[petsc-users] VecView to hdf5 broken for large (complex) vectors
Balay, Satish balay at mcs.anl.gov
Wed Apr 17 01:35:31 CDT 2019
On Wed, 17 Apr 2019, Smith, Barry F. via petsc-users wrote:
>   This is fine for "hacking" on PETSc but worthless for any other package. Here is my concern, when someone
> realizes there is a problem with a package they are using through a package manager they think, crud I have to
> 1) find the git repository for this package
> 2) git clone the package
> 3) figure out how to build the package from source, is it ./configure, cmake, what are the needed arguments,...
> 4) wait for the entire thing to build
> then I can go in and investigate the problem and provide and test the fix via a pull request. Heck I'm not going to bother.
> Thus a lot of potential contributions of small fixes that everyone in the community would benefit from are lost. This is why, for
> me, an ideal HPC package manager provides a trivial process for providing fixes/improvements to other packages.
> For example Sajid could have easily figured out the VecView_MPI_HDF5() bug and provided a fix but just the hassle of
> logistics (not ability to solve the problem) prevented him from providing the bug fix to everyone rapidly.
Even without spack and multiple packages - this is not a easy thing to
do. For ex: most of our users install petsc from tarball.
And if they find a bug - they have to go through similar complicated
process [create a bitbucket account, get a fork - learn the petsc PR
process - make a PR etc].
With spack - I stick to the usual process - and don't get bogged down
by 'spack' support for this process.
If I see a breakage - I do 'spack build-env package [this has its own
issues] - attempt a fix - get it first working with a spack build.
[Alternative is to just edit the package file to get my fix - if its a patch I can find]
Once I have it working [the major issue is taken care off]. Then I
have a diff/patch and then worry about how to submit this diff/patch
to upstream.
Sure its a multi step model - and has many trip points. But is not
that our current petsc only model doesn't have any.
Satish
