[petsc-users] Possible Bug ?
Sajid Ali sajidsyed2021 at u.northwestern.edu
Mon Apr 22 17:00:38 CDT 2019
I see that src/mat/examples/tests/ex112.c is failing for petsc at 3.11.1
configured without complex scalars. With complex scalars everything works
fine.
The error I see is :
[sajid at xrmlite bugfix]$
./ex112
No protocol
specified
 1-D: FFTW on vector of size
10
  Error norm of |x - z|
5.37156
5.90871
5.96243
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Nonconforming object
sizes
[0]PETSC ERROR: Mat mat,Vec x: global dim 20
10
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.11.1, Apr, 12,
[0]PETSC ERROR: ./ex112 on a  named xrmlite.phys.northwestern.edu by sajid
Mon Apr 22 16:58:41 2019
[0]PETSC ERROR: Configure options
--prefix=/home/sajid/packages/spack/opt/spack/linux-centos7-x86_64/gcc-8.3.0/petsc-3.11.1-5bdbcozu3labtbbi7gtq4xa
knay24lo6 --with-ssl=0 --download-c2html=0 --download-sowing=0
--download-hwloc=0 CFLAGS="-O2 -march=native" FFLAGS="-O2 -march=native"
CXXFLAGS="-
O2 -march=native"
--with-cc=/home/sajid/packages/spack/opt/spack/linux-centos7-x86_64/gcc-8.3.0/mpich-3.3-ig4cr2xw2x63bqs5rnmhfshln4iv7av5/bin/mpic
c
--with-cxx=/home/sajid/packages/spack/opt/spack/linux-centos7-x86_64/gcc-8.3.0/mpich-3.3-ig4cr2xw2x63bqs5rnmhfshln4iv7av5/bin/mpic++
--with-fc=/h
ome/sajid/packages/spack/opt/spack/linux-centos7-x86_64/gcc-8.3.0/mpich-3.3-ig4cr2xw2x63bqs5rnmhfshln4iv7av5/bin/mpif90
--with-precision=double --w
ith-scalar-type=real --with-shared-libraries=1 --with-debugging=1
--with-64-bit-indices=0
--with-blaslapack-lib="/home/sajid/packages/spack/opt/spa
ck/linux-centos7-x86_64/gcc-8.3.0/intel-mkl-2019.3.199-kzcly5rtcjbkwtnm6tri6kkexnwoat5m/compilers_and_libraries_2019.3.199/linux/mkl/lib/intel64/li
bmkl_intel_lp64.so
/home/sajid/packages/spack/opt/spack/linux-centos7-x86_64/gcc-8.3.0/intel-mkl-2019.3.199-kzcly5rtcjbkwtnm6tri6kkexnwoat5m/compil
ers_and_libraries_2019.3.199/linux/mkl/lib/intel64/libmkl_sequential.so
kl-2019.3.199-kzcly5rtcjbkwtnm6tri6kkexnwoat5m/compilers_and_libraries_2019.3.199/linux/mkl/lib/intel64/libmkl_core.so
/lib64/libpthread.so /lib64/
libm.so /lib64/libdl.so" --with-x=0 --with-clanguage=C --with-scalapack=0
--with-metis=0 --with-hdf5=0 --with-hypre=0 --with-parmetis=0 --with-mump
s=0 --with-trilinos=0 --with-fftw=1
--with-fftw-dir=/home/sajid/packages/spack/opt/spack/linux-centos7-x86_64/gcc-8.3.0/fftw-3.3.8-mkj4ho2jp6xfrnkl
mrvhdfh73woer2s7 --with-superlu_dist=0 --with-suitesparse=0
--with-zlib-include=/home/sajid/packages/spack/opt/spack/linux-centos7-x86_64/gcc-8.3.0
/zlib-1.2.11-jqrcjdjnrxvouufhjtxbfvfms23fsqpx/include
--with-zlib-lib="-L/home/sajid/packages/spack/opt/spack/linux-centos7-x86_64/gcc-8.3.0/zlib-1
.2.11-jqrcjdjnrxvouufhjtxbfvfms23fsqpx/lib -lz"
--with-zlib=1
[0]PETSC ERROR: #1 MatMult() line 2385 in
/tmp/sajid/spack-stage/spack-stage-mTD0AV/petsc-3.11.1/src/mat/interface/matrix.c
[0]PETSC ERROR: #2 main() line 94 in
/home/sajid/packages/aux_xwp_petsc/bugfix/ex112.c
[0]PETSC ERROR: No PETSc Option Table
entries
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 60) - process
0
[unset]: write_line error; fd=-1 buf=:cmd=abort
exitcode=60
system msg for write_line failure : Bad file
descriptor
I came across this because I saw that MatMult was failing for a new test
related to a PR I was working on. Is this a bug ?
Thank You,
Sajid Ali
Applied Physics
Northwestern University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190422/90bac681/attachment.html>
