[petsc-users] Using -malloc_dump to examine memory leak
Smith, Barry F. bsmith at mcs.anl.gov
Wed Apr 17 00:59:46 CDT 2019
  Please remember to respond-to-all in your emails, otherwise the mail comes only to me and I may not have full information to respond to your queries correctly.
> On Apr 16, 2019, at 11:56 PM, Yuyun Yang <yyang85 at stanford.edu> wrote:
> So using -objects_dump showed nothing below the line:
> The following objects were never freed
> Does that mean I’ve freed all the objects? If so, why would -malloc_dump give me a bunch of messages?
  No idea. If you have messages from -malloc_dump then memory has not been freed and almost always this is due to undestroyed objects. Presumably you didn't turn off logging in ./configure (nobody does that). If you use the option -objects_dump this is processed in PetscOptionsCheckInitial_Private() which is called from PetscInitialize() with
#if defined(PETSC_USE_LOG)
  ierr = PetscOptionsHasName(NULL,NULL,"-objects_dump",&PetscObjectsLog);CHKERRQ(ierr);
#endif
then in inherit.c each object creation gets logged with
PetscErrorCode  PetscHeaderCreate_Private(PetscObject h,PetscClassId classid,const char class_name[],const char descr[],const char mansec[],
                                          MPI_Comm comm,PetscObjectDestroyFunction destroy,PetscObjectViewFunction view)
  static PetscInt idcnt = 1;
  PetscErrorCode  ierr;
  PetscObject     *newPetscObjects;
  PetscInt         newPetscObjectsMaxCounts,i;
#endif
  PetscFunctionBegin;
  h->classid               = classid;
  h->type                  = 0;
  h->class_name            = (char*)class_name;
  h->description           = (char*)descr;
  h->mansec                = (char*)mansec;
  h->prefix                = 0;
  h->refct                 = 1;
#if defined(PETSC_HAVE_SAWS)
  h->amsmem                = PETSC_FALSE;
#endif
  h->id                    = idcnt++;
  h->parentid              = 0;
  h->qlist                 = 0;
  h->olist                 = 0;
  h->bops->destroy         = destroy;
  h->bops->view            = view;
  h->bops->getcomm         = PetscObjectGetComm_Petsc;
  h->bops->compose         = PetscObjectCompose_Petsc;
  h->bops->query           = PetscObjectQuery_Petsc;
  h->bops->composefunction = PetscObjectComposeFunction_Petsc;
  h->bops->queryfunction   = PetscObjectQueryFunction_Petsc;
  ierr = PetscCommDuplicate(comm,&h->comm,&h->tag);CHKERRQ(ierr);
  /* Keep a record of object created */
  if (PetscObjectsLog) {
    PetscObjectsCounts++;
    for (i=0; i<PetscObjectsMaxCounts; i++) {
      if (!PetscObjects[i]) {
        PetscObjects[i] = h;
        PetscFunctionReturn(0);
    /* Need to increase the space for storing PETSc objects */
    if (!PetscObjectsMaxCounts) newPetscObjectsMaxCounts = 100;
    else                        newPetscObjectsMaxCounts = 2*PetscObjectsMaxCounts;
    ierr = PetscMalloc1(newPetscObjectsMaxCounts,&newPetscObjects);CHKERRQ(ierr);
    ierr = PetscMemcpy(newPetscObjects,PetscObjects,PetscObjectsMaxCounts*sizeof(PetscObject));CHKERRQ(ierr);
    ierr = PetscMemzero(newPetscObjects+PetscObjectsMaxCounts,(newPetscObjectsMaxCounts - PetscObjectsMaxCounts)*sizeof(PetscObject));CHKERRQ(ierr);
    ierr = PetscFree(PetscObjects);CHKERRQ(ierr);
    PetscObjects                        = newPetscObjects;
    PetscObjects[PetscObjectsMaxCounts] = h;
    PetscObjectsMaxCounts               = newPetscObjectsMaxCounts;
#endif
Then in PetscFinalize()
       List all objects the user may have forgot to free
    ierr = PetscOptionsHasName(NULL,NULL,"-objects_dump",&flg1);CHKERRQ(ierr);
    if (flg1) {
      MPI_Comm local_comm;
      char     string[64];
      ierr = PetscOptionsGetString(NULL,NULL,"-objects_dump",string,64,NULL);CHKERRQ(ierr);
      ierr = MPI_Comm_dup(MPI_COMM_WORLD,&local_comm);CHKERRQ(ierr);
      ierr = PetscSequentialPhaseBegin_Private(local_comm,1);CHKERRQ(ierr);
      ierr = PetscObjectsDump(stdout,(string[0] == 'a') ? PETSC_TRUE : PETSC_FALSE);CHKERRQ(ierr);
      ierr = PetscSequentialPhaseEnd_Private(local_comm,1);CHKERRQ(ierr);
      ierr = MPI_Comm_free(&local_comm);CHKERRQ(ierr);
#endif
Very simple code.
