[petsc-users] Strange compiling error in DMPlexDistribute after updating PETSc to V3.11.0
Danyang Su danyang.su at gmail.com
Fri Apr 5 15:42:53 CDT 2019
Hi All,
I got a strange error in calling DMPlexDistribute after updating PETSc
to V3.11.0. There sounds no change in the interface of DMPlexDistribute
as documented in
https://www.mcs.anl.gov/petsc/petsc-3.10/docs/manualpages/DMPLEX/DMPlexDistribute.html#DMPlexDistribute
https://www.mcs.anl.gov/petsc/petsc-3.11/docs/manualpages/DMPLEX/DMPlexDistribute.html#DMPlexDistribute
The code section is shown below.
       !c distribute mesh over processes
       call
DMPlexDistribute(dm,stencil_width,PETSC_NULL_SF,distributed_dm,ierr)
When I use PETSc V3.10 and earlier versions, it works fine. After
updating to latest PETSc V3.11.0, I got the following error during compiling
       call
        1
Error: Non-variable expression in variable definition context (actual
argument to INTENT = OUT/INOUT) at (1)
/home/dsu/Soft/PETSc/petsc-3.11.0/linux-gnu-opt/lib/petsc/conf/petscrules:31:
recipe for target '../../solver/solver_ddmethod.o' failed
The fortran example
/home/dsu/Soft/PETSc/petsc-3.11.0/src/dm/label/examples/tutorials/ex1f90.F90
which also uses DMPlexDistribute can be compiled without problem. Is
there any updates in the compiler flags I need to change?
Danyang
