[petsc-users] Constructing a MATNEST with blocks defined in different procs
Mark Adams
mfadams at lbl.gov
Tue Apr 9 13:30:56 CDT 2019
On Tue, Apr 9, 2019 at 10:36 AM Diogo FERREIRA SABINO <
diogo.ferreira-sabino at univ-tlse3.fr> wrote:
> Hi Mark,
> Thank you for the quick answer.
> So, I defined each block of the Nest matrix as a MATMPIAIJ in the World
> communicator and I set the local sizes in such a way that A00 and A11 are
> in the processors 0 and 1, respectively.
> However, now I'm not able to set the off diagonal blocks of the Nest
> matrix. For example, if I try to set the block (0,1) of the nest with A00,
> the following error occurs:
> [0]PETSC ERROR: Arguments are incompatible
> [0]PETSC ERROR: Local sizes (2,2) of nested submatrix (0,1) do not agree
> with space defined by index sets (2,0)
> I'm using the following lines to generate the Nest matrix:
> AfullNESTpointer[0]=Ablocks[0];
> AfullNESTpointer[1]=Ablocks[0]; //Not working
> // AfullNESTpointer[1]=NULL; //It works
> AfullNESTpointer[2]=NULL;
> AfullNESTpointer[3]=Ablocks[1];
> MatCreate(PETSC_COMM_WORLD,&AfullNEST);
> MatSetSizes(AfullNEST,PETSC_DECIDE,PETSC_DECIDE,4,4);
> MatCreateNest(PETSC_COMM_WORLD,2,NULL,2,NULL,AfullNESTpointer,&AfullNEST);
This is not how you create a MatNest. See:
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateNest.html
The C example look pretty much like what you want to do:
MatCreateNest <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateNest.html#MatCreateNest>(PETSC_COMM_WORLD
<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PETSC_COMM_WORLD.html#PETSC_COMM_WORLD>,
2, NULL, 2, NULL, s->subA, &s->A);
> A simple test is given below, lunching it with: mpirun -n 2
> ./Main_petsc.exe
> Thanks in advance,
> Diogo
> static char help[] = "Create MPI Nest";
> #include <petscmat.h>
> #undef __FUNCT__
> #define __FUNCT__ "main"
> int main(int argc,char **argv)
> PetscInitialize(&argc,&argv,(char*)0,help);
> PetscErrorCode ierr;
> PetscInt i,PetscIntTEMP;
> PetscMPIInt MPIrank,MPIsize;
> MPI_Comm_rank(PETSC_COMM_WORLD,&MPIrank);
> MPI_Comm_size(PETSC_COMM_WORLD,&MPIsize);
> /////////////////////////////////////////////////////////////// Create
> Mats:
> Mat Ablocks[MPIsize];
> for(i=0;i<MPIsize;i++){
> MatCreate(PETSC_COMM_WORLD,&Ablocks[i]);
> PetscIntTEMP = (i==MPIrank) ? 2 : 0;
> MatSetSizes(Ablocks[i],PetscIntTEMP,PetscIntTEMP,PETSC_DECIDE,PETSC_DECIDE);
> MatSetType(Ablocks[i],MATMPIAIJ);
> MatMPIAIJSetPreallocation(Ablocks[i],PetscIntTEMP,NULL,PetscIntTEMP,NULL);
> PetscInt ISstart,ISend;
> MatGetOwnershipRange(Ablocks[i],&ISstart,&ISend); //Check info
> PetscSynchronizedPrintf(PETSC_COMM_WORLD,"proc(%d): Ablocks[%d]:(%d to
> %d) \n",MPIrank,i,ISstart,ISend);
> PetscSynchronizedFlush(PETSC_COMM_WORLD,PETSC_STDOUT);
> MatSetValue(Ablocks[MPIrank],0,0,5+MPIrank,INSERT_VALUES);
> MatSetValue(Ablocks[MPIrank],0,1,10+MPIrank,INSERT_VALUES);
> MatSetValue(Ablocks[MPIrank],1,0,15+MPIrank,INSERT_VALUES);
> MatSetValue(Ablocks[MPIrank],1,1,20+MPIrank,INSERT_VALUES);
> MatAssemblyBegin(Ablocks[i],MAT_FINAL_ASSEMBLY);
> MatAssemblyEnd(Ablocks[i],MAT_FINAL_ASSEMBLY);
> // MatView(Ablocks[i],PETSC_VIEWER_STDOUT_WORLD);
> Nest:
> Mat AfullNEST, *AfullNESTpointer;
> Mat AfullConverted;
> PetscMalloc1(4,&AfullNESTpointer);
> // MatSetSizes(AfullNEST,2,2,PETSC_DECIDE,PETSC_DECIDE);
> MatView(AfullNEST,PETSC_VIEWER_STDOUT_WORLD);
> MatConvert(AfullNEST,MATMPIAIJ,MAT_INITIAL_MATRIX,&AfullConverted);
> MatView(AfullConverted,PETSC_VIEWER_STDOUT_WORLD);
> ierr = PetscFinalize(); CHKERRQ(ierr); return 0;
> April 5, 2019 2:38:46 PM CEST Mark Adams <mfadams at lbl.gov> wrote:
> On Fri, Apr 5, 2019 at 7:19 AM Diogo FERREIRA SABINO via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> Hi,
> I'm new in petsc and I'm trying to construct a MATNEST in two procs, by
> setting each block of the nested matrix with a MATMPIAIJ matrix defined in
> each proc.
