[petsc-users] Argument out of range error in MatPermute
Wed Apr 24 07:26:00 CDT 2019
On Wed, Apr 24, 2019 at 8:25 AM Eda Oktay <eda.oktay at metu.edu.tr> wrote:
> Dear Matt,
> I solved my problem by trying with 9*9 matrix as you said. I made indexing
> mistake.
Great! Reducing the problem size always helps.
    Matt
> Thank you for answering.
> Eda
> Matthew Knepley <knepley at gmail.com>, 24 Nis 2019 Çar, 14:30 tarihinde
> şunu yazdı:
>> On Wed, Apr 24, 2019 at 6:35 AM Stefano Zampini via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> Dump the index sets and the matrix in binary and send them
>> First, reduce your problem size to about 10.
>>   Matt
>>> Il giorno mer 24 apr 2019 alle ore 13:21 Eda Oktay <
>>> eda.oktay at metu.edu.tr> ha scritto:
>>>> Since I am using square matrix, isn't the row local size of the matrix
>>>> equal to the local size of IS? They are both 2127 and 2126.
>>>> Stefano Zampini <stefano.zampini at gmail.com>, 24 Nis 2019 Çar, 13:15
>>>> tarihinde şunu yazdı:
>>>>> I don't understand your code. However, I suspect we have a bug here
>>>>> https://bitbucket.org/petsc/petsc/src/dba4d5898a4236b42fbe8dff209f1243d2f2582a/src/mat/impls/aij/mpi/mpiaij.c#lines-1652
>>>>> The code assumes the number of leaves is A->rmap->n (the row local
>>>>> size of the matrix). Shouldn't this be the local size of the IS (rowp)?
>>>>> Barry?
>>>>> Il giorno mer 24 apr 2019 alle ore 13:03 Eda Oktay <
>>>>>> Dear Stefano,
>>>>>> Thank you for answering. When I used MatSetSizes, I got an error
>>>>>> since the matrix is read from outside, but from the error I understood that
>>>>>> actually the local sizes are 2127 and 2126, so I misunderstood the problem.
>>>>>> I am sorry for my mistake.
>>>>>> However, I still cannot understand where is the error. Because both
>>>>>> communicators and local sizes of IS and the matrix are the same. I still
>>>>>> get the same error in MatPermute:
>>>>>> [0]PETSC ERROR: Argument out of range
>>>>>> [0]PETSC ERROR: Index -1081207334 is out of range
>>>>>> [0]PETSC ERROR: See
>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>>>> shooting.
>>>>>> [0]PETSC ERROR: Petsc Release Version 3.10.3, Dec, 18, 2018
>>>>>> [0]PETSC ERROR: ./TEKRAR_TEK_SAYI_SON_YENI_DENEME_TEMIZ_ENYENI_FINAL
>>>>>> on a arch-linux2-c-debug named 53d.wls.metu.edu.tr by edaoktay Wed
>>>>>> Apr 24 11:22:15 2019
>>>>>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>>>>>> --with-fc=gfortran --with-cxx-dialect=C++11 --download-openblas
>>>>>> --download-metis --download-parmetis --download-superlu_dist
>>>>>> --download-slepc --download-mpich
>>>>>> [0]PETSC ERROR: #1 PetscLayoutFindOwner() line 248 in
>>>>>> /home/edaoktay/petsc-3.10.3/include/petscis.h
>>>>>> [0]PETSC ERROR: #2 MatPermute_MPIAIJ() line 1685 in
>>>>>> /home/edaoktay/petsc-3.10.3/src/mat/impls/aij/mpi/mpiaij.c
>>>>>> [0]PETSC ERROR: #3 MatPermute() line 4997 in
