[petsc-users] Bad memory scaling with PETSc 3.10
Myriam Peyrounette
myriam.peyrounette at idris.fr
Tue Apr 30 03:25:41 CDT 2019
that's really good news for us, thanks! I will plot again the memory
scaling using these new options and let you know. Next week I hope.
Before that, I just need to clarify the situation. Throughout our
discussions, we mentionned a number of options concerning the scalability:
-matptatp_via scalable
-inner_diag_matmatmult_via scalable
-mat_freeintermediatedatastructures
-matptap_via allatonce
-matptap_via allatonce_merged
Which ones of them are compatible? Should I use all of them at the same
time? Is there redundancy?
Myriam
Le 04/25/19 à 21:47, Zhang, Hong a écrit :
> Myriam:
> Checking MatPtAP() in petsc-3.6.4, I realized that it uses different
> algorithm than petsc-10 and later versions. petsc-3.6 uses out-product
> for C=P^T * AP, while petsc-3.10 uses local transpose of P. petsc-3.10
> accelerates data accessing, but doubles the memory of P.
> Fande added two new implementations for MatPtAP() to petsc-master
> which use much smaller and scalable memories with slightly higher
> computing time (faster than hypre though). You may use these new
> implementations if you have concern on memory scalability. The option
> for these new implementation are:
> Hong
> On Mon, Apr 15, 2019 at 12:10 PM hzhang at mcs.anl.gov
> <mailto:hzhang at mcs.anl.gov> <hzhang at mcs.anl.gov
> <mailto:hzhang at mcs.anl.gov>> wrote:
> Myriam:
> Thank you very much for providing these results!
> I have put effort to accelerate execution time and avoid using
> global sizes in PtAP, for which the algorithm of transpose of
> P_local and P_other likely doubles the memory usage. I'll try to
> investigate why it becomes unscalable.
> Hong
> Hi,
> you'll find the new scaling attached (green line). I used the
> version 3.11 and the four scalability options :
> -matptap_via scalable
> -inner_offdiag_matmatmult_via scalable
> The scaling is much better! The code even uses less memory for
> the smallest cases. There is still an increase for the larger
> one.
> With regard to the time scaling, I used KSPView and LogView on
> the two previous scalings (blue and yellow lines) but not on
> the last one (green line). So we can't really compare them, am
> I right? However, we can see that the new time scaling looks
> quite good. It slightly increases from ~8s to ~27s.
> Unfortunately, the computations are expensive so I would like
> to avoid re-run them if possible. How relevant would be a
> proper time scaling for you?
> Myriam
> Le 04/12/19 à 18:18, Zhang, Hong a écrit :
>> Myriam :
>> Thanks for your effort. It will help us improve PETSc.
>> Hong
>> Hi all,
>> I used the wrong script, that's why it diverged... Sorry
>> about that.
>> I tried again with the right script applied on a tiny
>> problem (~200
>> elements). I can see a small difference in memory usage
>> (gain ~ 1mB).
>> when adding the -mat_freeintermediatestructures option. I
>> still have to
>> execute larger cases to plot the scaling. The
>> supercomputer I am used to
>> run my jobs on is really busy at the moment so it takes a
>> while. I hope
>> I'll send you the results on Monday.
>> Thanks everyone,
>> Myriam
>> Le 04/11/19 à 06:01, Jed Brown a écrit :
>> > "Zhang, Hong" <hzhang at mcs.anl.gov
>> <mailto:hzhang at mcs.anl.gov>> writes:
>> >> Jed:
>> >>>> Myriam,
>> >>>> Thanks for the plot.
>> '-mat_freeintermediatedatastructures' should not affect
>> solution. It releases almost half of memory in C=PtAP if
>> C is not reused.
>> >>> And yet if turning it on causes divergence, that
>> would imply a bug.
>> >>> Hong, are you able to reproduce the experiment to see
>> the memory
>> >>> scaling?
>> >> I like to test his code using an alcf machine, but my
>> hands are full now. I'll try it as soon as I find time,
>> hopefully next week.
>> > I have now compiled and run her code locally.
>> > Myriam, thanks for your last mail adding configuration
>> and removing the
>> > MemManager.h dependency. I ran with and without
>> > -mat_freeintermediatedatastructures and don't see a
>> difference in
>> > convergence. What commands did you run to observe that
>> difference?
>> Myriam Peyrounette
>> CNRS/IDRIS - HLST
> Myriam Peyrounette
> CNRS/IDRIS - HLST
Myriam Peyrounette
CNRS/IDRIS - HLST
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190430/9c78f543/attachment-0001.html>
Type: application/pkcs7-signature
Desc: Signature cryptographique S/MIME
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190430/9c78f543/attachment-0001.p7s>
