[petsc-users] ST solver error
Jose E. Roman
jroman at dsic.upv.es
Thu Aug 1 09:01:39 CDT 2019
See FAQ #10
http://slepc.upv.es/documentation/faq.htm
> El 1 ago 2019, a las 15:58, Yang Bo (Asst Prof) via petsc-users <petsc-users at mcs.anl.gov> escribió:
> Hi everyone,
> I am trying to use the Shift-and-invert spectral transformations for my diagonalisation code. While there is no problem running the code with
> STSetType(st,STSHIFT);
> I receive the following errors when using STSetType(st,STSINVERT):
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/linearsolvertable.html for possible LU and Cholesky solvers
> [0]PETSC ERROR: Could not locate a solver package. Perhaps you must ./configure with --download-<package>
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.10.2, Oct, 09, 2018
> [0]PETSC ERROR: ./main on a arch-linux2-c-debug named yangbo-ThinkStation-P720 by yangbo Thu Aug 1 17:30:34 2019
> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-mpich --download-fblaslapack --with-debugging=0 COPTFLAGS="-O3 -march=native -mtune=native" CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3 -march=native -mtune=native"
> [0]PETSC ERROR: #1 MatGetFactor() line 4415 in /home/yangbo/petsc-3.10.2/src/mat/interface/matrix.c
> [0]PETSC ERROR: #2 PCSetUp_LU() line 93 in /home/yangbo/petsc-3.10.2/src/ksp/pc/impls/factor/lu/lu.c
> [0]PETSC ERROR: #3 PCSetUp() line 932 in /home/yangbo/petsc-3.10.2/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #4 KSPSetUp() line 391 in /home/yangbo/petsc-3.10.2/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #5 STSetUp_Cayley() line 192 in /home/yangbo/slepc-3.10.1/src/sys/classes/st/impls/cayley/cayley.c
> [0]PETSC ERROR: #6 STSetUp() line 271 in /home/yangbo/slepc-3.10.1/src/sys/classes/st/interface/stsolve.c
> [0]PETSC ERROR: #7 EPSSetUp() line 263 in /home/yangbo/slepc-3.10.1/src/eps/interface/epssetup.c
> [0]PETSC ERROR: #8 EPSSolve() line 135 in /home/yangbo/slepc-3.10.1/src/eps/interface/epssolve.c
> [0]PETSC ERROR: #9 main() line 331 in main.cpp
> [0]PETSC ERROR: PETSc Option Table entries:
> [0]PETSC ERROR: -e 7
> [0]PETSC ERROR: -f d
> [0]PETSC ERROR: -nev 20
> [0]PETSC ERROR: -o 19
> [0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
> application called MPI_Abort(MPI_COMM_WORLD, 92) - process 0
> May I know if I need to install the solver package for this to work?
> Thank you very much!
> Best regards,
> Yang Bo