>>>>>> /home/edaoktay/petsc-3.10.3/src/mat/interface/matrix.c
>>>>>> [0]PETSC ERROR: #4 main() line 361 in
>>>>>> /home/edaoktay/petsc-3.10.3/arch-linux2-c-debug/share/slepc/examples/src/eda/TEKRAR_TEK_SAYI_SON_YENI_DENEME_TEMIZ_ENYENI_FINAL.c
>>>>>> This is the part of my program:
>>>>>>   ierr = MatCreateVecs(L,&vr,NULL);CHKERRQ(ierr);
>>>>>>   ierr = EPSGetEigenpair(eps,0,&kr,NULL,vr,NULL);
>>>>>>   ierr = PetscPrintf(PETSC_COMM_WORLD," The second smallest
>>>>>> eigenvalue: %g\n",kr);CHKERRQ(ierr);
>>>>>>   /* sort second smallest eigenvector */
>>>>>>   ierr = VecGetSize(vr,&siz);CHKERRQ(ierr);
>>>>>>   ierr = PetscMalloc1(siz,&idx);CHKERRQ(ierr);
>>>>>>   for (i=0; i<siz;i++) idx[i] = i;
>>>>>>   VecScatter ctx;
>>>>>>   Vec vout;
>>>>>>   VecScatterCreateToAll(vr,&ctx,&vout);
>>>>>>   VecScatterBegin(ctx,vr,vout,INSERT_VALUES,SCATTER_FORWARD);
>>>>>>   VecScatterEnd(ctx,vr,vout,INSERT_VALUES,SCATTER_FORWARD);
>>>>>>   VecScatterDestroy(&ctx);
>>>>>>   PetscScalar *avr;
>>>>>>   ierr = VecGetArray(vout,&avr);CHKERRQ(ierr);
>>>>>>   ierr = PetscSortRealWithPermutation(siz,avr,idx);CHKERRQ(ierr);
>>>>>>   /*Select out a piece of the resulting indices idx on each process;
>>>>>> for example with two processes I think rank = 0 would get the first half of
>>>>>> the idx and rank = 1 would get the second half.*/
>>>>>>   PetscMPIInt rank,size;
>>>>>>   MPI_Comm_rank(PETSC_COMM_WORLD, &rank);
>>>>>>   MPI_Comm_size(PETSC_COMM_WORLD, &size);
>>>>>>   PetscInt mod;
>>>>>>   mod = siz % size;
>>>>>>   PetscInt *idxx,ss;
>>>>>>   ss = (siz-mod)/size;
>>>>>>   if (mod != 0){
>>>>>>     if (rank<mod){
>>>>>>         PetscMalloc1(ss+1,&idxx);
>>>>>>     } else{
>>>>>>         PetscMalloc1(ss,&idxx);
>>>>>>   } else{
>>>>>>     j =0;
>>>>>>     for (i=rank*ss; i<(rank+1)*ss; i++) {
>>>>>>       idxx[j] = idx[i];
>>>>>>      //PetscPrintf(PETSC_COMM_WORLD," idxx: %D\n",idxx[j]);
>>>>>>       j++;
>>>>>>   if (mod != 0){
>>>>>>     if (rank<mod){
>>>>>>         idxx[ss+1] = idx[ss*size+rank+1];
>>>>>>   /*Permute matrix L (spy(A(p1,p1))*/
>>>>>>     if (mod != 0){
>>>>>>         if (rank<mod){
>>>>>>             ierr =
>>>>>> ISCreateGeneral(PETSC_COMM_WORLD,ss+1,idxx,PETSC_COPY_VALUES,&is);CHKERRQ(ierr);
>>>>>>         } else{
>>>>>>             ierr =
>>>>>> ISCreateGeneral(PETSC_COMM_WORLD,ss,idxx,PETSC_COPY_VALUES,&is);CHKERRQ(ierr);
>>>>>>     }else {
>>>>>>         ierr =
>>>>>>   ierr = ISSetPermutation(is);CHKERRQ(ierr);
>>>>>>   ierr = MatPermute(A,is,is,&PL);CHKERRQ(ierr);
>>>>>> I printed IS and idxx, IS is a permutation and numbers seem to be
>>>>>> correct. The program also works when mod==0.
>>>>>> Thanks,
>>>>>> Eda
>>>>>> Stefano Zampini <stefano.zampini at gmail.com>, 22 Nis 2019 Pzt, 18:13
>>>>>>> If you are using PETSC_DECIDE for the local sizes in MatSetSizes,
>>>>>>> the default local sizes should be 2127 and 2126.
