[petsc-users] Bad memory scaling with PETSc 3.10
Mark Adams mfadams at lbl.gov
Fri Apr 26 07:47:00 CDT 2019
Increasing the threshold should increase the size of the coarse grids, but
yours are decreasing. I'm puzzled by that.
On Tue, Mar 5, 2019 at 11:53 AM Myriam Peyrounette <
myriam.peyrounette at idris.fr> wrote:
> I used PCView to display the size of the linear system in each level of
> the MG. You'll find the outputs attached to this mail (zip file) for both
> the default threshold value and a value of 0.1, and for both 3.6 and 3.10
> PETSc versions.
> For convenience, I summarized the information in a graph, also attached
> (png file).
> As you can see, there are slight differences between the two versions but
> none is critical, in my opinion. Do you see anything suspicious in the
> outputs?
> + I can't find the default threshold value. Do you know where I can find
> it?
> Thanks for the follow-up
> Myriam
> Le 03/05/19 à 14:06, Matthew Knepley a écrit :
> On Tue, Mar 5, 2019 at 7:14 AM Myriam Peyrounette <
>> Hi Matt,
>> I plotted the memory scalings using different threshold values. The two
>> scalings are slightly translated (from -22 to -88 mB) but this gain is
>> neglectable. The 3.6-scaling keeps being robust while the 3.10-scaling
>> deteriorates.
>> Do you have any other suggestion?
> Mark, what is the option she can give to output all the GAMG data?
> Also, run using -ksp_view. GAMG will report all the sizes of its grids, so
> it should be easy to see
> if the coarse grid sizes are increasing, and also what the effect of the
> threshold value is.
>   Thanks,
>      Matt
>> Thanks
>> Myriam
>> Le 03/02/19 à 02:27, Matthew Knepley a écrit :
>> On Fri, Mar 1, 2019 at 10:53 AM Myriam Peyrounette via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> Hi,
>>> I used to run my code with PETSc 3.6. Since I upgraded the PETSc version
>>> to 3.10, this code has a bad memory scaling.
>>> To report this issue, I took the PETSc script ex42.c and slightly
>>> modified it so that the KSP and PC configurations are the same as in my
>>> code. In particular, I use a "personnalised" multi-grid method. The
>>> modifications are indicated by the keyword "TopBridge" in the attached
>>> scripts.
>>> To plot the memory (weak) scaling, I ran four calculations for each
>>> script with increasing problem sizes and computations cores:
>>> 1. 100,000 elts on 4 cores
>>> 2. 1 million elts on 40 cores
>>> 3. 10 millions elts on 400 cores
>>> 4. 100 millions elts on 4,000 cores
>>> The resulting graph is also attached. The scaling using PETSc 3.10
>>> clearly deteriorates for large cases, while the one using PETSc 3.6 is
>>> robust.
>>> After a few tests, I found that the scaling is mostly sensitive to the
>>> use of the AMG method for the coarse grid (line 1780 in
>>> main_ex42_petsc36.cc). In particular, the performance strongly
>>> deteriorates when commenting lines 1777 to 1790 (in
>>> Do you have any idea of what changed between version 3.6 and version
>>> 3.10 that may imply such degradation?
>> I believe the default values for PCGAMG changed between versions. It
>> sounds like the coarsening rate
>> is not great enough, so that these grids are too large. This can be set
>> using:
>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCGAMGSetThreshold.html
>> There is some explanation of this effect on that page. Let us know if
>> setting this does not correct the situation.
>>   Thanks,
>>      Matt
>>> Let me know if you need further information.
>>> Best,
>>> Myriam Peyrounette
>>> Myriam Peyrounette
>>> CNRS/IDRIS - HLST
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/%7Eknepley/>
>> Myriam Peyrounette
>> CNRS/IDRIS - HLST
> experiments lead.
> -- Norbert Wiener
> Myriam Peyrounette
> CNRS/IDRIS - HLST
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190426/94d9e4f2/attachment.html>
