[petsc-users] Sporadic MPI_Allreduce() called in different locations on larger core counts
Smith, Barry F.
bsmith at mcs.anl.gov
Tue Aug 6 08:36:47 CDT 2019
There is also
$ ./configure --help | grep color
--with-is-color-value-type=<char,short>
char, short can store 256, 65536 colors current: short
I can't imagine you have over 65 k colors but something to check
> On Aug 6, 2019, at 8:19 AM, Mark Lohry <mlohry at gmail.com> wrote:
> My first guess is that the code is getting integer overflow somewhere. 25 billion is well over the 2 billion that 32 bit integers can hold.
> Mine as well -- though in later tests I have the same issue when using --with-64-bit-indices. Ironically I had removed that flag at some point because the coloring / index set was using a serious chunk of total memory on medium sized problems.
Understood
> Questions on the petsc internals there though: Are matrices indexed with two integers (i,j) so the max matrix dimension is (int limit) x (int limit) or a single integer so the max dimension is sqrt(int limit)?
> Also I was operating under the assumption the 32 bit limit should only constrain per-process problem sizes (25B over 400 processes giving 62M non-zeros per process), is that not right?
It is mostly right but may not be right for everything in PETSc. For example I don't know about the MatFD code
Since using a debugger is not practical for large code counts to find the point the two processes diverge you can try
-log_trace
or
-log_trace filename
in the second case it will generate one file per core called filename.%d note it will produce a lot of output
Good luck
> We are adding more tests to nicely handle integer overflow but it is not easy since it can occur in so many places
> Totally understood. I know the pain of only finding an overflow bug after days of waiting in a cluster queue for a big job.
> We urge you to upgrade.
> I'll do that today and hope for the best. On first tests on 3.11.3, I still have a couple issues with the coloring code:
> * I am still getting the nasty hangs with MATCOLORINGJP mentioned here: https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2017-October/033746.html
> * MatColoringSetType(coloring, MATCOLORINGGREEDY); this produces a wrong jacobian unless I also set MatColoringSetWeightType(coloring, MAT_COLORING_WEIGHT_LEXICAL);
> * MATCOLORINGMIS mentioned in the documentation doesn't seem to exist.
> Thanks,
> Mark
> On Tue, Aug 6, 2019 at 8:56 AM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> Regardless for problems this large you likely need the ./configure option --with-64-bit-indices
> Hopefully this will resolve your problem with large process counts
> Barry
> > On Aug 6, 2019, at 7:43 AM, Mark Lohry via petsc-users <petsc-users at mcs.anl.gov> wrote:
> > I'm running some larger cases than I have previously with a working code, and I'm running into failures I don't see on smaller cases. Failures are on 400 cores, ~100M unknowns, 25B non-zero jacobian entries. Runs successfully on half size case on 200 cores.
> > 1) The first error output from petsc is "MPI_Allreduce() called in different locations". Is this a red herring, suggesting some process failed prior to this and processes have diverged?
> > 2) I don't think I'm running out of memory -- globally at least. Slurm output shows e.g.
> > Memory Utilized: 459.15 GB (estimated maximum)
> > Memory Efficiency: 26.12% of 1.72 TB (175.78 GB/node)
> > I did try with and without --64-bit-indices.
> > 3) The debug traces seem to vary, see below. I *think* the failure might be happening in the vicinity of a Coloring call. I'm using MatFDColoring like so:
> > ISColoring iscoloring;
> > MatFDColoring fdcoloring;
> > MatColoring coloring;
> > MatColoringCreate(ctx.JPre, &coloring);
> > // converges stalls badly without this on small cases, don't know why
> > // none of these worked.
> > // MatColoringSetType(coloring, MATCOLORINGJP);
> > // MatColoringSetType(coloring, MATCOLORINGSL);
> > // MatColoringSetType(coloring, MATCOLORINGID);
> > MatColoringSetFromOptions(coloring);
> > MatColoringApply(coloring, &iscoloring);
> > MatColoringDestroy(&coloring);
> > MatFDColoringCreate(ctx.JPre, iscoloring, &fdcoloring);
> > I have had issues in the past with getting a functional coloring setup for finite difference jacobians, and the above is the only configuration I've managed to get working successfully. Have there been any significant development changes to that area of code since v3.8.3? I'll try upgrading in the mean time and hope for the best.
