[petsc-users] Error with VecDestroy_MPIFFTW+0x61
Sajid Ali sajidsyed2021 at u.northwestern.edu
Sun Apr 14 19:59:39 CDT 2019
 Hi Matt,
While in theory, that sounds perfect I still get the same error. I'm
attaching a minimal test program which creates 3 vectors x,y,z via the
petsc-fftw interface and a test vector via VecDuplicate and then destroy
all the vectors. Without the test vector everything works fine.
Thank You,
Sajid Ali
Applied Physics
Northwestern University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190414/9d192b23/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190414/9d192b23/attachment.obj>