> I'm trying to use MatCreateNest or MatNestSetSubMats, but I'm not being
> able to do it.
> Using MatNestSetSubMats, I'm trying to construct the MATNEST, giving a
> pointer to the correct matrices depending on the MPIrank of that proc.
> I'm obtaining the error message for the line
> :MatNestSetSubMats(AfullNEST,1,&IS_ROW,2,&IS_COL,AfullNESTpointer);
> [0]PETSC ERROR: Invalid argument
> [0]PETSC ERROR: Wrong type of object: Parameter # 5
> Is there a way of doing it, or all the blocks of the MATNEST have to exist
> in the same communicator as the MATNEST matrix?
> Yes, they must all have the same communicator. A matrix can be empty on a
> process, so you just create them with the global communicator, set the
> local sizes that you want (eg, 0 on some procs).
> ./Main_petsc.exe
> #undef __FUNCT__
> //////////////////////////////////////////////////////// Create Each
> Matrix:
> Mat Adiag;
> //Create a Adiag different on each proc:
> ierr = MatCreate(PETSC_COMM_SELF,&Adiag);
> CHKERRQ(ierr);
> ierr = MatSetSizes(Adiag,2,2,PETSC_DECIDE,PETSC_DECIDE);
> CHKERRQ(ierr);
> ierr = MatSetType(Adiag,MATMPIAIJ);
> CHKERRQ(ierr);
> ierr = MatSetFromOptions(Adiag);
> CHKERRQ(ierr);
> ierr = MatMPIAIJSetPreallocation(Adiag,2,NULL,2,NULL);
> CHKERRQ(ierr);
> MatSetValue(Adiag,0,0,(MPIrank+5),INSERT_VALUES);
> MatSetValue(Adiag,0,1,(MPIrank+10),INSERT_VALUES);
> MatSetValue(Adiag,1,0,(MPIrank+15),INSERT_VALUES);
> MatSetValue(Adiag,1,1,(MPIrank+20),INSERT_VALUES);
> MatAssemblyBegin(Adiag,MAT_FINAL_ASSEMBLY);
> MatAssemblyEnd(Adiag,MAT_FINAL_ASSEMBLY);
> Nest:
> MPI_Barrier(PETSC_COMM_WORLD);
> PetscMalloc1(2,&AfullNESTpointer);
> AfullNESTpointer[0]=NULL;
> AfullNESTpointer[MPIrank]=Adiag;
> // Rank=0 --> AfullNESTpointer[0]=Adiag; AfullNESTpointer[1]=NULL;
> // Rank=1 --> AfullNESTpointer[0]=NULL; AfullNESTpointer[1]=Adiag;
> IS IS_ROW,IS_COL;
> ISCreateStride(PETSC_COMM_SELF,1,MPIrank,0,&IS_ROW);
> ISCreateStride(PETSC_COMM_SELF,2,0,1,&IS_COL);
> // Rank=0 --> IS_ROW= [ 0 ] ; IS_COL= [ 0, 1 ] ;
> // Rank=1 --> IS_ROW= [ 1 ] ; IS_COL= [ 0, 1 ] ;
> // MatSetSizes(AfullNEST,PETSC_DECIDE,PETSC_DECIDE,4,4);
> MatCreateNest(PETSC_COMM_WORLD,1,&IS_ROW,1,&IS_COL,AfullNESTpointer,&AfullNEST);
> ierr =
> CHKERRQ(ierr);
> return 0;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190409/0f81e107/attachment.html>
