[petsc-users] Argument out of range error in MatPermute
Eda Oktay eda.oktay at metu.edu.tr
Mon Apr 8 03:21:21 CDT 2019
Hello again,
I solved the problem for even numbered sized matrices. However when the
matrix size is odd, then number of elements in each index set at each
processor are different. (For example, for size 4253*4253 and 2 processors,
size of index set at processor 0 is 2127 where at processor 1, it is 2126)
I think this is why, MatPermute again gives the same "Argument out of
range" error. Index sets look like correct but I still did not get why I
get this error.
This is the part of my program:
  PetscMPIInt rank,size;
  MPI_Comm_rank(PETSC_COMM_WORLD, &rank);
  MPI_Comm_size(PETSC_COMM_WORLD, &size);
  PetscInt mod;
  mod = siz % size;
  PetscInt *idxx,ss;
  ss = (siz-mod)/size;
  if (mod != 0){
    if (rank<mod){
        PetscMalloc1(ss+1,&idxx);
    } else{
        PetscMalloc1(ss,&idxx);
  if (rank != size-1) {
    j =0;
    for (i=rank*ss; i<(rank+1)*ss; i++) {
      idxx[j] = idx[i];
      j++;
  } else {
    j =0;
    for (i=rank*ss; i<siz; i++) {
      idxx[j] = idx[i];
      j++;
  if (mod != 0){
    if (rank<mod){
        idxx[ss+1] = idx[ss*size+rank+1];
  /*Permute matrix L (spy(A(p1,p1))*/
    if (mod != 0){
    if (rank<mod){
        ierr =
ISCreateGeneral(PETSC_COMM_WORLD,ss+1,idxx,PETSC_COPY_VALUES,&is);CHKERRQ(ierr);
    } else{
        ierr =
ISCreateGeneral(PETSC_COMM_WORLD,ss,idxx,PETSC_COPY_VALUES,&is);CHKERRQ(ierr);
  ierr = ISSetPermutation(is);CHKERRQ(ierr);
  ierr = MatPermute(A,is,is,&PL);CHKERRQ(ierr);
And I get the following error even if I use MatSetOption :
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Argument out of range
[0]PETSC ERROR: New nonzero at (0,4252) caused a malloc
Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn
off this check
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.10.3, Dec, 18, 2018
[0]PETSC ERROR: ./SON_YENI_DENEME_TEMIZ_ENYENI_FINAL on a
arch-linux2-c-debug named dd2b.wls.metu.edu.tr by edaoktay Mon Apr  8
11:10:59 2019
[0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
--with-fc=gfortran --with-cxx-dialect=C++11 --download-openblas
--download-metis --download-parmetis --download-superlu_dist
--download-slepc --download-mpich
[0]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 617 in
/home/edaoktay/petsc-3.10.3/src/mat/impls/aij/mpi/mpiaij.c
[0]PETSC ERROR: #2 MatSetValues() line 1349 in
/home/edaoktay/petsc-3.10.3/src/mat/interface/matrix.c
[0]PETSC ERROR: #3 MatPermute_MPIAIJ() line 1714 in
[0]PETSC ERROR: #4 MatPermute() line 4997 in
[0]PETSC ERROR: #5 main() line 352 in
/home/edaoktay/petsc-3.10.3/arch-linux2-c-debug/share/slepc/examples/src/eda/SON_YENI_DENEME_TEMIZ_ENYENI_FINAL.c
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -f
/home/edaoktay/petsc-3.10.3/share/petsc/datafiles/matrices/binary_files/airfoil1_binary
[0]PETSC ERROR: -mat_partitioning_type parmetis
[0]PETSC ERROR: -unweighted
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
Thanks!
Eda
Eda Oktay <eda.oktay at metu.edu.tr>, 25 Mar 2019 Pzt, 13:53 tarihinde şunu
yazdı:
> I attached whole program I wrote where the problem is in line 285. One of
> the matrices I used was airfoil1_binary, included in the folder. Also, I
> included makefile. Is that what you want?
> Matthew Knepley <knepley at gmail.com>, 25 Mar 2019 Pzt, 13:41 tarihinde
> şunu yazdı:
>> That should not happen. Can you send in a small example that we can debug.
>>   Thanks,
>>     Matt
>> On Mon, Mar 25, 2019 at 12:38 AM Eda Oktay via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> Hello,
>>> I am trying to permute a vector A using following lines:
>>> ierr =
>>> ISCreateGeneral(PETSC_COMM_SELF,siz,idx,PETSC_COPY_VALUES,&is);CHKERRQ(ierr);
>>>   ierr = ISDuplicate(is,&newIS);CHKERRQ(ierr);
>>>   ierr =
>>> MatSetOption(A,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_FALSE);CHKERRQ(ierr);
>>>   ierr = MatPermute(A,is,newIS,&PL);CHKERRQ(ierr);
>>> However, in MatPermute line, I get the following error even if I used
>>> MatSetOption before this line:
>>> [0]PETSC ERROR: New nonzero at (0,485) caused a malloc
>>> off this check
>>> for trouble shooting.
>>> [0]PETSC ERROR: ./DENEME_TEMIZ_ENYENI_FINAL on a arch-linux2-c-debug
>>> named 1232.wls.metu.edu.tr by edaoktay Mon Mar 25 12:15:14 2019
>>> [0]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 579 in
>>> [0]PETSC ERROR: #2 MatAssemblyEnd_MPIAIJ() line 807 in
>>> [0]PETSC ERROR: #3 MatAssemblyEnd() line 5340 in
>>> [0]PETSC ERROR: #4 MatPermute_MPIAIJ() line 1723 in
>>> [0]PETSC ERROR: #5 MatPermute() line 4997 in
>>> [0]PETSC ERROR: #6 main() line 285 in
>>> /home/edaoktay/petsc-3.10.3/arch-linux2-c-debug/share/slepc/examples/src/eda/DENEME_TEMIZ_ENYENI_FINAL.c
>>> [0]PETSC ERROR: -f
>>> [0]PETSC ERROR: -weighted
>>> I'll be glad if you can help me.
>>> Thanks!
>>> Eda
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190408/2615b428/attachment.html>
