[petsc-users] Argument out of range error in MatPermute
Stefano Zampini
stefano.zampini at gmail.com
Wed Apr 24 05:34:34 CDT 2019
Dump the index sets and the matrix in binary and send them
Il giorno mer 24 apr 2019 alle ore 13:21 Eda Oktay <eda.oktay at metu.edu.tr>
ha scritto:
> Since I am using square matrix, isn't the row local size of the matrix
> equal to the local size of IS? They are both 2127 and 2126.
> Stefano Zampini <stefano.zampini at gmail.com>, 24 Nis 2019 Çar, 13:15
> tarihinde şunu yazdı:
>> I don't understand your code. However, I suspect we have a bug here
>> https://bitbucket.org/petsc/petsc/src/dba4d5898a4236b42fbe8dff209f1243d2f2582a/src/mat/impls/aij/mpi/mpiaij.c#lines-1652
>> The code assumes the number of leaves is A->rmap->n (the row local size
>> of the matrix). Shouldn't this be the local size of the IS (rowp)? Barry?
>> Il giorno mer 24 apr 2019 alle ore 13:03 Eda Oktay <eda.oktay at metu.edu.tr>
>> ha scritto:
>>> Dear Stefano,
>>> Thank you for answering. When I used MatSetSizes, I got an error since
>>> the matrix is read from outside, but from the error I understood that
>>> actually the local sizes are 2127 and 2126, so I misunderstood the problem.
>>> I am sorry for my mistake.
>>> However, I still cannot understand where is the error. Because both
>>> communicators and local sizes of IS and the matrix are the same. I still
>>> get the same error in MatPermute:
>>> [0]PETSC ERROR: Argument out of range
>>> [0]PETSC ERROR: Index -1081207334 is out of range
>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>> for trouble shooting.
>>> [0]PETSC ERROR: Petsc Release Version 3.10.3, Dec, 18, 2018
>>> [0]PETSC ERROR: ./TEKRAR_TEK_SAYI_SON_YENI_DENEME_TEMIZ_ENYENI_FINAL on
>>> a arch-linux2-c-debug named 53d.wls.metu.edu.tr by edaoktay Wed Apr 24
>>> 11:22:15 2019
>>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>>> --with-fc=gfortran --with-cxx-dialect=C++11 --download-openblas
>>> --download-metis --download-parmetis --download-superlu_dist
>>> --download-slepc --download-mpich
>>> [0]PETSC ERROR: #1 PetscLayoutFindOwner() line 248 in
>>> /home/edaoktay/petsc-3.10.3/include/petscis.h
>>> [0]PETSC ERROR: #2 MatPermute_MPIAIJ() line 1685 in
>>> /home/edaoktay/petsc-3.10.3/src/mat/impls/aij/mpi/mpiaij.c
>>> [0]PETSC ERROR: #3 MatPermute() line 4997 in
>>> /home/edaoktay/petsc-3.10.3/src/mat/interface/matrix.c
>>> [0]PETSC ERROR: #4 main() line 361 in
>>> /home/edaoktay/petsc-3.10.3/arch-linux2-c-debug/share/slepc/examples/src/eda/TEKRAR_TEK_SAYI_SON_YENI_DENEME_TEMIZ_ENYENI_FINAL.c
>>> This is the part of my program:
>>> ierr = MatCreateVecs(L,&vr,NULL);CHKERRQ(ierr);
>>> ierr = EPSGetEigenpair(eps,0,&kr,NULL,vr,NULL);
>>> ierr = PetscPrintf(PETSC_COMM_WORLD," The second smallest eigenvalue:
>>> %g\n",kr);CHKERRQ(ierr);
>>> /* sort second smallest eigenvector */
>>> ierr = VecGetSize(vr,&siz);CHKERRQ(ierr);
>>> ierr = PetscMalloc1(siz,&idx);CHKERRQ(ierr);
>>> for (i=0; i<siz;i++) idx[i] = i;
>>> VecScatter ctx;
>>> Vec vout;
>>> VecScatterCreateToAll(vr,&ctx,&vout);
>>> VecScatterBegin(ctx,vr,vout,INSERT_VALUES,SCATTER_FORWARD);
>>> VecScatterEnd(ctx,vr,vout,INSERT_VALUES,SCATTER_FORWARD);
>>> VecScatterDestroy(&ctx);
>>> PetscScalar *avr;
>>> ierr = VecGetArray(vout,&avr);CHKERRQ(ierr);
>>> ierr = PetscSortRealWithPermutation(siz,avr,idx);CHKERRQ(ierr);
>>> /*Select out a piece of the resulting indices idx on each process; for
>>> example with two processes I think rank = 0 would get the first half of the
>>> idx and rank = 1 would get the second half.*/
>>> PetscMPIInt rank,size;
>>> MPI_Comm_rank(PETSC_COMM_WORLD, &rank);
>>> MPI_Comm_size(PETSC_COMM_WORLD, &size);
>>> PetscInt mod;
