[petsc-users] Error with VecDestroy_MPIFFTW+0x61
Sajid Ali sajidsyed2021 at u.northwestern.edu
Sun Apr 14 19:28:06 CDT 2019
Hi PETSc Developers,
I happen to be a user who needs 4 vectors whose layout is aligned with
FFTW. The usual MatCreateVecsFFTW allows one to make 3 such vectors. To get
around this I call the function twice, once with three vectors, once with
one vector (and 2x NULL). This causes a strange segfault when freeing the
memory with VecDestroy (for the lone vector I'm guessing).
My program runs with no issues if I create the fourth vector with
VecCreateMPI (I need the 4th vector for point-wise multiply so this would
be ineffiient).
To get around this problem, is there a way to ask for 4 vectors aligned to
the FFTW matrix? If not is there a way to get the intended behavior from
VecCreateMPI, (perhaps by using a helper function to determine the data
alignment and pass to it instead of using PETSC_DECIDE)?
I'm attaching my code just in case what I'm thinking is wrong and anyone
would be kind enough to point it out to me. The issue is at line 87/88.
With 87, the program crashes, with 88 it works fine.
Thanks in advance for the help!
Sajid Ali
Applied Physics
Northwestern University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190414/ba5f18f9/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190414/ba5f18f9/attachment.obj>
