[petsc-users] Possible Bug ?
Sajid Ali sajidsyed2021 at u.northwestern.edu
Mon Apr 22 18:05:13 CDT 2019
Hi Barry,
I'm not sure why MatCreateVecsFFW is not used at line 50/51.
The error occurs at line 94 because in the second loop, the example
manually creates the x vector instead of the one created using the A
matrix. For complex numbers this is not an issue but for real numbers the
dimensions don't match. MatCreateVecsFFTW creates a vector of size 20 for
N=10 but VecCreateSeq is creating a vector of size 10. I'm not sure what
the rationale behind this test is.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190422/52bcf921/attachment.html>