>>> mod = siz % size;
>>> PetscInt *idxx,ss;
>>> ss = (siz-mod)/size;
>>> if (mod != 0){
>>> if (rank<mod){
>>> PetscMalloc1(ss+1,&idxx);
>>> } else{
>>> PetscMalloc1(ss,&idxx);
>>> } else{
>>> j =0;
>>> for (i=rank*ss; i<(rank+1)*ss; i++) {
>>> idxx[j] = idx[i];
>>> //PetscPrintf(PETSC_COMM_WORLD," idxx: %D\n",idxx[j]);
>>> j++;
>>> if (mod != 0){
>>> if (rank<mod){
>>> idxx[ss+1] = idx[ss*size+rank+1];
>>> /*Permute matrix L (spy(A(p1,p1))*/
>>> if (mod != 0){
>>> if (rank<mod){
>>> ierr =
>>> ISCreateGeneral(PETSC_COMM_WORLD,ss+1,idxx,PETSC_COPY_VALUES,&is);CHKERRQ(ierr);
>>> } else{
>>> ierr =
>>> ISCreateGeneral(PETSC_COMM_WORLD,ss,idxx,PETSC_COPY_VALUES,&is);CHKERRQ(ierr);
>>> }else {
>>> ierr =
>>> ierr = ISSetPermutation(is);CHKERRQ(ierr);
>>> ierr = MatPermute(A,is,is,&PL);CHKERRQ(ierr);
>>> I printed IS and idxx, IS is a permutation and numbers seem to be
>>> correct. The program also works when mod==0.
>>> Thanks,
>>> Eda
>>> Stefano Zampini <stefano.zampini at gmail.com>, 22 Nis 2019 Pzt, 18:13
>>>> If you are using PETSC_DECIDE for the local sizes in MatSetSizes, the
>>>> default local sizes should be 2127 and 2126.
>>>> Il giorno lun 22 apr 2019 alle ore 11:28 Eda Oktay via petsc-users <
>>>> petsc-users at mcs.anl.gov> ha scritto:
>>>>> Thank you for your answers. I figured out that for a matrix of size
>>>>> 4253*4253, local size of Mat is 2127 and 2127 for 2 processors. However, I
>>>>> wrote the program such that the local sizes of IS 2127 and 2126.
>>>>> Is local size of Mat being 2127 on both processors correct? If it is,
>>>>> then I will change the local size of IS but then it will exceed the global
>>>>> size of Mat. Isn't this also a problem?
>>>>> Thanks a lot,
>>>>> Eda
>>>>> Smith, Barry F. <bsmith at mcs.anl.gov>, 9 Nis 2019 Sal, 00:31 tarihinde
>>>>> şunu yazdı:
>>>>>> Suggest printing out the IS with ISView after it is created and
>>>>>> confirming that 1) it is a permutation and 2) that the size of the IS on
>>>>>> each process matches the number of rows on that process.
>>>>>> Note from the manual page: The index sets should be on the same
>>>>>> communicator as Mat and have the same local sizes.
>>>>>> Barry
>>>>>> > On Apr 8, 2019, at 3:21 AM, Eda Oktay via petsc-users <
>>>>>> petsc-users at mcs.anl.gov> wrote:
>>>>>> > Hello again,
>>>>>> > I solved the problem for even numbered sized matrices. However when
>>>>>> the matrix size is odd, then number of elements in each index set at each
>>>>>> processor are different. (For example, for size 4253*4253 and 2 processors,
>>>>>> size of index set at processor 0 is 2127 where at processor 1, it is 2126)
>>>>>> I think this is why, MatPermute again gives the same "Argument out of
>>>>>> range" error. Index sets look like correct but I still did not get why I
>>>>>> get this error.
>>>>>> > PetscInt mod;
>>>>>> > mod = siz % size;
>>>>>> > PetscInt *idxx,ss;
>>>>>> > if (mod != 0){
>>>>>> > if (rank<mod){
>>>>>> > } else{
>>>>>> > if (rank != size-1) {
>>>>>> > j =0;
>>>>>> > idxx[j] = idx[i];
>>>>>> > j++;
>>>>>> > } else {
>>>>>> > j =0;
>>>>>> > for (i=rank*ss; i<siz; i++) {
>>>>>> > idxx[j] = idx[i];
>>>>>> > j++;
>>>>>> > if (mod != 0){
>>>>>> > if (rank<mod){
>>>>>> > if (mod != 0){
>>>>>> > if (rank<mod){
>>>>>> > ierr =
>>>>>> > } else{
>>>>>> > ierr =
>>>>>> > And I get the following error even if I use MatSetOption :
>>>>>> > [0]PETSC ERROR: --------------------- Error Message
>>>>>> > [0]PETSC ERROR: New nonzero at (0,4252) caused a malloc
>>>>>> > Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to
>>>>>> turn off this check
>>>>>> > [0]PETSC ERROR: See
>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>>>> shooting.