>>>>>>> Il giorno lun 22 apr 2019 alle ore 11:28 Eda Oktay via petsc-users <
>>>>>>> petsc-users at mcs.anl.gov> ha scritto:
>>>>>>>> Thank you for your answers. I figured out that for a matrix of size
>>>>>>>> 4253*4253, local size of Mat is 2127 and 2127 for 2 processors. However, I
>>>>>>>> wrote the program such that the local sizes of IS 2127 and 2126.
>>>>>>>> Is local size of Mat being 2127 on both processors correct? If it
>>>>>>>> is, then I will change the local size of IS but then it will exceed the
>>>>>>>> global size of Mat. Isn't this also a problem?
>>>>>>>> Thanks a lot,
>>>>>>>> Eda
>>>>>>>> Smith, Barry F. <bsmith at mcs.anl.gov>, 9 Nis 2019 Sal, 00:31
>>>>>>>>>   Suggest printing out the IS with ISView after it is created and
>>>>>>>>> confirming that 1) it is a permutation and 2) that the size of the IS on
>>>>>>>>> each process matches the number of rows on that process.
>>>>>>>>>   Note from the manual page: The index sets should be on the same
>>>>>>>>> communicator as Mat and have the same local sizes.
>>>>>>>>> Barry
>>>>>>>>> > On Apr 8, 2019, at 3:21 AM, Eda Oktay via petsc-users <
>>>>>>>>> > Hello again,
>>>>>>>>> > I solved the problem for even numbered sized matrices. However
>>>>>>>>> when the matrix size is odd, then number of elements in each index set at
>>>>>>>>> each processor are different. (For example, for size 4253*4253 and 2
>>>>>>>>> processors, size of index set at processor 0 is 2127 where at processor 1,
>>>>>>>>> it is 2126) I think this is why, MatPermute again gives the same "Argument
>>>>>>>>> out of range" error. Index sets look like correct but I still did not get
>>>>>>>>> why I get this error.
>>>>>>>>> >   PetscInt mod;
>>>>>>>>> >   mod = siz % size;
>>>>>>>>> >   PetscInt *idxx,ss;
>>>>>>>>> >   if (mod != 0){
>>>>>>>>> >     if (rank<mod){
>>>>>>>>> >     } else{
>>>>>>>>> >   if (rank != size-1) {
>>>>>>>>> >     j =0;
>>>>>>>>> >       idxx[j] = idx[i];
>>>>>>>>> >       j++;
>>>>>>>>> >   } else {
>>>>>>>>> >     j =0;
>>>>>>>>> >     for (i=rank*ss; i<siz; i++) {
>>>>>>>>> >       idxx[j] = idx[i];
>>>>>>>>> >       j++;
>>>>>>>>> >   if (mod != 0){
>>>>>>>>> >     if (rank<mod){
>>>>>>>>> >     if (mod != 0){
>>>>>>>>> >     if (rank<mod){
>>>>>>>>> >         ierr =
>>>>>>>>> >     } else{
>>>>>>>>> >         ierr =
>>>>>>>>> > And I get the following error even if I use MatSetOption :
>>>>>>>>> > [0]PETSC ERROR: --------------------- Error Message
>>>>>>>>> > [0]PETSC ERROR: New nonzero at (0,4252) caused a malloc
>>>>>>>>> > Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE)
>>>>>>>>> to turn off this check
>>>>>>>>> > [0]PETSC ERROR: See
>>>>>>>>> shooting.
>>>>>>>>> > [0]PETSC ERROR: ./SON_YENI_DENEME_TEMIZ_ENYENI_FINAL on a
>>>>>>>>> arch-linux2-c-debug named dd2b.wls.metu.edu.tr by edaoktay Mon
>>>>>>>>> Apr  8 11:10:59 2019
>>>>>>>>> > [0]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 617 in
>>>>>>>>> > [0]PETSC ERROR: #2 MatSetValues() line 1349 in
>>>>>>>>> > [0]PETSC ERROR: #3 MatPermute_MPIAIJ() line 1714 in
>>>>>>>>> > [0]PETSC ERROR: #4 MatPermute() line 4997 in
>>>>>>>>> > [0]PETSC ERROR: #5 main() line 352 in
>>>>>>>>> /home/edaoktay/petsc-3.10.3/arch-linux2-c-debug/share/slepc/examples/src/eda/SON_YENI_DENEME_TEMIZ_ENYENI_FINAL.c
>>>>>>>>> > [0]PETSC ERROR: PETSc Option Table entries:
>>>>>>>>> > [0]PETSC ERROR: -f
>>>>>>>>> /home/edaoktay/petsc-3.10.3/share/petsc/datafiles/matrices/binary_files/airfoil1_binary
>>>>>>>>> > [0]PETSC ERROR: -mat_partitioning_type parmetis
>>>>>>>>> > [0]PETSC ERROR: -unweighted
>>>>>>>>> > [0]PETSC ERROR: ----------------End of Error Message -------send
>>>>>>>>> entire error message to petsc-maint at mcs.anl.gov----------
>>>>>>>>> > Thanks!
