[petsc-users] Possibility of using out of date Jacobians with TS
Steve
stevenbenbow at quintessa.org
Mon Aug 12 02:49:47 CDT 2019
Thanks Mark, if if I see similar performance I'll be very happy!
On 11/08/2019 15:17, Mark Lohry wrote:
> Anecdotal: I've been *shocked* at how long I can let the
> -snes_lag_preconditioner go with -snes_mf_operator. I have it
> configured to only recompute the preconditioner whenever it hits my
> linear solver iteration limit, which pretty much never happens on
> unsteady problems.
> On Fri, Aug 9, 2019 at 11:11 AM Steve via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> Thank you Barry, that's very helpful.
> I'll have a play with those various options and see how I get on.
> On 09/08/2019 15:43, Smith, Barry F. wrote:
> > Steve,
> > There are two possibilities
> > 1) completely under user control, when you are asked for a new
> Jacobian you can evaluate the current conditions and decide
> whether to generate a new one. For example get from SNES the
> number of iterations it required and if that is starting to go up
> then get a new one or check if the time-step is being cut because
> the nonlinear solver is becoming "too hard" and generate a new one.
> > It is also possible to use -snes_mf_operator (or an inline
> version) that uses matrix-free to apply the Jacobian and the
> Jacobian you provide to compute the preconditioner. This allows
> you to keep the current Jacobian/preconditioner even longer before
> rebuilding. Here you can use the increase in the number of linear
> iterations to decide when to change the Jacobian.
> > 2) let PETSc decide when to rebuild the Jacobian. This is more
> limited since it has no direct measure of how well the Jacobian is
> doing. Some possibilities are
> > -snes_lag_jacobian -snes_lag_jacobian_persists
> -snes_lag_preconditioner -snes_lag_preconditioner_persists This
> introduces yet another parameter under your control; you can lag
> the generation of the new preconditioner even when you get a new
> preconditioner (this makes sense only when you are not using
> -snes_mf_operator),
> > So, at a high level, you have a great deal of freedom to
> control when you recreate the Jacobian (and preconditioner), will
> be problem dependent and the optimal value will depend on your
> problem and specific integrator. Final note, when you rebuild may
> also depend on how far you have integrated, when the nonlinear
> effects are strong you probably want to rebuild often but when the
> solution is close to linearly evolving less often.
> > If generating the Jacobian/preconditioner is expensive
> relative to everything else a good combination is
> -snes_mf_operator and a pretty lagged generation of new Jacobians.
> > Barry
> >> On Aug 9, 2019, at 9:25 AM, Steve via petsc-users
> >> Hi,
> >> I'm experimenting with the use of PETSc to replace a DAE solver
> in an existing code that I use to solve stiff nonlinear problems.
> I expect to use TSBDF in the final instance, and so am currently
> playing with it but applied to a simpler linear problem - just to
> get some experience with the SNES/KSP/PC controls before diving in
> to the hard problem.
> >> Below is some output from TSAdapt for the simple linear
> problem, using TSBDF and PCLU, so that the linear algebra solve in
> the newton loop is direct:
> >> TSAdapt basic bdf 0:2 step 0 accepted t=0 +
> 1.000e-03 dt=2.000e-03 wlte=2.51e-07 wltea= -1 wlter= -1
> >> TSResidual...
> >> TSJacobian... calculate
> >> TSResidual...
> >> TSAdapt basic bdf 0:2 step 1 accepted t=0.001 +
> 2.000e-03 dt=4.000e-03 wlte=2.83e-07 wltea= -1 wlter= -1
> >> TSResidual...
> >> TSResidual...
> >> TSAdapt basic bdf 0:2 step 2 accepted t=0.003 +
> 4.000e-03 dt=8.000e-03 wlte=1.22e-07 wltea= -1 wlter= -1
> >> TSResidual...
> >> TSResidual...
> >> I have added the "TSResidual..." and "TSJacobian..." echoes so
> that I can see when PETSc is requesting residuals and Jacobians to
> be computed. (This is the Jacobian routine specified via
> TSSetIJacobian.)
> >> Regarding the above output, it appears that TS / SNES always
> requests a new (I)Jacobian at each new timestep (after the first
> residual is calculated). I can see mathematically why this would
> be the default choice, but had hoped that it might be possible for
> out-of-date Jacobians to be used until they become inefficient. My
> reason for wanting this is that the Jacobian calculations for the
> intended application are particularly expensive, but for small
> enough timesteps out-of-date Jacobians may be good enough, for a
> few steps.
> >> Is there any way of specifying that out-of-date (I)Jacobians
> can be tolerated (at the expense of increased Newton iterations,
> or smaller timesteps)? Alternatively would it make sense to
> include callbacks to TS / SNES from the Jacobian evaluation
> function to determine whether sufficiently few iterations have
> been used that it might be safe to return the previously
> calculated Jacobian (if I store a copy)? If so, is there any
> advice on how I should do this?
> >> NB. I see that there is an option for TSRHSJacobianSetReuse(),
> but this only applies to the RHS component of the DAE (the G(t,u)
> part, using the terminology from the manual), but I am not using
> this as ultimately I expect to be solving strongly nonlinear
> problems with no "slow" G(t,u) part.
> >> Any advice would be greatly appreciated.
> Dr Steven J Benbow
> Quintessa Ltd, First Floor, West Wing, Videcom House, Newtown
> Road, Henley-on-Thames, Oxfordshire RG9 1HG, UK
> Tel: 01491 636246 DD: 01491 630051 Web: http://www.quintessa.org
> Quintessa Limited is an employee-owned company registered in
> England, Number 3716623.
> Registered office: Quintessa Ltd, First Floor, West Wing, Videcom
> House, Newtown Road, Henley-on-Thames, Oxfordshire RG9 1HG, UK
> If you have received this e-mail in error, please notify
> privacy at quintessa.org <mailto:privacy at quintessa.org> and delete it
> from your system
Dr Steven J Benbow
Quintessa Ltd, First Floor, West Wing, Videcom House, Newtown Road, Henley-on-Thames, Oxfordshire RG9 1HG, UK
Quintessa Limited is an employee-owned company registered in England, Number 3716623.
Registered office: Quintessa Ltd, First Floor, West Wing, Videcom House, Newtown Road, Henley-on-Thames, Oxfordshire RG9 1HG, UK
If you have received this e-mail in error, please notify privacy at quintessa.org and delete it from your system
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190812/a2af47be/attachment.html>