>>>>>> > [0]PETSC ERROR: ./SON_YENI_DENEME_TEMIZ_ENYENI_FINAL on a
>>>>>> arch-linux2-c-debug named dd2b.wls.metu.edu.tr by edaoktay Mon Apr
>>>>>> 8 11:10:59 2019
>>>>>> > [0]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 617 in
>>>>>> > [0]PETSC ERROR: #2 MatSetValues() line 1349 in
>>>>>> > [0]PETSC ERROR: #3 MatPermute_MPIAIJ() line 1714 in
>>>>>> > [0]PETSC ERROR: #4 MatPermute() line 4997 in
>>>>>> > [0]PETSC ERROR: #5 main() line 352 in
>>>>>> /home/edaoktay/petsc-3.10.3/arch-linux2-c-debug/share/slepc/examples/src/eda/SON_YENI_DENEME_TEMIZ_ENYENI_FINAL.c
>>>>>> > [0]PETSC ERROR: PETSc Option Table entries:
>>>>>> > [0]PETSC ERROR: -f
>>>>>> /home/edaoktay/petsc-3.10.3/share/petsc/datafiles/matrices/binary_files/airfoil1_binary
>>>>>> > [0]PETSC ERROR: -mat_partitioning_type parmetis
>>>>>> > [0]PETSC ERROR: -unweighted
>>>>>> > [0]PETSC ERROR: ----------------End of Error Message -------send
>>>>>> entire error message to petsc-maint at mcs.anl.gov----------
>>>>>> > Thanks!
>>>>>> > Eda
>>>>>> > Eda Oktay <eda.oktay at metu.edu.tr>, 25 Mar 2019 Pzt, 13:53
>>>>>> > I attached whole program I wrote where the problem is in line 285.
>>>>>> One of the matrices I used was airfoil1_binary, included in the folder.
>>>>>> Also, I included makefile. Is that what you want?
>>>>>> > Matthew Knepley <knepley at gmail.com>, 25 Mar 2019 Pzt, 13:41
>>>>>> > That should not happen. Can you send in a small example that we can
>>>>>> debug.
>>>>>> > Thanks,
>>>>>> > Matt
>>>>>> > On Mon, Mar 25, 2019 at 12:38 AM Eda Oktay via petsc-users <
>>>>>> > Hello,
>>>>>> > I am trying to permute a vector A using following lines:
>>>>>> > ierr =
>>>>>> ISCreateGeneral(PETSC_COMM_SELF,siz,idx,PETSC_COPY_VALUES,&is);CHKERRQ(ierr);
>>>>>> > ierr = ISDuplicate(is,&newIS);CHKERRQ(ierr);
>>>>>> > ierr =
>>>>>> MatSetOption(A,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_FALSE);CHKERRQ(ierr);
>>>>>> > ierr = MatPermute(A,is,newIS,&PL);CHKERRQ(ierr);
>>>>>> > However, in MatPermute line, I get the following error even if I
>>>>>> used MatSetOption before this line:
>>>>>> > [0]PETSC ERROR: New nonzero at (0,485) caused a malloc
>>>>>> turn off this check
>>>>>> > [0]PETSC ERROR: See
>>>>>> shooting.
>>>>>> > [0]PETSC ERROR: ./DENEME_TEMIZ_ENYENI_FINAL on a
>>>>>> arch-linux2-c-debug named 1232.wls.metu.edu.tr by edaoktay Mon Mar
>>>>>> 25 12:15:14 2019
>>>>>> > [0]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 579 in
>>>>>> > [0]PETSC ERROR: #2 MatAssemblyEnd_MPIAIJ() line 807 in
>>>>>> > [0]PETSC ERROR: #3 MatAssemblyEnd() line 5340 in
>>>>>> > [0]PETSC ERROR: #4 MatPermute_MPIAIJ() line 1723 in
>>>>>> > [0]PETSC ERROR: #5 MatPermute() line 4997 in
>>>>>> > [0]PETSC ERROR: #6 main() line 285 in
>>>>>> /home/edaoktay/petsc-3.10.3/arch-linux2-c-debug/share/slepc/examples/src/eda/DENEME_TEMIZ_ENYENI_FINAL.c
>>>>>> > [0]PETSC ERROR: -f
>>>>>> > [0]PETSC ERROR: -weighted
>>>>>> > I'll be glad if you can help me.
>>>>>> > Thanks!
>>>>>> > Eda
>>>>>> > What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> > -- Norbert Wiener
>>>>>> > https://www.cse.buffalo.edu/~knepley/
>>>> Stefano
>> Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190424/a540f622/attachment-0001.html>
