[petsc-users] GlobalToLocal between DM and SubDM
Josh L ysjosh.lo at gmail.com
Tue Apr 30 13:19:43 CDT 2019
Thank you.
I just have a coupled problem, and i want to solve it beginning with
stagger then couple.
Matthew Knepley <knepley at gmail.com> 於 2019年4月30日 週二 下午12:57寫道:
> On Tue, Apr 30, 2019 at 1:20 PM Josh L via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Hi,
>> I have a DM that that has 2 sections:
>> section_0 has 2 dofs: u, v
>> section_1 has 1 dofs: p
>> and a SubDM created by DMCreateSubDM. SubDM only has section_1.
>> There are a global vector created with DM, and a local vector created
>> with SubDM
>> Can I do GlobalToLocal between this 2 vectors?
> No, the global and local vector have to have the same DM.
> If yes, which DM should I use when calling GlobalToLocal.
>> Basically, I want
>> a global vec: [u1, v1, p1 u2, v2, p2, u3, v3, p3......]
>> to
>> local vec: [all dof p that belongs to this processor]
> You will have to do it in two steps, either,
>   1) Extract p in a subDM, and then do G2L on that
> or
>   2) Do G2L on the full DM, and then extract p from the local vec
> 1) sounds better to me, but I do not know what your code is doing.
>   Thanks,
>     Matt
>> Thanks,
>> Yu-Sheng
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190430/5aac3fa6/attachment.html>
