[petsc-users] VecView to hdf5 broken for large (complex) vectors
Sajid Ali sajidsyed2021 at u.northwestern.edu
Tue Apr 16 14:43:44 CDT 2019
So, I tried running the debug version with valgrind to see if I can find
the chunk size that's being set but I don't see it. Is there a better way
to do it ?
`$ mpirun -np 32 valgrind ./ex_ms -prop_steps 1 -info &> out`. [The out
file is attached.]
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190416/757699c5/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190416/757699c5/attachment-0001.obj>
