[petsc-users] ASCIIRead error for multiple processors
    Matthew Knepley
    knepley at gmail.com
    Fri Apr  5 09:30:35 CDT 2019
On Fri, Apr 5, 2019 at 10:27 AM Yuyun Yang <yyang85 at stanford.edu> wrote:
> Hmm ok. Then should I use this function or not when I'm reading the input?
> It's probably still going to give me the same error and unable to proceed?
> I'd like to know if I should use something else to work around this
> problem.
No, what you do is
  if (!rank) {
    PetscViewerASCIIRead();
    MPI_Bcast();
  } else {
    MPI_Bcast();
     Matt
> Thanks,
> Yuyun
> Get Outlook for iOS <https://aka.ms/o0ukef>
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Friday, April 5, 2019 5:16:12 AM
> *To:* Yuyun Yang
> *Cc:* Smith, Barry F.; petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] ASCIIRead error for multiple processors
> On Thu, Apr 4, 2019 at 10:56 PM Yuyun Yang <yyang85 at stanford.edu> wrote:
>> So do I call MPI_Bcast right after I call PetscViewerASCIIRead? Is that
>> going to prevent the other processors from trying to read the same file but
>> were unable to?
> No, all this does is replicate data from process 0 on the other processes.
>    Matt
>> Thanks,
>> Yuyun
>> *Sent:* Thursday, April 4, 2019 7:30:20 PM
>> *To:* Yuyun Yang
>> On Thu, Apr 4, 2019 at 9:19 PM Yuyun Yang via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> We are probably not going to use hundreds of processors, but i think it
>>> would be good to just have processor 0 read the input and broadcast that to
>>> all the other processors. Would that be a possible fix? And what would you
>>> suggest to work around this problem for now?
>> Explicitly call MPI_Bcast().
>>    Matt
>>> Thanks!
>>> Yuyun
>>> *From:* Smith, Barry F. <bsmith at mcs.anl.gov>
>>> *Sent:* Thursday, April 4, 2019 3:07:37 PM
>>> *To:* Yuyun Yang
>>> *Cc:* petsc-users at mcs.anl.gov
>>>    Currently PetscViewerFileSetName_ASCII() only opens the file on
>>> process 0 (for read or write) thus when you call PetscViewerASCIIRead()
>>> from any process but the first it will be reading from an fd that has not
>>> been set and you could get unpredictable results.
>>>    The implementation and documentation for PetscViewerASCIIRead() is
>>> buggy.
>>>    There are two possible fixes we could make
>>> 1) have PetscViewerFileSetName_ASCII()  open the file for reading on all
>>> processes or
>>> 2) have PetscViewerASCIIRead() generate an error if the process is not
>>> rank == 0
>>>    Barry
>>> Note that using PetscViewerASCIIRead() from a handful of processes is
>>> probably fine but having hundreds or thousands of processes open the same
>>> ASCII file and reading from it will likely not be scalable.
>>> > On Apr 4, 2019, at 3:15 PM, Yuyun Yang via petsc-users <
>>> > Hello team,
>>> > I’m trying to use PetscViewerASCIIRead() to read in a single
>>> interger/scalar value from an input file. It works for one processor.
>>> However, when running on multiple processors, I’m getting the below error:
>>> > [1]PETSC ERROR: Invalid argument
>>> > [1]PETSC ERROR: Insufficient data, read only 0 < 1 items
>>> > [1]PETSC ERROR: #1 PetscViewerASCIIRead() line 1054 in
>>> /usr/local/CLAB-2/petsc-3.6/src/sys/classes/viewer/impls/ascii/filev.c
>>> > Is there something wrong with how I’m implementing this, or ASCIIRead
>>> does not work with multiple processors?
>>> > Thanks,
>>> > Yuyun
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190405/972a2129/attachment.html>