Try
-objects_dump all
and see if that changes things. Otherwise you'll need to use the debugger to track why it is not printing out the undestroyed objects.
> I also ran valgrind, and am getting the following error when using --track-origins=yes:
> Uninitialised value was created by a stack allocation
> ==617==    at 0x417D66: ComputeVel_qd::computeVel(double*, double, int&, int) (fault.cpp:953)
> The first argument of this function is a Petsc array (obtained from VecGetArray, and after calling this function, VecRestoreArray was called on that same object). I can’t think of a way why valgrind thinks there is an uninitialized value. Is this by any chance related to the -malloc_dump messages?
  Should be unrelated to the -malloc_dump message.
  A "stack allocation" is usually a local variable, while the value from VecGetArray() is from the heap. Check the use of all your local variables in this function.
  Barry
> Thanks for your help on this.
> Best regards,
> Yuyun
> From: petsc-users <petsc-users-bounces at mcs.anl.gov> On Behalf Of Yuyun Yang via petsc-users
> Sent: Tuesday, April 16, 2019 7:30 AM
> To: Smith, Barry F. <bsmith at mcs.anl.gov>
> Cc: petsc-users at mcs.anl.gov
> Subject: Re: [petsc-users] Using -malloc_dump to examine memory leak
> Great, thank you for the advice!
> Best regards,
> Yuyun
> Get Outlook for iOS
> From: Smith, Barry F. <bsmith at mcs.anl.gov>
> Sent: Tuesday, April 16, 2019 5:54:15 AM
> To: Yuyun Yang
>   Please try the flag -options_dump this tries to give a much more concise view of what objects have not been freed. For example I commented
> out the last VecDestroy() in src/snes/examples/tutorials/ex19.c and then obtained:
> ./ex19 -objects_dump
> lid velocity = 0.0625, prandtl # = 1., grashof # = 1.
> Number of SNES iterations = 2
> [0] DM da DM_0x84000000_0
>       [0]  DMDACreate2d() in /Users/barrysmith/Src/petsc/src/dm/impls/da/da2.c
>       [0]  main() in /Users/barrysmith/Src/petsc/src/snes/examples/tutorials/ex19.c
> [0] Vec seq Vec_0x84000000_6
>       [0]  DMCreateGlobalVector() in /Users/barrysmith/Src/petsc/src/dm/interface/dm.c
> Now I just need to look at the calls to DMCreateGlobalVector and DMDACreate2d in main to see what I did not free.
> Note that since PETSc objects may hold references to other PETSc objects some items may not be freed for which you DID call destroy on.
> For example because the unfreed vector holds a reference to the DM the DM is listed as not freed. Once you properly destroy the vector you'll
> not that the DM is no longer listed as non freed.
> It can be a little overwhelming at first to figure out what objects have not been freed. We recommending setting the environmental variable
> export PETSC_OPTIONS=-malloc_test so that every run of your code reports memory issues and you can keep them under control from
> the beginning (when the code is small and growing) rather than wait until the code is large and there are many unfreed objects to chase down.
>    Good luck
>    Barry
> > On Apr 16, 2019, at 1:14 AM, Yuyun Yang via petsc-users <petsc-users at mcs.anl.gov> wrote:
> > Hello team,
> > I’m trying to use the options -malloc_dump and -malloc_debug to examine memory leaks. The messages however, are quite generic, and don’t really tell me where the problems occur, for example:
> > [ 0]1520 bytes VecCreate() line 35 in /home/yyy910805/petsc/src/vec/vec/interface/veccreate.c
> >       [0]  PetscMallocA() line 35 in /home/yyy910805/petsc/src/sys/memory/mal.c
> >       [0]  VecCreate() line 30 in /home/yyy910805/petsc/src/vec/vec/interface/veccreate.c
> >       [0]  VecDuplicate_Seq() line 804 in /home/yyy910805/petsc/src/vec/vec/impls/seq/bvec2.c
> >       [0]  VecDuplicate() line 375 in /home/yyy910805/petsc/src/vec/vec/interface/vector.c
> > The code is huge, so going through every single VecCreate/VecDuplicate and VecDestroy is going to be time-consuming. Meanwhile, running valgrind gave me some uninitialized values errors that don’t seem to be related to the above message (or maybe they are?).
> > How can I use this option to debug effectively?
> > Thanks a lot,
> > Yuyun