>>>>>>>>> > Eda
>>>>>>>>> > Eda Oktay <eda.oktay at metu.edu.tr>, 25 Mar 2019 Pzt, 13:53
>>>>>>>>> > I attached whole program I wrote where the problem is in line
>>>>>>>>> 285. One of the matrices I used was airfoil1_binary, included in the
>>>>>>>>> folder. Also, I included makefile. Is that what you want?
>>>>>>>>> > Matthew Knepley <knepley at gmail.com>, 25 Mar 2019 Pzt, 13:41
>>>>>>>>> > That should not happen. Can you send in a small example that we
>>>>>>>>> can debug.
>>>>>>>>> >   Thanks,
>>>>>>>>> >     Matt
>>>>>>>>> > On Mon, Mar 25, 2019 at 12:38 AM Eda Oktay via petsc-users <
>>>>>>>>> > Hello,
>>>>>>>>> > I am trying to permute a vector A using following lines:
>>>>>>>>> > ierr =
>>>>>>>>> ISCreateGeneral(PETSC_COMM_SELF,siz,idx,PETSC_COPY_VALUES,&is);CHKERRQ(ierr);
>>>>>>>>> >   ierr = ISDuplicate(is,&newIS);CHKERRQ(ierr);
>>>>>>>>> >   ierr =
>>>>>>>>> MatSetOption(A,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_FALSE);CHKERRQ(ierr);
>>>>>>>>> >   ierr = MatPermute(A,is,newIS,&PL);CHKERRQ(ierr);
>>>>>>>>> > However, in MatPermute line, I get the following error even if I
>>>>>>>>> used MatSetOption before this line:
>>>>>>>>> > [0]PETSC ERROR: New nonzero at (0,485) caused a malloc
>>>>>>>>> > [0]PETSC ERROR: See
>>>>>>>>> shooting.
>>>>>>>>> > [0]PETSC ERROR: ./DENEME_TEMIZ_ENYENI_FINAL on a
>>>>>>>>> arch-linux2-c-debug named 1232.wls.metu.edu.tr by edaoktay Mon
>>>>>>>>> Mar 25 12:15:14 2019
>>>>>>>>> > [0]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 579 in
>>>>>>>>> > [0]PETSC ERROR: #2 MatAssemblyEnd_MPIAIJ() line 807 in
>>>>>>>>> > [0]PETSC ERROR: #3 MatAssemblyEnd() line 5340 in
>>>>>>>>> > [0]PETSC ERROR: #4 MatPermute_MPIAIJ() line 1723 in
>>>>>>>>> > [0]PETSC ERROR: #5 MatPermute() line 4997 in
>>>>>>>>> > [0]PETSC ERROR: #6 main() line 285 in
>>>>>>>>> /home/edaoktay/petsc-3.10.3/arch-linux2-c-debug/share/slepc/examples/src/eda/DENEME_TEMIZ_ENYENI_FINAL.c
>>>>>>>>> > [0]PETSC ERROR: -f
>>>>>>>>> > [0]PETSC ERROR: -weighted
>>>>>>>>> > I'll be glad if you can help me.
>>>>>>>>> > Thanks!
>>>>>>>>> > Eda
>>>>>>>>> > What most experimenters take for granted before they begin their
>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>> experiments lead.
>>>>>>>>> > -- Norbert Wiener
>>>>>>>>> > https://www.cse.buffalo.edu/~knepley/
>>>>>>> Stefano
>>>>> Stefano
>>> Stefano
>> experiments lead.
>> -- Norbert Wiener
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190424/077aecd6/attachment-0001.html>