> > Any ideas?
> > Thanks,
> > Mark
> > mlohry at lancer:/ssd/dev_ssd/cmake-build$ grep "\[0\]" slurm-3429773.out
> > [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> > [0]PETSC ERROR: Petsc has generated inconsistent data
> > [0]PETSC ERROR: MPI_Allreduce() called in different locations (functions) on different processors
> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> > [0]PETSC ERROR: Petsc Release Version 3.8.3, Dec, 09, 2017
> > [0]PETSC ERROR: maDG on a arch-linux2-c-opt named tiger-h19c1n19 by mlohry Tue Aug 6 06:05:02 2019
> > [0]PETSC ERROR: Configure options PETSC_DIR=/home/mlohry/build/external/petsc PETSC_ARCH=arch-linux2-c-opt --with-cc=/opt/intel/compilers_and_libraries_2019.1.144/linux/mpi/intel64/bin/mpigcc --with-cxx=/opt/intel/compilers_and_libraries_2019.1.144/linux/mpi/intel64/bin/mpigxx --with-fc=0 --with-clanguage=C++ --with-pic=1 --with-debugging=yes COPTFLAGS='-O3' CXXOPTFLAGS='-O3' --with-shared-libraries=1 --download-parmetis --download-metis MAKEFLAGS=$MAKEFLAGS --with-mpiexec=/usr/bin/srun --with-64-bit-indices
> > [0]PETSC ERROR: #1 TSSetMaxSteps() line 2944 in /home/mlohry/build/external/petsc/src/ts/interface/ts.c
> > [0]PETSC ERROR: #2 TSSetMaxSteps() line 2944 in /home/mlohry/build/external/petsc/src/ts/interface/ts.c
> > [0]PETSC ERROR: Invalid argument
> > [0]PETSC ERROR: Enum value must be same on all processes, argument # 2
> > [0]PETSC ERROR: #3 TSSetExactFinalTime() line 2250 in /home/mlohry/build/external/petsc/src/ts/interface/ts.c
> > [0]PETSC ERROR: ------------------------------------------------------------------------
> > [0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the batch system) has told this process to end
> > [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> > [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> > [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
> > [0]PETSC ERROR: likely location of problem given in stack below
> > [0]PETSC ERROR: --------------------- Stack Frames ------------------------------------
> > [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> > [0]PETSC ERROR: INSTEAD the line number of the start of the function
> > [0]PETSC ERROR: is given.
> > [0]PETSC ERROR: [0] PetscCommDuplicate line 130 /home/mlohry/build/external/petsc/src/sys/objects/tagm.c
> > [0]PETSC ERROR: [0] PetscHeaderCreate_Private line 34 /home/mlohry/build/external/petsc/src/sys/objects/inherit.c
> > [0]PETSC ERROR: [0] DMCreate line 36 /home/mlohry/build/external/petsc/src/dm/interface/dm.c
> > [0]PETSC ERROR: [0] DMShellCreate line 983 /home/mlohry/build/external/petsc/src/dm/impls/shell/dmshell.c
> > [0]PETSC ERROR: [0] TSGetDM line 5287 /home/mlohry/build/external/petsc/src/ts/interface/ts.c
> > [0]PETSC ERROR: [0] TSSetIFunction line 1310 /home/mlohry/build/external/petsc/src/ts/interface/ts.c
> > [0]PETSC ERROR: [0] TSSetExactFinalTime line 2248 /home/mlohry/build/external/petsc/src/ts/interface/ts.c
> > [0]PETSC ERROR: [0] TSSetMaxSteps line 2942 /home/mlohry/build/external/petsc/src/ts/interface/ts.c
> > [0]PETSC ERROR: Signal received
