[petsc-users] VecView to hdf5 broken for large (complex) vectors
Wed Apr 17 06:49:55 CDT 2019
On Wed, Apr 17, 2019 at 2:40 AM Smith, Barry F. via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> > On Apr 17, 2019, at 1:35 AM, Balay, Satish <balay at mcs.anl.gov> wrote:
> > On Wed, 17 Apr 2019, Smith, Barry F. via petsc-users wrote:
> >>  This is fine for "hacking" on PETSc but worthless for any other
> package. Here is my concern, when someone
> >> realizes there is a problem with a package they are using through a
> package manager they think, crud I have to
> >> 1) find the git repository for this package
> >> 2) git clone the package
> >> 3) figure out how to build the package from source, is it ./configure,
> cmake, what are the needed arguments,...
> >> 4) wait for the entire thing to build
> >> then I can go in and investigate the problem and provide and test the
> fix via a pull request. Heck I'm not going to bother.
> >> Thus a lot of potential contributions of small fixes that everyone in
> the community would benefit from are lost. This is why, for
> >> me, an ideal HPC package manager provides a trivial process for
> providing fixes/improvements to other packages.
> >> For example Sajid could have easily figured out the VecView_MPI_HDF5()
> bug and provided a fix but just the hassle of
> >> logistics (not ability to solve the problem) prevented him from
> providing the bug fix to everyone rapidly.
>    I never said that any current practices are better than using spack! It
> is just that perhaps
> with a few tweaks spack could provide a way to fundamentally improve our
> current practices (which are, as you acknowledge cumbersome).
This sounds like a hopeless pipedream. But maybe.
   Matt
>    Barry
> > Even without spack and multiple packages - this is not a easy thing to
> > do. For ex: most of our users install petsc from tarball.
> > And if they find a bug - they have to go through similar complicated
> > process [create a bitbucket account, get a fork - learn the petsc PR
> > process - make a PR etc].
> > With spack - I stick to the usual process - and don't get bogged down
> > by 'spack' support for this process.
> > If I see a breakage - I do 'spack build-env package [this has its own
> > issues] - attempt a fix - get it first working with a spack build.
> > [Alternative is to just edit the package file to get my fix - if its a
> patch I can find]
> > Once I have it working [the major issue is taken care off]. Then I
> > have a diff/patch and then worry about how to submit this diff/patch
> > to upstream.
> > Sure its a multi step model - and has many trip points. But is not
> > that our current petsc only model doesn't have any.
> > Satish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190417/fe641546/attachment-0001.html>
