[petsc-users] Bad memory scaling with PETSc 3.10
Zhang, Hong hzhang at mcs.anl.gov
Mon Apr 15 12:10:29 CDT 2019
Myriam:
Thank you very much for providing these results!
I have put effort to accelerate execution time and avoid using global sizes in PtAP, for which the algorithm of transpose of P_local and P_other likely doubles the memory usage. I'll try to investigate why it becomes unscalable.
Hong
you'll find the new scaling attached (green line). I used the version 3.11 and the four scalability options :
-matptap_via scalable
-inner_diag_matmatmult_via scalable
-inner_offdiag_matmatmult_via scalable
-mat_freeintermediatedatastructures
The scaling is much better! The code even uses less memory for the smallest cases. There is still an increase for the larger one.
With regard to the time scaling, I used KSPView and LogView on the two previous scalings (blue and yellow lines) but not on the last one (green line). So we can't really compare them, am I right? However, we can see that the new time scaling looks quite good. It slightly increases from ~8s to ~27s.
Unfortunately, the computations are expensive so I would like to avoid re-run them if possible. How relevant would be a proper time scaling for you?
Myriam
Le 04/12/19 à 18:18, Zhang, Hong a écrit :
Myriam :
Thanks for your effort. It will help us improve PETSc.
Hong
Hi all,
I used the wrong script, that's why it diverged... Sorry about that.
I tried again with the right script applied on a tiny problem (~200
elements). I can see a small difference in memory usage (gain ~ 1mB).
when adding the -mat_freeintermediatestructures option. I still have to
execute larger cases to plot the scaling. The supercomputer I am used to
run my jobs on is really busy at the moment so it takes a while. I hope
I'll send you the results on Monday.
Thanks everyone,
Myriam
Le 04/11/19 à 06:01, Jed Brown a écrit :
> "Zhang, Hong" <hzhang at mcs.anl.gov<mailto:hzhang at mcs.anl.gov>> writes:
>> Jed:
>>>> Myriam,
>>>> Thanks for the plot. '-mat_freeintermediatedatastructures' should not affect solution. It releases almost half of memory in C=PtAP if C is not reused.
>>> And yet if turning it on causes divergence, that would imply a bug.
>>> Hong, are you able to reproduce the experiment to see the memory
>>> scaling?
>> I like to test his code using an alcf machine, but my hands are full now. I'll try it as soon as I find time, hopefully next week.
> I have now compiled and run her code locally.
> Myriam, thanks for your last mail adding configuration and removing the
> MemManager.h dependency.  I ran with and without
> -mat_freeintermediatedatastructures and don't see a difference in
> convergence.  What commands did you run to observe that difference?
Myriam Peyrounette
CNRS/IDRIS - HLST
Myriam Peyrounette
CNRS/IDRIS - HLST
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190415/4c9d651d/attachment.html>