> > [0]PETSC ERROR: #4 User provided function() line 0 in unknown file
> > mlohry at lancer:/ssd/dev_ssd/cmake-build$ grep "\[0\]" slurm-3429158.out
> > [0]PETSC ERROR: MPI_Allreduce() called in different locations (code lines) on different processors
> > [0]PETSC ERROR: maDG on a arch-linux2-c-opt named tiger-h21c2n1 by mlohry Mon Aug 5 23:58:19 2019
> > [0]PETSC ERROR: #1 MatSetBlockSizes() line 7206 in /home/mlohry/build/external/petsc/src/mat/interface/matrix.c
> > [0]PETSC ERROR: #2 MatSetBlockSizes() line 7206 in /home/mlohry/build/external/petsc/src/mat/interface/matrix.c
> > [0]PETSC ERROR: #3 MatSetBlockSize() line 7170 in /home/mlohry/build/external/petsc/src/mat/interface/matrix.c
> > [0]PETSC ERROR: #4 VecSetSizes() line 1310 in /home/mlohry/build/external/petsc/src/vec/vec/interface/vector.c
> > [0]PETSC ERROR: #5 VecSetSizes() line 1310 in /home/mlohry/build/external/petsc/src/vec/vec/interface/vector.c
> > [0]PETSC ERROR: #6 VecCreateMPIWithArray() line 609 in /home/mlohry/build/external/petsc/src/vec/vec/impls/mpi/pbvec.c
> > [0]PETSC ERROR: #7 MatSetUpMultiply_MPIAIJ() line 111 in /home/mlohry/build/external/petsc/src/mat/impls/aij/mpi/mmaij.c
> > [0]PETSC ERROR: #8 MatAssemblyEnd_MPIAIJ() line 735 in /home/mlohry/build/external/petsc/src/mat/impls/aij/mpi/mpiaij.c
> > [0]PETSC ERROR: #9 MatAssemblyEnd() line 5243 in /home/mlohry/build/external/petsc/src/mat/interface/matrix.c
> > [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
> > [0]PETSC ERROR: [0] PetscSFSetGraphLayout line 497 /home/mlohry/build/external/petsc/src/vec/is/utils/pmap.c
> > [0]PETSC ERROR: [0] GreedyColoringLocalDistanceTwo_Private line 208 /home/mlohry/build/external/petsc/src/mat/color/impls/greedy/greedy.c
> > [0]PETSC ERROR: [0] MatColoringApply_Greedy line 559 /home/mlohry/build/external/petsc/src/mat/color/impls/greedy/greedy.c
> > [0]PETSC ERROR: [0] MatColoringApply line 357 /home/mlohry/build/external/petsc/src/mat/color/interface/matcoloring.c
> > [0]PETSC ERROR: [0] VecSetSizes line 1308 /home/mlohry/build/external/petsc/src/vec/vec/interface/vector.c
> > [0]PETSC ERROR: [0] VecCreateMPIWithArray line 605 /home/mlohry/build/external/petsc/src/vec/vec/impls/mpi/pbvec.c
> > [0]PETSC ERROR: [0] MatSetUpMultiply_MPIAIJ line 24 /home/mlohry/build/external/petsc/src/mat/impls/aij/mpi/mmaij.c
> > [0]PETSC ERROR: [0] MatAssemblyEnd_MPIAIJ line 698 /home/mlohry/build/external/petsc/src/mat/impls/aij/mpi/mpiaij.c
> > [0]PETSC ERROR: [0] MatAssemblyEnd line 5234 /home/mlohry/build/external/petsc/src/mat/interface/matrix.c
> > [0]PETSC ERROR: [0] MatSetBlockSizes line 7204 /home/mlohry/build/external/petsc/src/mat/interface/matrix.c
> > [0]PETSC ERROR: [0] MatSetBlockSize line 7167 /home/mlohry/build/external/petsc/src/mat/interface/matrix.c
> > [0]PETSC ERROR: #10 User provided function() line 0 in unknown file
> > mlohry at lancer:/ssd/dev_ssd/cmake-build$ grep "\[0\]" slurm-3429134.out
> > [0]PETSC ERROR: maDG on a arch-linux2-c-opt named tiger-h20c2n1 by mlohry Mon Aug 5 23:24:23 2019
> > [0]PETSC ERROR: #1 PetscSplitOwnership() line 88 in /home/mlohry/build/external/petsc/src/sys/utils/psplit.c
