[petsc-users] ASM vs GASM
    Boyce Griffith
    boyceg at gmail.com
    Tue Apr 30 08:38:55 CDT 2019
> On Apr 30, 2019, at 9:06 AM, Mark Adams <mfadams at lbl.gov> wrote:
> Allowing GASM to construct the "outer" subdomains from the non-overlapping "inner" subdomains, and using "exact" subdomain solvers (subdomain KSPs are using FGMRES+ILU with an rtol of 1e-12), I get convergence in ~2 iterations in the preconditioned residual norm to an rtol of 1e-12. If I look at the true residual norm, however, it stagnates around 1e-4.
> That PC is singular.
Yes. I am confused about why GASM is giving a singular PC but ASM is not with the same subdomains.
One difference between them is that the default GASM overlap is 0 (https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCGASMSetOverlap.html <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCGASMSetOverlap.html>), but the default ASM overlap is 1 (https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCASMSetOverlap.html <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCASMSetOverlap.html>). However, changing the GASM overlap does not make any difference in the convergence history.
-- Boyce
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190430/dea41e50/attachment-0001.html>
