[petsc-users] When building PETSc with --prefix, reference to temporary build directory remains
Bastian Löhrer bastian.loehrer at tu-dresden.de
Thu Aug 1 06:07:12 CDT 2019
Dear all,
I'm struggling to compile PETSc 3.3-p6 on a cluster where it is to be
provided in a read-only folder.
My scenario is the following:
PETSc shall end up in a folder into which I can write from a login node
but which is read-only on compute nodes: I'll call it /readonly/ below.
So, using a compute node, I need to compile PETSc in a different
location, which I'll call /temporary/
I have read numerous instructions on the web and here are the steps that
I came up with:
1. on a compute node: unpack the PETSc source to /temporary/ and
navigate there.
2. configure:
./configure \
                  --prefix=/readonly/ \
--with-gnu-compilers=0 \
--with-vendor-compilers=intel \
--with-large-file-io=1 \
                  --CFLAGS="-fPIC -L${I_MPI_ROOT}/intel64/lib
-I${I_MPI_ROOT}/intel64/include -lmpi"           \
                --CXXFLAGS="-fPIC -L${I_MPI_ROOT}/intel64/lib
-I${I_MPI_ROOT}/intel64/include -lmpi -lmpicxx"  \
                  --FFLAGS="-fPIC -L${I_MPI_ROOT}/intel64/lib
                 --LDFLAGS="-L${I_MPI_ROOT}/intel64/lib
                 COPTFLAGS="-O3 -axCORE-AVX2 -xSSE4.2 -fp-model
consistent -fp-model source -fp-speculation=safe -ftz"  \
               CXXOPTFLAGS="-O3 -axCORE-AVX2 -xSSE4.2 -fp-model
                 FOPTFLAGS="-O3 -axCORE-AVX2 -xSSE4.2 -fp-model
--with-blas-lapack-dir="${MKLROOT}/lib/intel64" \
--download-hypre \
          --with-debugging=no
3. make all
4. on a login node: make install
5. From now on set PETSC_DIR=/readonly PETSC_ARCH=''
step 4 moves the compiled PETSc to /readonly/ and it works, but when I
compile a program with it the following line pops up in the linking command:
-Wl,-rpath,/temporary/-Xlinker
This is a problem when the drive on which /temporary/ is placed is not
reachable which is the case right now due to technical issues. This
causes the linking process to get stuck.
The folder /temporary/ is to be deleted anyway so I do not see why it
should be referenced here.
Am I missing something?
- Bastian
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190801/9e8e3a72/attachment.html>
