> 0.
>>>>>>> -6.043
>>>>>>> 1.74446
>>>>>>> 0.
>>>>>>> 0.
>>>>>>> -5.23339
>>>>>>> -4.924
>>>>>>> 3.0215
>>>>>>> 0.
>>>>>>> -4.924
>>>>>>> 3.0215
>>>>>>> -3.48893
>>>>>>> 0.
>>>>>>> Process [2]
>>>>>>> -6.043
>>>>>>> -5.23339
>>>>>>> -4.924
>>>>>>> -3.0215
>>>>>>> 0.
>>>>>>> -4.924
>>>>>>> -3.0215
>>>>>>> -3.48893
>>>>>>> 0.
>>>>>>> -6.043
>>>>>>> 1.74446
>>>>>>> 0.
>>>>>>> 0.
>>>>>>> -5.23339
>>>>>>> -4.924
>>>>>>> 3.0215
>>>>>>> 0.
>>>>>>> -4.924
>>>>>>> 3.0215
>>>>>>> -3.48893
>>>>>>> 0.
>>>>>>> Thanks,
>>>>>>> SG
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190815/9e91f6f7/attachment.html>
