[petsc-users] Error with VecDestroy_MPIFFTW+0x61
Mon Apr 15 18:57:54 CDT 2019
On Mon, Apr 15, 2019 at 2:44 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   There are two distinct issues here.
> 1) the use of fftw_malloc(). This is a relatively minor issue. This is
> causing the crash in the code because VecDuplicate() uses PetscMalloc() to
> obtain the array but when the array is freed fftw_malloc() is called on it.
> 2) the padding that FFTW needs in its vectors. Look at
> MatCreateVecsFFTW_FFTW() source code
>       alloc_local =
> fftw_mpi_local_size_1d(dim[0],comm,FFTW_FORWARD,FFTW_ESTIMATE,&local_n0,&local_0_start,&local_n1,&local_1_start);
>       if (fin) {
>         data_fin  =
> (fftw_complex*)fftw_malloc(sizeof(fftw_complex)*alloc_local);
>         ierr      = VecCreateMPIWithArray(comm,1,local_n0,N,(const
> PetscScalar*)data_fin,fin);CHKERRQ(ierr);
> Note that fftw_mpi_local_size_1d returns a "size" alloc_local  that is
> then passed into the fftw_malloc() which is then passed into
> VecCreateMPIWithArray(); this size is LARGER than local_n0 the local size
> of the MPI vector.  FFTW routines assume that "extra space" is available at
> the end of the arrays and use that as "work" space. The different fin,
> fout, bout have sometimes different local sizes and different amount of
> padding (see the code for exact details).
> When you call VecDuplicate() on an fin vector it doesn't know about the
> padding so creates a new vector with an array with only the size of
> local_n0, that is without any ghost padding in the end. If you pass this
> new vector into a FFTW routine it will access out of bounds memory and thus
> potentially crash or incorrect results.
> Note that if one replaced all the fftw_malloc() with PetscMalloc() the
> error described above would still be there. VecDuplicate() vectors would
> not have the extra padding they need.
> My proposed fixed outlined before resolves both problems at the same time.
But its complicated. What about making VecGhost for this? VecDuplicate
respects the ghost region.
   Matt
>    Barry
> Final note just to make it absolutely clear, the use of fftw_malloc() has
> nothing to with the extra padding at the end of the vector arrays! The
> extra padding is managed by the call to alloc_local =
> fftw_mpi_local_size_1d() and the use of alloc_local to determine the size
> of the array to allocate. fftw_alloc() itself is not putting any extra
> padding at the end.
> > On Apr 15, 2019, at 11:47 AM, Sajid Ali <
> sajidsyed2021 at u.northwestern.edu> wrote:
> > Hi Barry & Matt,
> > I'd be happy to contribute a patch once I understand what's going on.
> > @Matt, Where is the padding occurring? In the VecCreateFFTW I see that
> each process looks up the dimension of array it's supposed to hold and asks
> for memory to hold that via fftw_malloc (which as you say is just a wrapper
> to simd-aligned malloc). Is the crash occurring because the first vector
> was created via fftw_malloc and duplicated via PETScMalloc and they happen
> to have different alignment sizes (FFTW was compiled with simd=avx2 since
> I'm using a Broadwell-Xeon and PETScMalloc aligns to PETSC_MEMALIGN ?)
> > PS: I've only ever used FFTW via the python interface (and automated the
> build & but couldn't automate testing of pyfftw-mpi since cython coverage
> reporting is confusing).
> > Thank You,
> > Sajid Ali
> > Applied Physics
> > Northwestern University
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190415/cc75c76d/attachment-0001.html>