> > [0]PETSC ERROR: #2 PetscSplitOwnership() line 88 in /home/mlohry/build/external/petsc/src/sys/utils/psplit.c
> > [0]PETSC ERROR: #3 PetscLayoutSetUp() line 137 in /home/mlohry/build/external/petsc/src/vec/is/utils/pmap.c
> > [0]PETSC ERROR: #4 VecCreate_MPI_Private() line 489 in /home/mlohry/build/external/petsc/src/vec/vec/impls/mpi/pbvec.c
> > [0]PETSC ERROR: #5 VecCreate_MPI() line 537 in /home/mlohry/build/external/petsc/src/vec/vec/impls/mpi/pbvec.c
> > [0]PETSC ERROR: #6 VecSetType() line 51 in /home/mlohry/build/external/petsc/src/vec/vec/interface/vecreg.c
> > [0]PETSC ERROR: #7 VecCreateMPI() line 40 in /home/mlohry/build/external/petsc/src/vec/vec/impls/mpi/vmpicr.c
> > [0]PETSC ERROR: Object is in wrong state
> > [0]PETSC ERROR: Vec object's type is not set: Argument # 1
> > [0]PETSC ERROR: #8 VecGetLocalSize() line 665 in /home/mlohry/build/external/petsc/src/vec/vec/interface/vector.c
> > mlohry at lancer:/ssd/dev_ssd/cmake-build$ grep "\[0\]" slurm-3429102.out
> > [0]PETSC ERROR: maDG on a arch-linux2-c-opt named tiger-h19c1n16 by mlohry Mon Aug 5 22:50:12 2019
> > [0]PETSC ERROR: #1 TSSetExactFinalTime() line 2250 in /home/mlohry/build/external/petsc/src/ts/interface/ts.c
> > [0]PETSC ERROR: #2 TSSetExactFinalTime() line 2250 in /home/mlohry/build/external/petsc/src/ts/interface/ts.c
> > [0]PETSC ERROR: #3 MatSetBlockSizes() line 7206 in /home/mlohry/build/external/petsc/src/mat/interface/matrix.c
> > [0]PETSC ERROR: #4 MatSetBlockSizes() line 7206 in /home/mlohry/build/external/petsc/src/mat/interface/matrix.c
> > [0]PETSC ERROR: #5 MatSetBlockSize() line 7170 in /home/mlohry/build/external/petsc/src/mat/interface/matrix.c
> > [0]PETSC ERROR: #6 MatStashScatterBegin_Ref() line 476 in /home/mlohry/build/external/petsc/src/mat/utils/matstash.c
> > [0]PETSC ERROR: #7 MatStashScatterBegin_Ref() line 476 in /home/mlohry/build/external/petsc/src/mat/utils/matstash.c
> > [0]PETSC ERROR: #8 MatStashScatterBegin_Private() line 455 in /home/mlohry/build/external/petsc/src/mat/utils/matstash.c
> > [0]PETSC ERROR: #9 MatAssemblyBegin_MPIAIJ() line 679 in /home/mlohry/build/external/petsc/src/mat/impls/aij/mpi/mpiaij.c
> > [0]PETSC ERROR: #10 MatAssemblyBegin() line 5154 in /home/mlohry/build/external/petsc/src/mat/interface/matrix.c
> > [0]PETSC ERROR: [0] MatStashScatterEnd_Ref line 137 /home/mlohry/build/external/petsc/src/mat/utils/matstash.c
> > [0]PETSC ERROR: [0] MatStashScatterEnd_Private line 126 /home/mlohry/build/external/petsc/src/mat/utils/matstash.c
> > [0]PETSC ERROR: [0] MatStashScatterBegin_Ref line 473 /home/mlohry/build/external/petsc/src/mat/utils/matstash.c
> > [0]PETSC ERROR: [0] MatStashScatterBegin_Private line 454 /home/mlohry/build/external/petsc/src/mat/utils/matstash.c
> > [0]PETSC ERROR: [0] MatAssemblyBegin_MPIAIJ line 676 /home/mlohry/build/external/petsc/src/mat/impls/aij/mpi/mpiaij.c
> > [0]PETSC ERROR: [0] MatAssemblyBegin line 5143 /home/mlohry/build/external/petsc/src/mat/interface/matrix.c
> > [0]PETSC ERROR: #11 User provided function() line 0 in unknown file
