[petsc-users] questions regarding simple petsc matrix vector operation
Karl Lin
karl.linkui at gmail.com
Wed Apr 24 16:13:13 CDT 2019
Hi, there
I have been trying to get a simple program run with the following code:
12 int main(int argc,char **args)
13 {
14 PetscErrorCode ierr;
15 Mat A;
16 Mat AT;
17 Mat N;
18 char name[1024];
19 char vname[1024];
20 char pass[1024];
21 PetscBool flg;
22 Vec b,x,u,Ab,Au;
23 PetscViewer viewer; /* viewer */
24 PetscMPIInt rank,size;
25
26 KSP QRsolver;
27 PC pc;
28 PetscInt its;
29 PetscReal norm;
30
31 PetscInt n1, n2, n3, np1, np2, np3, p, jj;
32
33 PetscInt *cols, *dnz, *onz;
34 PetscScalar *vals;
35
36 ierr = PetscInitialize(&argc,&args,0,help);if (ierr) return ierr;
37
38 ierr = MPI_Comm_size(PETSC_COMM_WORLD,&size);CHKERRQ(ierr);
39 ierr = MPI_Comm_rank(PETSC_COMM_WORLD,&rank);CHKERRQ(ierr);
40
41 PetscMalloc1(1, &dnz);
42 PetscMalloc1(1, &onz);
43
44 dnz[0]=2;
45 onz[0]=1;
46
47 MatCreateMPIAIJMKL(PETSC_COMM_WORLD, 1, 2, 1, 2, 2, dnz, 2, onz, &A);
CHKERRQ(ierr);
48
49 PetscMalloc1(2, &cols);
50 PetscMalloc1(2, &vals);
51
52 jj = rank;
53 cols[0]=0; cols[1]=1;
54 vals[0]=1.0;vals[1]=1.0;
55
56 MatSetValues(A, 1, &jj, 2, cols, vals, INSERT_VALUES);
57
58 MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
59 MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
60
61 VecCreate(PETSC_COMM_WORLD,&x);
62 VecSetSizes(x,PETSC_DECIDE,2);
63 VecSetFromOptions(x);
64
65 VecCreate(PETSC_COMM_WORLD,&b);
66 VecSetSizes(b,PETSC_DECIDE,1);
67 VecSetFromOptions(b);
68
69 VecCreate(PETSC_COMM_WORLD,&u);
70 VecSetSizes(u,PETSC_DECIDE,1);
71 VecSetFromOptions(u);
72
73 VecSet(b, 2.0);
74 VecSet(u, 0.0);
75 VecSet(x, 0.0);
76
77 MatMult(A, x, u);
78
79 VecView(x, PETSC_VIEWER_STDOUT_WORLD);
80 VecView(b, PETSC_VIEWER_STDOUT_WORLD);
81 VecView(u, PETSC_VIEWER_STDOUT_WORLD);
82
83 VecAXPY(u,-1.0,b);
However, it always crashes at line 83 even with single process saying:
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
to find memory corruption errors
[0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
run
[0]PETSC ERROR: to get more information on the crash.
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.10.4, Feb, 26, 2019
I can't figure out why this would happen. The printout from VecView shows
every vec value is correct. I will greatly appreciate any tips.
Karl
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190424/4c344c8f/attachment.html>
