[petsc-users] Error with parallel solve
Mark Adams mfadams at lbl.gov
Mon Apr 8 12:58:55 CDT 2019
This looks like an error in MUMPS:
        IF ( IROW_GRID .NE. root%MYROW .OR.
     &       JCOL_GRID .NE. root%MYCOL ) THEN
            WRITE(*,*) MYID,':INTERNAL Error: recvd root arrowhead '
On Mon, Apr 8, 2019 at 1:37 PM Smith, Barry F. via petsc-users <
petsc-users at mcs.anl.gov> wrote:
>   Difficult to tell what is going on.
>   The message User provided function() line 0 in  unknown file  indicates
> the crash took place OUTSIDE of PETSc code and error message INTERNAL
> Error: recvd root arrowhead  is definitely not coming from PETSc.
>    Yes, debug with the debug version and also try valgrind.
>    Barry
> > On Apr 8, 2019, at 12:12 PM, Manav Bhatia via petsc-users <
> > Hi,
> >     I am running a code a nonlinear simulation using mesh-refinement on
> libMesh. The code runs without issues on a Mac (can run for days without
> issues), but crashes on Linux (Centos 6). I am using version 3.11 on Linux
> with openmpi 3.1.3 and gcc8.2.
> >     I tried to use the -on_error_attach_debugger, but it only gave me
> this message. Does this message imply something to the more experienced
> eyes?
> >     I am going to try to build a debug version of petsc to figure out
> what is going wrong. I will get and share more detailed logs in a bit.
> > Regards,
> > Manav
> > [8]PETSC ERROR:
> > [8]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> > [8]PETSC ERROR: Try option -start_in_debugger or
> > [8]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> > [8]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> OS X to find memory corruption errors
> > [8]PETSC ERROR: configure using --with-debugging=yes, recompile, link,
> and run
> > [8]PETSC ERROR: to get more information on the crash.
> > [8]PETSC ERROR: User provided function() line 0 in  unknown file
> > PETSC: Attaching gdb to
> /cavs/projects/brg_codes/users/bhatia/mast/mast_topology/opt/examples/structural/example_5/structural_example_5
> of pid 2108 on display localhost:10.0 on machine Warhawk1.HPC.MsState.Edu
> of pid 2112 on display localhost:10.0 on machine Warhawk1.HPC.MsState.Edu
> >            0 :INTERNAL Error: recvd root arrowhead
> >            0 :not belonging to me. IARR,JARR=       67525       67525
> >            0 :IROW_GRID,JCOL_GRID=           0           4
> >            0 :MYROW, MYCOL=           0           0
> >            0 :IPOSROOT,JPOSROOT=    92264688    92264688
> > MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> > with errorcode -99.
> > NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> > You may or may not see output from other processes, depending on
> > exactly when Open MPI kills them.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190408/d1a86834/attachment.html>
