[petsc-users] Strange compiling error in DMPlexDistribute after updating PETSc to V3.11.0
Matthew Knepley
knepley at gmail.com
Fri Apr 5 20:00:20 CDT 2019
On Fri, Apr 5, 2019 at 4:44 PM Danyang Su via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi All,
> I got a strange error in calling DMPlexDistribute after updating PETSc
> to V3.11.0. There sounds no change in the interface of DMPlexDistribute
> as documented in
> https://www.mcs.anl.gov/petsc/petsc-3.10/docs/manualpages/DMPLEX/DMPlexDistribute.html#DMPlexDistribute
> https://www.mcs.anl.gov/petsc/petsc-3.11/docs/manualpages/DMPLEX/DMPlexDistribute.html#DMPlexDistribute
> The code section is shown below.
> !c distribute mesh over processes
> call
> DMPlexDistribute(dm,stencil_width,PETSC_NULL_SF,distributed_dm,ierr)
> When I use PETSc V3.10 and earlier versions, it works fine. After
> updating to latest PETSc V3.11.0, I got the following error during
> compiling
> call
> 1
> Error: Non-variable expression in variable definition context (actual
> argument to INTENT = OUT/INOUT) at (1)
> /home/dsu/Soft/PETSc/petsc-3.11.0/linux-gnu-opt/lib/petsc/conf/petscrules:31:
> recipe for target '../../solver/solver_ddmethod.o' failed
> The fortran example
> /home/dsu/Soft/PETSc/petsc-3.11.0/src/dm/label/examples/tutorials/ex1f90.F90
> which also uses DMPlexDistribute can be compiled without problem. Is
> there any updates in the compiler flags I need to change?
What includes do you have? It looks like it does not understand
PETSC_NULL_SF.
Matt
> Thanks,
> Danyang
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190405/46c40db3/attachment.html>
